Quadra 75 in a Top Flite P-47
My Feedback: (34)
Ok, I lost my TopFlite Gaint P51 very said day, but its time to find a replacement.
I have decied on the TopFlite Gaint P47, My wife likes it and It will only take $150 in parts to fix the retract for this bird.
Ihave a Quadra 75 with spring start and mag, that I got when I thought I was going to have time to stick build a Top Flite Gaint Corsair.
So anyways, I know this motor is a little heavy, seems to be about 6 pounds with the muff, mag and spring start.wich seems to be about 1 pound more over a G62.
I have serveal war birds but I really want one that will swing a nice 4 blade prop and I know this motor will do it, I was thinking a 20X10 X 4 blade will work nice on this motor.
Anyone have firewall isses with there ARF?
I know I will have to put all the weight in the tail that I can, ie: reciver packs, and will do the retracting tail wheel.
Anyone have any CG issues with this bird?
I know scale flying can be done with a US41 and it screems reall nice with a DLE55
Aguy showed up one day whileme and my boy were flying (He has a hanger 9 b25 with 2 4 strokes and my DLE55 P51 and we all few exscort, one of the best days ever)
Thanks Mike
Thanks Mike
RE: Quadra 75 in a Top Flite P-47
Build a Meister 118" Zero! A Q75 pulled mine around just fine! That is, until the vibration from that big single cylinder thumper caused the whole firewall to fall off in flight. I did have a 3w75 in a Top Flite GS P-51...loved it! That sucker was so fast I hardly had time to enjoy it as she flew by on a low pass! A Q75 is certainly overkill at your altitude but probably doable. Just be sure that your firewall and fuse is reinforced with carbon fiber!
My Feedback: (32)
I just test flew mine last weekend it is powered by a DA 85, it balanced fine with no weight added. I am running a three bladed prop and with that prop WOT passes ate really fun. Great flying airframe, i say use what you have and enjoy yourself!
Paul
Paul
My Feedback: (34)
Carbon fiber the firewall? How?
I always pin my firewalls. Drill a small whole into the firewall fill hole with thin ca. Then put a screw in it.
Are you saying to put carbon fiber from the rear?
Thanks guys I just got the ok. I wish I did not have to pay the $80 shipping. I wonder if I get my hobby store to order it with they charge me shipping?
My Feedback: (35)
LA
Theory is, if it will fit, it will work. But, and this is a big but, you don't wan't to have to add any extra weight to the tail to get it to balance. It's always good to add a heavier engine if nose weight is needed to balance, but you don't want to add too heavy of an engine to where tail weight has to be added. Also, and this is just my personal opinion, forget about the speed. I know there a lot of guys out there that like to see just how fast they can get their plane to fly, but in reality, it is so non-scale. It's fun to watch for a flight or two, but after that it sorta gets monotonous. If you want a scale-like bird, try to keep the speed as scale as possible. With that being said, you've got an engine that will turn a nice, scale four-blade prop. Just my two cents.
I epoxy 2"x5" carbon fiber cloth from the firewall to the fuse in three places. In time those "pins" can wobble out and crack the fuse sheeting. The CF pretty much makes the joint permanent. I used to do this with fiberglass but CF is significantly stronger.
Hi, i have a P47 with a 3W 85cc in 15 flights no problems, it balances without any lead but mine is a built up and i have reinforced the fire wall and other bits.
You will find the Quadra is ok no problem and not over powered , but if its an ARF it flys great with a DLE55 so the 75 should be ok.
If its the ARF just hook the engine retracts etc.in a temporary fashion to check the balance and go from there.
My Feedback: (34)
ORIGINAL: fytrjok
Thanks guys, where do you get this carbon fiber?
This is how
http://www.wyliewarbirds.com/project...ion/index.html
http://www.wyliewarbirds.com/projects/tysp47/index.html
I have been flying one with a da 85 for years now and i have had customers request the 85 power plant install in them. It is way more than it needs but if you like to hot rod go for it. A DLE 55 is a great power plant for this bird. I didnt mod the firewall.
