Spitfire Brotherhood (All Spitfires Welcome)
#3007
AB, CANADA
Flight Leader, unfortunately not. :-(
It was too windy for my taste. The whole fleet is parked and the spitfire is hanging from the
basement ceiling so I can admire it while working on my winter project.
It's getting a little bit too cold around the nose now (-8c) to enjoy it.
On the bright side, there is always next spring 6 month from now. :-)
Happy building & flying.
Andreas
Andreas
#3009
My Feedback: (10)
One Less Spitfire
I regret the loss of my H9 60 Size Spitfire; I had only enjoyed flying my Spit about 12 times, a great plane, put a lot of work in it bashing it out to be a better than usual ARF offfering; on its final and fatal flight after leaving the ground I had no control, could never get it to fly level, it kept pulling up and it finally dove in nose first, a total write off.
Post mortem revealed a partially stripped Elevator Servo that had a flat spot that caused the elevator to get stuck in the up position, but when you pushed the stick forward it would go down, but it would get stuck again when you pulled the stick back, the plane kept porposing up and down and at one point when I was making the turn to try and get back to the airstrip it went inverted and it dove straight into the ground; I don't believe the servo was damaged as a result of the crash because the plane hit nose first and both the Elevator and Rudder servo tray and pushrods were intact and still attached to their surfaces and functioning.
Part of the problem as to why the servo stripped was my fault because I didn't provide enough of a hinge gap when I put the plane together. During the post crash investigation I flexed the elevators and rudder and both were way too stiff; the servo had nylon gears and I believe the excessive resistance from the elevator stripped the gear.
I think the crash could have been prevented if I had followed basic preflight rountine which I had deviated from that day, and that was to do a check of the movement of the control surfaces, which may have revealed the elevator servo problem. A reminder to "DO A PROPER PRE FLIGHT CHECK and DON'T DEVIATE FROM ROUTINE"!
I won't build another H9 Spitfire, I have a DLE55 brand new sitting on a shelf that I was going to use on a ZERO if Top Flite ever released one, so instead of waiting for a Zero I think I will get the Giant Top Flite Spitfire ARF instead.
Here is a photo just after completion and prior to maiden Flight.
#3012
SNIP
SNIP
SNIP
SNIP
#3014
My Feedback: (10)
I think that is the first time I have ever heard of not enough hinge gap. Usually those types of things show up during the build. I wonder if the elevator servo had been in a prior crash and the gears were cracked. I have had that happen more than once before. Now I label the servos when I install them so that I can evaluate their continued use in the event of a crash. It really sucks to eat a bird because the last bird that servo was in crashed.
#3016
My Feedback: (193)
FL
Sorry for the loss. I HATE when that happens. Best thing is to climb back on the horse. The Top Flite ARFs are very nice; I have the P-47, the AT-6, and the Corsair 62". They fly great, easy to land, look really good too. Love 'em all. Great prices with the Tower discounts. The quarter scale Spitfire will be big bucks in the air. Just thinking about flying one gives me a pretty high pucker factor. Get some big servos for it. --Tony #59
#3018
dasintex: that is about the sixth one that I have herd of that has had that problem that is why I wont own a 2.4 futaba but there are others out there that love them from what I have been told is that the rx and tx stop communicating to one another
Jim
Jim
#3020
My Feedback: (10)
You are correct, both Radio and Receiver were and are still working without any issues; as I described I could never get the plane to fly level; when it wanted to climb I would push forward the elevator stick and it responded, but the minute I pulled back to try and get level flight it would climb again, it was a constant up down battle, and I am guessing, the elevator servo got stuck or hung because of a section of the nylon gear was stripped, which in my opinion would account for the erratic behavior; I was able to retract the gear after taking off, full throttle control, etc.
In no way did I or will I believe it was a 2.4 Problem. I might add the Spitfire flew flawlessly a week before, and I have flown other planes on the same radio without issue. A 2.4 problem may have been a remote possibility if there were several people, greater than 20 or so, and they all had their radios on at the same time, and other 2.4 devices were actively running, etc; but I was one of 3 people at the field and the only one flying or had their radio on, and our field is far removed from the nearest town or business, etc.
The only reason I say this is that there was a possible issue with 2.4 at a huge flying event that had hundreds in attendance, and who knows how many people had their radios turned on, operating Ipads or other devices using 2.4, etc; apparently a plane went down, others had hits or glitches, the theory was that the airwaves were conjested with 2.4 traffic, some agree others don't.
#3022
My Feedback: (22)
Brotherhood, I am glad to hear so many were able to sortie,but saddened that some did not return from their missions. I and 1.5 were unable to launch due to winds and other mission objectives.
Thanks for participating in this years Brotherhood sortie and I will post next years mission plans in the future. Maybe we can plan one during better flight conditions for those in other parts of the world.
Blue Skies,
Steve
Blue Skies,
Steve
#3023
My Feedback: (22)
Welcometo the Spitfire Brotherhood Owl #203
BrotherhoodUpdate, we now have 203 in our squadron.
Welcome to the Spitfire Brotherhood Owl #203
203. Owl NC, USA
Start Date: 12-28-2011
Current Date: 10-30-2013
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
64.mad web tv scientist
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. CAPT John
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
129. Seamus OLeprosy
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
138. Scratchbuilder46
139. jchtr3a/John Harrigal
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
146. Michel Gravelle
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
184. LKruse
185. Flyfast1
186. mpro326
187. oldtimer4759
188. AZThud
189. DavidAgar WA, USA
190. David’s Dad (In Memory and Honor of his service to Freedom)
191. Capt G NV, USA
192. GregorB
193.KaP2011
194. Hawkflyer
195. taygher
196. rupa Switzerland
197. Phantom pty Panama
198.GWarden
199.CNY_Dave NY, USA
200.Rebel Flyer MN, USA
201.Alex A&MMODELS FL, USA
202.sparky4lawndart CA, USA
203.Owl NC, USA
If you would like to join the Spitfire Brotherhood please send me a PM ore-mail right here from RCU, or just make your request on this thread. I willtrack and assign you a number.
Never can tell when you may run into another Spitfire Brother somewhere, sojoin now
203. Owl NC, USA
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. CAPT John
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
184. LKruse
185. Flyfast1
186. mpro326
187. oldtimer4759
188. AZThud
191. Capt G NV, USA
192. GregorB
193.KaP2011
194. Hawkflyer
195. taygher
198.GWarden
203.Owl NC, USA
#3024
My Feedback: (22)
BrotherhoodUpdate, we now have 204 in our squadron.
Welcome to the Spitfire Brotherhood Owl #203 and Jim Branaum #204
203. Owl NC, USA
204.Jim Branaum TX, USA
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. CAPT John
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
184. LKruse
185. Flyfast1
186. mpro326
187. oldtimer4759
188. AZThud
191. Capt G NV, USA
192. GregorB
193.KaP2011
194. Hawkflyer
195. taygher
198.GWarden
203.Owl NC, USA
Never can tell when you may run into another Spitfire Brother somewhere, sojoin now.
203. Owl NC, USA
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. CAPT John
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
184. LKruse
185. Flyfast1
186. mpro326
187. oldtimer4759
188. AZThud
191. Capt G NV, USA
192. GregorB
193.KaP2011
194. Hawkflyer
195. taygher
198.GWarden
203.Owl NC, USA
#3025
Had my best sortie with my PZ Spitfire MKIX this AM. Ran quite a few batteries through her and greased every landing. I have a new one still in the box and have ordered the retracts for her. I am still flying my original with the fixed gear. I can't wait until I can fly her wheels up.
