Do you have ESM Electric Retracts?
Reply
Old 10-16-2012, 11:14 AM
  #76
TampaRC
TampaRC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Do you have ESM Electric Retracts?
I am interested in the V3 for the TOP FLIGHT 84" P-51.  Anyone know which set might work?  The ESM Mustang is 71" so I'm assuming I need something stronger/larger for the TF ?
TampaRC is offline
Old 10-16-2012, 11:44 AM
  #77
Tone Price
Tone Price's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
irocbsa - No idea when exactly, ESM is being very vague. The best thing to do is to contact support@troybuiltmodels.com and get yourself on the "pre-order" list. It costs nothing to do this and once we get our stock in we contact people on the list from oldest to newest orders.
TampaRC - Please contact Patrick here at TBM, he should be able to point you in the right direction: patrick@troybuiltmodels.com
SunShyne - If I looked up the plane correctly they're calling for Robart's "ROBQ1665" gear. Looks similar but you may want to contact Patrick here as well for more insight.
Robart's:
ESM's:
Tone Price is offline
Old 10-17-2012, 12:56 AM
  #78
juweeltje
juweeltje's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and? .....
who can confirm the improvements off the new V3? (exept TBM)
who have tested them thoroughly?
juweeltje is offline
Old 10-21-2012, 07:03 PM
  #79
wallace.tharp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tone, thanks, I have been talking to Thomas and he says I have the V 2.5 He told me to just send back the actuators and keep the gear legs and other items and he will send me a new set of V 3 s. All good I think & very good of Thomas at VQ Warbirds, per usual. Thanks to both of you. wallace.tharp
wallace.tharp is offline
Old 10-23-2012, 02:42 PM
  #80
splais
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just received my replacement v3 retracts and the main gear operate backward to the way the old gear worked. Does anyone know if I can just take them apart and reverse the strut block in the housing?
Secondly, could someone TBM/VQ please explain why the version 3 gear need a controller with a stand alone battery and just what this thing does?
Thanks.
splais is offline
Old 10-24-2012, 06:47 AM
  #81
Tone Price
Tone Price's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
splais - The separate board contains the circuitry that let the unit know when to stop cycling. It also receives the signal from the RX and controls the direction of the motor. The V3 are stronger and draw upwards of 1.5 amps during the cycle. This is higher than the previous versions. It was decided by the manufacturer that it would not be safe to run off the same flight pack battery.
As for the reversed direction, simply reverse the wires on the exposed motor.
Old 10-24-2012, 08:44 AM
  #82
splais
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info on the controller.
You misunderstood the problem with the main gear, but I'm handling that off line.
A general comment on the V3 gear. While I think it is ridiculous to need a separate controller and dedicated battery to run these - they are working very well so far on many ground tests. They are very quick, maybe twice as fast going up and down as the V2's.
splais is offline
Old 10-24-2012, 10:25 AM
  #83
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: splais
I would find it surprising that anyone would run e-retracts on the RX battery! Especially with the current requirements of the 2.4 gig RXers. Depending on the size of plane, throwing another battery in the plane is no big deal. Especially if it prevents you from browning out.
vertical grimmace is offline
Old 10-24-2012, 11:00 AM
  #84
splais
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My setup is a little on the overkill side. A Smartfly Power Expander with two A123 batteries. The ignition on 3rd separate batt. Have no idea if this setup impacts need for the gear to have own battery, but I am following recommended setup for the V3's
splais is offline
Old 10-24-2012, 11:21 AM
  #85
TampaRC
TampaRC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: splais
Why would you want them twice as fast? Thats twice as unscale.
TampaRC is offline
Old 10-24-2012, 11:24 AM
  #86
splais
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The version two gear were not scale, they were exceedingly slow and would not function at anything but idle speed and power. To me the V3 gear are "just right", not to fast and not two slow.
splais is offline
Old 11-12-2012, 08:36 AM
  #87
Prop_Wash
Prop_Wash's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This tread seemed to die off. Does anyone have any reports on the version 3 retracts? good,bad?
Prop_Wash is offline
Old 11-12-2012, 08:51 AM
  #88
splais
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I now have the version 3 retracts on my Texan. They appear to a great improvement over the others. I did have some initial minor problems. One motor burned out immediately and TBM replaced it ASAP. No problem since. I have cycled the gear a dozen times on the ground and flown twice. Everything seems nice and I love the cycle speed. Unfortunately our weather has been crappy lately. Hopefully some more flight tests this week/weekend.
splais is offline
Old 11-12-2012, 10:18 AM
  #89
Prop_Wash
Prop_Wash's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the update splais! Thats good news!
Old 11-13-2012, 06:39 AM
  #90
Tone Price
Tone Price's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In regards to the burnout splais encountered, sometimes the screws on the outside of the actual motor are too tight. When they are too tight, the motor cannot spin freely and after several failed actuations the gears inevitably give up. Simply breaking them free then gently re-tightening with loctite prevents future binding.
We are testing all gear that leave our warehouse so a future DOA should be highly unlikely!
Old 11-13-2012, 07:14 AM
  #91
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Tone Price
Tone,
can you show which screws you are refering to on a picture?
thanks in Advance!
Philipp
Reverend is offline
Old 11-13-2012, 07:17 AM
  #92
Tone Price
Tone Price's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Reverend
Tone,
thanks in Advance!
Philipp
Check out the PDF here: http://www.troybuiltmodels.com/ns/ma...structions.pdf
I've also attached a low-res image of that pdf for your convenience.
Old 11-13-2012, 07:29 AM
  #93
Reverend
Reverend's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
brilliant, thanks!
Reverend is offline
Old 11-13-2012, 11:15 AM
  #94
Asanders
Asanders's Avatar
I have the V3 retracts for the 190d9. Do I understand that I also need a controller board to operate these? I understand the battery and have no problem with that.
Asanders is offline
Old 11-13-2012, 11:19 AM
  #95
Tone Price
Tone Price's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Asanders
Yes you need the controller board, did you receive one with your retracts? We don't have a picture of the D9 retracts yet but here is an image of the B-25 gear. Notice the small black box in the back of the picture. This has one lead for your battery and one for your receiver. Hope this helps!
Old 11-13-2012, 01:29 PM
  #96
Asanders
Asanders's Avatar
ok cool, yup I got that board I was thinking there was something else involved! Will be trying em out soon. Gotta build the plane first! Thanks
Asanders is offline
Old 11-13-2012, 03:31 PM
  #97
wallace.tharp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tone, I talked to Thomas at VQ Warbirds and he replaced my V 2.5 with 3.0 electrics and electric control box. Nice of Thomas, I had only to pay my own shipping to him. Problem: I plugged them in same as I did the V 2.5s which workded fine with my JR 9303 and 6 vlt battery..... but, they would only retract one gear at a time & sometimes not at all. Talked to Patrick at Troy Built Models and he said try a fresh 6 vlt battery. I tried my 6 vlt 2000 ma nmhd out of my P-51 and when I plugged it in the control went up in smoke? Held for 14 minutes for Patrick later today and he put me on voice mail. Any ideas? wallace.tharp
Old 11-13-2012, 04:53 PM
  #98
Tone Price
Tone Price's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wallace.tharp, we were off yesterday so we've been playing catchup today. I apologize he wasn't able to connect with you. I'll make sure he gives you a call early tomorrow.
Old 11-13-2012, 05:08 PM
  #99
wallace.tharp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Tone, I see now why you are using the new box. Makes sense to me but obviously I am troubled that it went up in smoke. I know that 7.3 v is the max recomended on the included diagram but I am wondering if I could use a 2 cell Li po, 1000 mah, 7.4v? I am thinking no because I see voltages as high as 7.8 when I take it off the charger. Thanks for the speedy reply. wallace.tharp
Old 11-14-2012, 06:43 AM
  #100
Tone Price
Tone Price's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wallace.tharp
Patrick just relayed to me that 7.3V is indeed the max voltage. We do not recommend using a 2s lipo unless it's regulated. We use 6.2-6.8v here in the shop for testing. We feel this voltage is a good balance between performance and current draw.
We don't have your phone number on file since you're VQ's customer and the message you left was cutting out so please give us another call or PM me your number for help with your gear!
Reply
Display Modes
