Esm Ju-87 B Stuka
Esm Ju-87 B Stuka
First thing i was told this should not be your second plane as i am still in training so whats your thoughts on this.. and i was looking for paint for touch ups its yellow, green ,dark green and some kind of blue plus if you have so build tips or mods that would help out only thing i have done is the wings,,..
RE: Esm Ju-87 B Stuka
Build thread here. You'll find many tips and such. Dont trust the manuals CG. read through the thread to find the correct CG location.
http://www.rcuniverse.com/forum/m_5674792/tm.htm
Colors can be color matched at a local Home Depot with Baer latex paints. You dont have to buy a large quanity either.
My Feedback: (12)
MI
In terms of building, no, this should not be your second plane. Between the complicated hinges and the less than adequate Chinglish instructions, you need some experience under your belt or at the very least an experiences ARF builder to help out.
In terms of flying, it is a very docile and easy to fly aircraft. It can handle a ton of weight (mine is up to 19 lbs dry) and still lands like a trainer. If you have tail dragger experience you will do fine.
Yes the Chinglish instructions are not as clear as they should as for the hinges they fit well with little cursing as i have only done the wings takeing my time on this and looking at other builds
