If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 80 of 164 FirstFirst ... 3070787980818290130 ... LastLast
Results 1,976 to 2,000 of 4096
  1. #1976
    Mart (Ham)'s Avatar
    Join Date
    Aug 2005
    Wickford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Spitfire Brotherhood (All Spitfires Welcome)
    Hi guys,
    I have a new esm 72" spit and was wondering if anyone has tried fitting the new Dle 35 with the rear exhaust, I was going to fit the Dle 20 but not sure if its going to give me enough power to rip the strip up on some nice low passes
    I've seen the Dle 30 being used but the cowl has to be cut up the side to much for my liking.
    So anybody tried the 35?
  2. #1977
    Brad330l's Avatar
    Join Date
    Jul 2004
    Port Hedland WA, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Warbirdguy
    There you go Thats a happy ending to a ''having a bad day'' story lol
    BTW here is a link to a site that has some decals for 1/5th spitfire http://www.iflytailies.com/store/decals/
    WBG
    Very cool!! Bookmarked.
    Thanks for posting.
    Brad
    Visit pilbaraaeromodellers.com
    Spitfire Brotherhood # 5
  3. #1978
    Join Date
    Nov 2005
    MANTECA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looked at the small spit over the weekend and it is a ziroli 65" wing span the plans are sill ok and could be reproduced if anyone is interested...........................
  4. #1979
    Join Date
    Mar 2003
    Springfield, VA,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Don't think ziroli ever made a small spit..
    BobH.
  5. #1980
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Chad Veich
    Hopefully it will get patched back up and flying soon
    That particular accident happened back in December of 2009. The Spitfire, MH367, has been repaired and flying again for quite some time.
    Chad,
    Thanks for the info. I am glad they repair it and its back flying!! Can you recall what happen to make it crash??
    Thanks!!
    Sonny
    aka
    jet22b
    Spitfire Brotherhood #12
    P-40 Brotherhood #52
    Great Planes Citabria DLE 35RA CC
  6. #1981
    Join Date
    Aug 2007
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mart (Ham)-
    I have the ESM SPit with a DLE 20 and the ESM Corsair 74" with the DLE 35 RA. The 35 should fit fine. THe length of the engine from firewall to thrust washer is 160 mm and the Spit calls for the thrust washer to be 158 mm from the firewall. You will have to cut open a good portion of the bottom of the cowl but that is not really a problem. You also need additional nose weight so that is a plus. Good Luck, hope this helps.
    Nothing difficult is ever easy.
    Spitfire Brotherhood #44
  7. #1982
    Join Date
    Jan 2011
    Claremont, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tevans55
    Mart (Ham)-
    I'd be curious as to any details you can provide on the ESM Spitty. I have the 72.5" ARF and am preparing a build pretty soon. I hear this plane needs a TON of nose weight and the CG provided by ESM is way off. Curious how much weight you have to add, what your flying weight is, and what CG you wound up at. Also curious which retracts you went with and how that's working out.
    Marc - Spit brother #147
  8. #1983
    Join Date
    Aug 2007
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't want to hijack this great thread. Here is a thread on this plane with lot's of great info.
    http://www.rcuniverse.com/forum/m_10..._1/key_/tm.htm
    I have been flying this plane for 4 years with an OS 120 AX and just changed the engine to a DLE 20. I am using the prototype Century Jet retracts. We used my plane to develop the retracts and they are strong and have never developed any slop. The CG should be at 107 mm and I added around 2 lbs of nose weight. That sounds like a lot for this size plane but it's a Spitfire...it will fly great! I also use about 70 degrees of flap for landing and it handles it extremely well. One thing I noticed with the flaps on this plane is that the plane does not balloon as I add flaps, it just slows down. Here is a shot of the retracts and the DLE 20 inside the cowl before I installed the JTec muffler. I also have a SR Batteries 3500 mAh NiCd mounted on top of the engine for nose weight. Hope this helps!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1845315   Click image for larger version.
ID:	1845316   Click image for larger version.
ID:	1845317   Click image for larger version.
  9. #1984
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    tevans55;
    Thanks for the link!! I am looking to build another Spit and this will give me a lot of info.
    Sonny
    aka
    jet22b
  10. #1985
    Mart (Ham)'s Avatar
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tevans55
    Mart (Ham)-
    I have the ESM SPit with a DLE 20 and the ESM Corsair 74'' with the DLE 35 RA. The 35 should fit fine. THe length of the engine from firewall to thrust washer is 160 mm and the Spit calls for the thrust washer to be 158 mm from the firewall. You will have to cut open a good portion of the bottom of the cowl but that is not really a problem. You also need additional nose weight so that is a plus. Good Luck, hope this helps.
    Tevans55
    Thanks for that helpfull info, how does the Dle 20 pull the corsair around? I wasn't sure if it would be quite enough power for the spit.
  11. #1986
    WARBIRDRCER's Avatar
    Join Date
    Feb 2008
    Oklahoma OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MajorTomski
    Hi guys, I few pages ago (post 1713) I mentioned that we have a new Spitfire flying. Here's my little GWS Spit at TORKS field in OKC. Not very happy with it yet. I have the CG where it is supposed to be but it is very twitchy. I'm going to try more nose weight.
    Tom,
    How is the spitfire? How is it flying and holding up in these Oklahoma winds?
    WARBIRDRCER:
    P-40, P-39, & Spitfire Brotherhood #1
    Skyraider Brotherhood #2
    Corsair Brotherhood #88
    F4U Brotherhood #2
    Member #12: Not so scale, almost ready to fly, soon to be scrap, warbird brotherhood
  12. #1987
    Join Date
    Dec 2001
    Litchfield Park, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jet22b
    Chad,
    Thanks!!
    Sonny
    aka
    jet22b
    I'm not sure what the official report concluded but, as I recall, the pilot was blaming a sudden change in wind direction as the airplane was rolling out after landing. It was a bad year for that particular plane and pilot as he damaged it earlier in the year with a hard landing. Been incident free ever since so far as I'm aware though!
  13. #1988
    Join Date
    Aug 2007
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Mart (Ham)
    ORIGINAL: tevans55
    Mart (Ham)-
    Tevans55
    Mart (Ham)-
    I have the DLE 35 RA in the Corsair and the DLE 20 in the Spitfire. It is a lot more power than the OS 120 AX and the 120 flew the plane very well. Weather here has been to bad to fly since I changed the engine.
  14. #1989
    facia's Avatar
    Join Date
    Apr 2012
    Edmonton, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well brothers,
    this is about as far as I am going to go with the mods to my Hangar 9 Spitfire.
    I am happy with the gunpowder weathering now and all that is left to do, is
    ironing out some wrinkles in the monokote and the flat clear.
    Hopefully I will be able to do the clear coat this coming weekend.
    Andreas
    Happy building and flying.
ID:	1845402   Click image for larger version.
ID:	1845403   Click image for larger version.
    Andreas
    Spitfire Brotherhood #130
    Cub Brother #185
    CORSAIR Brotherhood #92
  15. #1990
    Quikturn's Avatar
    Join Date
    Jan 2008
    West Des Moines, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello everyone,
    Does anyone have experience or recomendations for a Pica Spitfire? I recently purchased a 60 size Pica Spitfire kit. Looking over the plans, I see there are provisions for optional retracts but nothing for split flaps. I would really like to have flaps but I'm not sure if there is an easy way to build them on a wing that is not designed for them.
    Joe
    No matter how many times I cut it, it's still too short!
    Ultrasport Brotherhood #45, P-51 Brotherhood #34, P-40 Brotherhood #35, Saito Club member #799, Spitfire Brotherhood #173, Glow head #18
  16. #1991
    catboater's Avatar
    Join Date
    Jan 2002
    Kirkland, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: TTRotary
    In addition to reversed expo, it looked like a classic tail-heavy situation. Definitely sickening to watch. I strongly recommend that one flies the maiden on any Spitfire at CG = 25% root chord. No further back than that until one is comfortable with it. I just wound up leaving mine there on my elliptical wing birds because they fly on rails that way with straight mush-ahead stalls.
    For landing, it also helps to add 3-5 deg aileron reflex with flaps to increase the tip stall margin.
    Hate to see that. She was obviously tail heavy.
    Fly em\'\' on Sunday. Fix em\'\' on Monday.
    Spitfire Brotherhood 131
  17. #1992
    Emil The Swede's Avatar
    Join Date
    Jan 2012
    AlingsοΏ½s, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: TTRotary
    ORIGINAL: tevans55
    Mart (Ham)-
    My ESM Spitfire weighs about 6,35 kg with an OS-200. I had to add about300 grams in the nose. Use a heavy aluminiumspinner. I found that having the CG av 115 mm from the leding edge is perfekt. I use the ESM gen2 pneumatic retracts and think they work good.As allways on a warbird: try to get the servoinstallation as close to the engine as possible and be careful with adding weigt on the tail. I have made a log on my build, its in Swedish but google translate might help. http://www.amfk.se/forum/viewtopic.p...=393&start=100
    Good luck on the build!
    Spitfire brotherhood #164
  18. #1993
    Join Date
    Dec 2009
    Ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: facia
    Well brothers,
    Andreas
    Andreas, H9 aircraft come from the manufacturer covered in "Ultracote" not Monokote. Top Flite aircraftare covered withMonokote.When I build I prefer tocover the aircraft withMonokotevice Ultracote. I find that Monokote does not wrinkle as much,when applied properly as does Ultrcote.Others will say just the opposite; this is my experience with usingboth coverings.
    Roger
  19. #1994
    Join Date
    Jan 2002
    Apple Valley, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, question for the brothers....I am about to start my Comp-ARF Spitfire. I will only be working on it in passing, as I am using it as fill time as I work on my Mosquito. So updates will be far betwen. I can post updates here, as I do not plan to do an entire build thread. I plan to power it with a Quadra 75 I have. Any interest in my posting?
    Jeff
    Where's my glue....I gotta build!
    Spitfire Bro #108
  20. #1995
    Join Date
    Aug 2007
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, Yes!
  21. #1996
    facia's Avatar
    Join Date
    Apr 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Roger,
    you are correct. I mix up the two regularly.
    It should be UltraCote.
    I have had another look at my pictures and just realized that the
    landing gear is reversed. The bottom short side should be facing to the rear.
    Oh well, just have to change it around.
    Andreas
    Andreas
    Cub Brother #185
  22. #1997
    facia's Avatar
    Join Date
    Apr 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Jeff,
    yes, please.
    I am thinking about my next fall winter project already and it will be another Spitfire.
    I am torn between the Comp-ARF and the ESM Spitfire.
    So following a Comp-ARF build would be great.
    Andreas
    Andreas
    Cub Brother #185
  23. #1998
    Join Date
    Jan 2002
    Apple Valley, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, so I will post updates of my Comp-ARF Spitty here. Stay tuned.
    Jeff
    Spitfire Bro #108
  24. #1999
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: facia
    Hi Jeff,
    yes, please.
    Andreas
    Andreas,
    I have the sane problem!!!
    BTW: You are doing a great job on your H9 Spit. Like I said before, you will turn heads at your field this spring. Good luck when you maiden your bird and we want a flight report and or video!!!
    Sonny
    aka
    jet22b
  25. #2000
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jet22b
    Chad,
    Thanks!!
    Sonny
    aka
    jet22b
    Chad,
    Thanks again for the info. Maybe the plane was just to much for the pilot. I had a pilot friend of mine told me years ago, that the plane pick the pilot and not the pilot pick the plane!! I don't know if that true or not, but, some time I think so!!!
    Sonny
    aka
    jet22b
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
