Spitfire Brotherhood (All Spitfires Welcome)
Reply
Old 01-29-2013, 10:21 AM
  #2001
TTRotary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Spitfire Brotherhood (All Spitfires Welcome)
Quote:
ORIGINAL: tevans55
I don't want to hijack this great thread. Here is a thread on this plane with lot's of great info.
http://www.rcuniverse.com/forum/m_10..._1/key_/tm.htm
Hope this helps!
Thanks Tevan55. Could you tell me your ready-to-fly weight?
TTRotary is offline
Old 01-29-2013, 11:12 AM
  #2002
facia
facia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you, Sonny.
Will make another couple pics once I have the clear on and
then post a vid or flight report on the maiden probably mid to end of March.
No matter if it's the good, the bad or the ugly.
At present were in the deep freeze -28c + 24km/h winds = -42c wind chill factored. Yikes!
My Jetta TDi don't like that very much and the block heater is like an old Glade commercial - "Plug it in, Plug it in".
Andreas
Happy building and flying.
facia is offline
Old 01-29-2013, 11:58 AM
  #2003
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: facia
Hi Jeff,
yes, please.
I am thinking about my next fall winter project already and it will be another Spitfire.
I am torn between the Comp-ARF and the ESM Spitfire.
So following a Comp-ARF build would be great.
Andreas
Andreas, if you are referring to the ESM 50cc Spitfire; knowing the problems I have encountered trying to assemble the ESM 50cc Spitfire (a complete nightmare for me), I would go with a Comp-ARF Spitfire. I have read very few negative comments concerning the Comp-ARF.
Roger
ForcesR is offline
Old 01-29-2013, 01:19 PM
  #2004
facia
facia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Roger,
I should have been more clear in the size of airplane, because the Comp-ARF is the 50cc
and the ESM I was thinking of is more in the line of the 36cc which is just a little bit bigger (7.25" wingspan more) than my
present Hangar 9 Spit.
Now the Comp-ARF at 2.58m wingspan is one of my dreams, that I would like to realize
pending the sale of a couple of my musical keyboards to fund the project.
= serious investment!
Otherwise it will be the ESM 72.5" Spitfire which will be more to the liking of my finance ministers budget.
Thank you for the heads up on the ESM 50cc Spitfire assembly problems.
Much appreciated.
Andreas
facia is offline
Old 01-29-2013, 03:41 PM
  #2005
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TTRotary
Quote:
ORIGINAL: tevans55
Hope this helps!
Sorry I forgot to give you the weight. Mine weighs 15 lbs. 6 ozs. ready to fly. It is balanced at 107 mm wheels up. I also made a slightly more scale tailwheel in a more scale position on the plane. I don't think this had a major influence on altering the tail weight. Hope this helps.
tevans55 is offline
Old 01-29-2013, 04:11 PM
  #2006
kahloq
kahloq's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anybody that knows me on these forums KNOWS I predominantly fly Luftwaffe planes....almost to exclusion. However, I do have two Spitfires of decent size.
The first two pics show my Kyosho 90 size Spitfire MKII, but in captured German colors. It has a saito 125 with 15x8
The pics after that depict a modified Hangar 9 60 size that's been painted, altered a bit to more resemble an MKIX with the two large underwing radiators, etc. and include a scale small air inlet on the top right of the forward fuse. Additonally, it has later mark exhaust stacks for a merlin instead of the 3 collector piece per side manifolds of the early marks.
If you notice, it has a battery hatch on top. I have yet to put the wheel pants on. Power is from a turnigy g60 400kv motor on 6s 8000mah turning a 16x10
ID:	1845742   Click image for larger version
ID:	1845743   Click image for larger version
ID:	1845744   Click image for larger version
ID:	1845745   Click image for larger version
kahloq is offline
Old 01-29-2013, 06:21 PM
  #2007
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"The first two pics show my Kyosho 90 size Spitfire MKII, but in captured German colors. It has a saito 125 with 15x8"
Oh the horror....
Casey
glazier808 is offline
Old 01-29-2013, 08:02 PM
  #2008
dinodigger II
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Count me inIm the bonedigger.I would like to sign in as #63.That would be awesome.From here I dont have much computer experience.I do have a TF inthe making of !0 years now.Its being worked on as we speak.Get in touch with me and I'll do whatever to follow your lead-DinodiggerII.
dinodigger II is offline
Old 01-29-2013, 08:30 PM
  #2009
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We have 171 members already, that number will have been given out sorry...
Casey
Old 01-30-2013, 05:42 AM
  #2010
paladin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quikturn, I’ve done that mode for the Platt 65in ws Focke Wulf, its actually quite simple. On the FW there was a TE spar that was right were the hinges to the wing had to go. This spar was balsa and fit into a notch in the bottom of the rib this notch was half the thickness of the rib at that point. So you lay the spar out on the plans then use them to mark the notches in the ribs. Once all the notches are in make a 1/64 ply doubler that is 6in long for each rib involved. When its time to sheet the wing sheet the last 4 in of the top of the wing from ailerons in with ply. Its more work but I believe the sheeting is 3/32 so I bond 1/64 play to 1/16 balsa and bond it to the wing with the balsa out. Makes final sanding a bunch easier.
I know, I know 1/64 ply +1/16 balsa does not = 3/32. Use epoxy to make the bond between the two and the thickness will be perfect.
Joe
paladin is online now
Old 01-30-2013, 06:53 AM
  #2011
f16man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are right Bob I had a brain fade it is a Dave Platt , was a big box of lumber as the cowl is carved out of solid balsa blocks......
f16man is offline
Old 01-30-2013, 03:34 PM
  #2012
WARBIRDRCER
WARBIRDRCER's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brotherhood Update, we now have 173 in our squadron.
Welcome to the Spitfire Brotherhood #:
172. Motoman326
173. Quikturn
Start Date: 12-28-2011
Current Date: 1-29-2013
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
64.mad web tv scientist
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. Old Navy Flyer
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
129. Seamus OLeprosy
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
138. Scratchbuilder46
139. jchtr3a/John Harrigal
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
146. Michel Gravelle
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
If you would like to join the Spitfire Brotherhood please send me a PM or e-mail right here from RCU, or just make your request on this thread. I will track and assign you a number.
Never can tell when you may run into another Spitfire Brother somewhe
WARBIRDRCER is offline
Old 01-30-2013, 04:02 PM
  #2013
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
#1,
It will not be long before we hut the 200 member mark!!!
So how is your TF Spit's build going??? Hope to get back in the shop tomorrow and start the glass work!! That bad flu bug had me down for some time.[&o][&o] I have been looking at the EMS 72" Spit for my next winter build and looking at dropping a DLE 55RA in the nose!! Question to you and the Brotherhood, will that be a overkill??? Now I do have a DLE 20cc new in box, that I can use, but something tell me the plane will be under-power!! Like I said before, this will be next winter build, so I will have time to get everything in the shop for the build!!
Sonny
aka
jet22b
jet22b is offline
Old 01-30-2013, 04:13 PM
  #2014
TTRotary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tevans55
Yes, thanks very helpful Tevans55.
Just to add pics, here are a couple of my WM Spit - wing rivets over Monokote detail, and a fun pic at the flying field a couple weeks ago. Gotta love that SoCal weather. I just recieved my Top Flite Spitfire wing fillets and will be adding them to this bird soon. I may spring for a p51 canopy to replace that non-scale stock one.
Spitfire brother #147
ID:	1846169   Click image for larger version
TTRotary is offline
Old 01-30-2013, 04:56 PM
  #2015
WARBIRDRCER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sonny,
I am unsure how the 55 will fit without a lot of cowl cutting. The DLE 30 may be a better choice and save some cowling. Maybe someone will provide some insight to the fit and how much if any weight was added to the nose. Also the power requirements from others whom have done it would be nice too.
I now have the Spitfire at home for covering.
Old 01-30-2013, 04:57 PM
  #2016
motoman326
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to be a part of this prestigious brotherhood.
Here is a video of my first Spit powered by a Saito 80
http://www.youtube.com/watch?v=wYieEB-UFgI
and this is a video of our warbird fly in last year
http://www.youtube.com/watch?v=4UPz1teTHh8
Enjoy
Motoman326
Spitfire Brotherhood #172
motoman326 is offline
Old 01-30-2013, 05:07 PM
  #2017
WARBIRDRCER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Quikturn
Hello everyone,
Does anyone have experience or recomendations for a Pica Spitfire? I recently purchased a 60 size Pica Spitfire kit. Looking over the plans, I see there are provisions for optional retracts but nothing for split flaps. I would really like to have flaps but I'm not sure if there is an easy way to build them on a wing that is not designed for them.
Joe
I have one, but no flaps installed. It was put together for brother 1.5 with fixed gear and no flaps for a tail wheel warbird introduction plane.
I would say since the Spit uses split flaps you could mod the lower wing area for them. If scale looks are not an issue, you could beef up the lower wing structure, and add an in-set trailing edge, then add the hinged solid lower skin split flap.
If needed, use the steps from the top flight wing and adjust for your needs.
Old 01-30-2013, 06:37 PM
  #2018
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been looking at the EMS 72'' Spit for my next winter build and looking at dropping a DLE 55RA in the nose!! Question to you and the Brotherhood, will that be a overkill??? Now I do have a DLE 20cc new in box, that I can use, but something tell me the plane will be under-power!! Like I said before, this will be next winter build, so I will have time to get everything in the shop for the build!!
Sonny
aka
jet22b
[/quote]
Sonny-
I think the big job with putting a DLE 55 in the ESM Spit will be dropping the firewall back about 12 mm. Big job but not impossible. The 55 would be good for nose weight but there will be a lot hanging out the bottom. If you go with the 55 I agree with the 55 RA so that you will not have the muffler coming around the side of the engine. Depending on the prop you decide to use, prop clearance may be a problem when the tail wheel lifts.
If you put a 55 in this Spit, PLEASE, PLEASE promise us you will get video of the maiden...it should be exciting.
tevans55 is offline
Old 01-30-2013, 07:39 PM
  #2019
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tevans55
Sonny
aka
jet22b
Sonny-
[/quote]
tevans55,
I just left the troy-build website and found some very good info on a engine that fit the EMS 72" Spit!! It is a PTE 36cc RA, that will fit into the cowling without a lot of cutting. I want to keep the engine as much as I can inside the cowling. Plus they say that the PTE 36cc has a little more power than the DLE 30cc!! I think the DLE 55RA would be a over kill for this bird. In my younger days, I would do this mod at the drop of a hat!! But as you get older, you become wise!!!
So I am going with the EMS 72" Spitfire and a PTE 36cc RA engine for power. I will let some of the younger brothers do this. Thank you so very much for your input!! Now to do some reading and find out why other people who has this plane did not use the stock hardware!!
Thanks, again!!
Sonny
aka
jet22b
jet22b is offline
Old 01-30-2013, 07:58 PM
  #2020
tevans55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh Boy...I can help you with the stock hardware. Gently but swiftly open the hardware bags and dump them directly into the nearest garbage recepticle. The push rods are covered with a disgusting oil (don't even open that bag!) The rods must be a high carbon content which makes them rust at 12% humidity. They are also very brittle and heavy. Most if not all of the hardware will be metric, not bad unless you want to use some DuBro stuff you have collected over the years. I usually have 80% of what I need laying around in storage containers ready for the latest Chinese ARF. The wire for the tail wheel was big on my first Spitfire and they made it even larger and heavier in the second kit I purchased. As a result I bought a DuBro tail wheel kit and bashed it to look like a scale Spit tail gear. This is a great plane and I know you will enjoy the plane. I'm just kidding about the hardware (except the rods...throw those out), you will be able to selectively use some of it. Have fun...we'll be here to help if necessary!
tevans55 is offline
Old 01-30-2013, 11:29 PM
  #2021
goph
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what size engine do you have in your spity
im running a rcgf 26cc and it flys fine , been going for 4 years with out any problems.
still looking for a canopy to fit my wm 80" spity
if any body knows of any that would suit. that i may be able to get sent down to oz .
cheers goph #169
ps you like 13b?
goph is offline
Old 01-31-2013, 07:49 AM
  #2022
Duplicator41
Duplicator41's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try a Brian Taylor 83" Spitfire canopy from Traplett. It should work.
Cheers,
Duplicator41 is offline
Old 01-31-2013, 08:40 AM
  #2023
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look at this. I guess I purchase my BT a week too soon.
http://www.top-flite.com/airplanes/topa0708.html
smkrcflyer is offline
Old 01-31-2013, 11:08 AM
  #2024
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: smkrcflyer
smkrcflyer,
Just when you think you are a head of the game, somebody come by and change it!!! Now to look at Tower Hobbies website and see when they will have them in-stock. I do love it!!!
Thanks for the link!!!
Sonny
aka
jet22b
jet22b is offline
Old 01-31-2013, 11:40 AM
  #2025
InboundLZ
InboundLZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tower....they suck....
InboundLZ is offline
Reply
Display Modes
