If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2007
    hamburg, PA
    Ziroli AT-6 clear coat problem
    I recently traded for this AT-6 and the guy I got this from told me that the clear coat was messed up and he started to sand the clear down. Some of the really bad spots he sanded all the way to the wood but most of the places are just sanded alittle.
    It seams to me that the nitro fuel was eatting at the clear and turning the off white into yellow. whats the best way to fix this problem? Sand all the clear off and reclear or do I have to same all the way down and reshoot the color?
    Another side question whats the best servos for the main control surfaces?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1782926   Click image for larger version.
ID:	1782927   Click image for larger version.
  2. #2
    ESSAR's Avatar
    Join Date
    Feb 2012
    ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Ziroli AT-6 clear coat problem
    You don't need to remove all the clear, just feather it out where it's not smooth with fine grit paper maybe 400 or 600, then do your touch ups, hopefully if your color match is good they will blend away seemlessly. once the aircraft is touched up scuff the whole thing with a red 3M scotch brite pad, wash with alcohol or a similar mild degreaser and re-clear. I would use a urethane type clear because typically they are more chemically resistant, But I have used water based clear with a cross linker that is also fuel resistant.
    here is a link for the nelson's clear, it also comes in a flat finish:
    http://nelsonhobby.com/hobby_paint.php
    I am an aircraft refinisher by trade so I paint a lot of airplanes at work but I have more fun painting the models like these!
    Nice plane by the way, good luck.
    Essar.
  3. #3
    Join Date
    Dec 2001
    Summerfield, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: koenig427
    Great looking T-6, but GET RID OF THAT PROPELLER!!!!
    KEEP UM FLYIN
  4. #4
    Join Date
    Apr 2007
    hamburg, PA
    ORIGINAL: ESSAR
    Essar.
    doesn't sound too bad, i'll have to give that a try. I plan on getting it flying and then over the winter redo the clear coat on it.
  5. #5
    AmishWarlord's Avatar
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did the clear coat "fail" gum crack and peel off up or did it just yellow?
    Most clearcoats will turn yellow with time so that's no bid deal.
    I really liked Black Baron clear coat years ago. It would turn yellow in time though.
    Some of the later Dynathust props had a defect.
    The cheap manufacturer decided to save money by leaving out 1/2 the fiberglass.
    They are known to break in flight. Dynathust went under because of this.
    Anyway that was in the 90's so you know that prop is OLD!
    Time to change out to a nice Master Airscrew Classic!
  6. #6
    Join Date
    Apr 2007
    hamburg, PA
    ORIGINAL: AmishWarlord
    Did the clear coat ''fail'' gum crack and peel off up or did it just yellow?
    The clear just yellowed, So I wanna take it back down and re clear it.
    Also ill be putting a nice new prop on it before flight. That was the only prop I had at that time.
  7. #7
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey by the way that Saito 450 looks great in that AT-6.
    I bet that thing sounds awesome!
    What kind of set up does the engine have? As in fuel tank size, onboard glow and exhaust?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
