If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
  1. #1
    Join Date
    Oct 2003
    Denver, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ESM LA-7 CG help?
    Finishing up a ESM LA-7 Lavachkin that I hope to maiden later this week. Trying to get the CG dialed in. The manual says 168mm back from leading edge. I have read in some forums that 160mm back is good while others have said 155 to 150mm back. Please, anyone with any experience with this bird please post your thoughts. I do appreciate it. Thanks Jon
  2. #2
    Dash7ATP's Avatar
    Join Date
    Mar 2002
    Smithfield,, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ESM LA-7 CG help?
    Try to start at around 28%of MAC.
    Too far forward and it should fly but may feel nose heavy be sluggish in pitch.
    Too far aft and it may require a rebuild.
    Good luck.
    Dash
    "When you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return."
    AMA # 8870, Member since 1978.
    Waco Brotherhood # 219.
    P-40 Brotherhood #8.
  3. #3
    Join Date
    May 2011
    Litchfield Park, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi I have 50 plus flights on mine now and I have the CG at 150 ish could be 153 or so. The ground handling at this is good and it tracks like its on rails, elevator is as close to 0 degrees as my eye can tell after trimming it out. I will say this however inverted flight needs a deliberate push forward and slow roll need some forward stick to check the noses desire to head for the ground. As Dash said if you too far foreward with the CGplane flys bad and is sluggish is pitch, to far back plane flies once! :-) I would suggest you try 150 / 155 and see, its easier to move it back than to rebuild it!
    Link to flight Video of mine
    http://www.movingmoment.net/La7.wmv
    Cheers
    Rick,
    Spitfire Brotherhood #188
    P-39 Brotherhood #25
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
