Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 04-01-2014, 04:01 AM
  #2776
SteveD-RCU
SteveD-RCU's Avatar
Ya they are the stick on type,Ram used them on his in an early post..never tried them before there are some videos on the procedure..I'm just laying out some panel lines.Its just starting to warm up outside painting weather will be here soon i hope.
ID:	1983198   Click image for larger version
Old 04-01-2014, 05:50 AM
  #2777
BJ64
BJ64's Avatar
Yowsa!
You can buy rivet sheets now?
Way kewl
I've been thinking along the lines of some sort of template - like the perforated gear-tabs on the old 132-column computer printer paper - and then air-brush the 'rivets' on. Those paper holes are a bit big (and that printer paper is basically obsolete now), so I'm toying with the idea of using a good old leather-punch and some strips of manila-folder/A4 binder plastic etc. to make up some fine-holed 'templates' for airbrushing.
Will have to see how that pans out...
BJ
Old 04-01-2014, 08:47 AM
  #2778
steph69
steph69's Avatar
my DLE 55RA is finally here all the way from the USA 2 weeks delivery and its finally arrived happy days.
ID:	1983224   Click image for larger version
ID:	1983225   Click image for larger version
Old 04-01-2014, 05:57 PM
  #2779
BJ64
BJ64's Avatar
I notice a lot of chat regarding the DLE 55RA.
Are there any main differences between the 55 and 55RA (apart from the rear-exiting exhaust).
BJ
Old 04-01-2014, 06:36 PM
  #2780
dasintex
My Feedback: (10)
dasintex's Avatar
BJ
Apparently, there is an issue with the Exhaust/Muffler of the 55RA; it falls apart; I have read about mounting the Muffler with longer bolts and a larger fender washer to capture the Muffler more soundly.
Old 04-01-2014, 11:36 PM
  #2781
RCHS1
RCHS1's Avatar
Just Finished bulding this TF FW - DLE 55 side ( wish I went with rear for a mush cleaner look-less cowl cut)
Robart Mains air with Robart fixed tail retract (using 4-40 turnbuckles and ball ends).
Great planes aluminum metallic 1/16 stripe tape is a great color contrast for a panel line on this model (GPMQ1236) 2 rolls for whole model -
Callie graphics awesome graphics set at a steal of a price
had to add 10 oz lead weight to balance out using jr8611 servos dle 55 side with included exhaust
ID:	1983341   Click image for larger version
ID:	1983342   Click image for larger version
ID:	1983343   Click image for larger version
ID:	1983344   Click image for larger version
ID:	1983345   Click image for larger version
ID:	1983346   Click image for larger version
ID:	1983347   Click image for larger version
ID:	1983349   Click image for larger version
ID:	1983350   Click image for larger version
ID:	1983351   Click image for larger version
ID:	1983352   Click image for larger version
ID:	1983353   Click image for larger version
ID:	1983354   Click image for larger version
ID:	1983355   Click image for larger version
ID:	1983357   Click image for larger version
ID:	1983358   Click image for larger version
ID:	1983359   Click image for larger version
ID:	1983360   Click image for larger version
ID:	1983361   Click image for larger version
ID:	1983362   Click image for larger version
ID:	1983363   Click image for larger version
ID:	1983365   Click image for larger version
ID:	1983366   Click image for larger version
ID:	1983367   Click image for larger version
ID:	1983368   Click image for larger version
Old 04-02-2014, 02:18 AM
  #2782
BJ64
BJ64's Avatar
I meant more along the lines of any marked performance difference between a DLE 55 and DLE 55RA.
BJ
Old 04-02-2014, 02:20 AM
  #2783
BJ64
BJ64's Avatar
Originally Posted by RCHS1
Just Finished bulding this TF FW - DLE 55 side ...
Now you've got me completely confused ??
The pics you're showing are for a boxer motor - are you sure you don't mean a DLE 60 twin or something?
BJ
Old 04-02-2014, 05:29 AM
  #2784
dasintex
My Feedback: (10)
dasintex's Avatar
RCHS1 "Bucky"- Matt Keller,
What Engine are you actually using, the pictures you posted show 2 engines?
ID:	1983416   Click image for larger version
Old 04-02-2014, 05:35 AM
  #2785
Lifer
Lifer's Avatar
It looks like the twin would fit if the right-thrust was eliminated or negated.
Old 04-02-2014, 05:51 AM
  #2786
BJ64
BJ64's Avatar
..even more confusing...the whiteboard plan pic looks more like a Stuka... ?
BJ
Old 04-02-2014, 10:50 AM
  #2787
n8622t
My Feedback: (8)
Making that monokote look tons better Mpizpilot .....did you use a marker on the gun hood?
Old 04-02-2014, 02:17 PM
  #2788
Mpizpilot
My Feedback: (45)
Thanks, it really does help it a bit. No on the marker, it's all chalk. I would have used my airbrush but it was a rainy Sunday afternoo. When my compressor broke and I just didn't feel like trekking out for another.
Old 04-03-2014, 03:14 PM
  #2789
HORNET FLYER
We ended up using the DLE 55 running a menz (painted black) 22x12 which provides great power although the first flight was in 24mph winds it handled it with grace!
The DA100 would fit with minor or no cutting on the sides and eliminate some of the 10ounces of nose weight!
Be wary as my first 4 landings were flawless(in 190 terms!) but on my fifth landing I believe the clamp holding the leg in loosened or was not tight enough and twisted causing a low speed side load slide enough to bend the shaft on the trunion slightly( took it out and bent it back straight) which will work for the texas city warbird this weekend as i have #fw202a on order from robart
all in all this is a GREAT LOOKING and flying airplane!
stay tuned as a friend of mine video the first flight
Paul
Old 04-04-2014, 04:48 AM
  #2790
Stone17
Maiden flight with a crazy pilot.
http://youtu.be/bFhpEVV3JSo
Old 04-04-2014, 04:53 AM
  #2791
SWORDSN
My Feedback: (13)
Lotta wind for a maiden!
Old 04-04-2014, 05:07 AM
  #2792
HORNET FLYER
Haha......dang it man!
I was excited to put my my first flight video and you beat me to it lol!
it was windy but had no choice as the texas city event is this weekend and the next warbird is bomberfield in June.
The top flite fw190 is a winner!
I know there is another one in my area and hope to link up and do some formation one day
paul
Old 04-04-2014, 05:41 AM
  #2793
BJ64
BJ64's Avatar
WInd?
What wind?
That was just a healthy dose of take-off/land assist
BJ
  #2794
BJ64
BJ64's Avatar
Hey... nice flight, BTW
BJ
Old 04-04-2014, 06:17 AM
  #2795
Lifer
Lifer's Avatar
Nice flying site!
Old 04-04-2014, 06:47 AM
  #2796
BJ64
BJ64's Avatar
Originally Posted by Lifer
Nice flying site!
Ditto.
You 'Mericans sure have some nice black-top runways at your clubs.
Down here, that stuff costs a fortune - and I haven't seen any in all the Clubs I have visited thus far.
It's either grass, or thistles to choose from.
Bitumen seems to be for full-size only...
BJ
Old 04-05-2014, 03:56 PM
  #2797
Mpizpilot
My Feedback: (45)
http://youtu.be/0IuF_h46vas Finally had some warm weather to try out the EME 55. I'm very impressed with how smooth the motor is. The FW is finally 100% complete, just need a nice day with out these crazy winds.
Old 04-06-2014, 11:22 AM
  #2798
SWORDSN
My Feedback: (13)
WInd?
What wind?
BJ
Lipstick on a pig
Old 04-09-2014, 04:41 AM
  #2799
BJ64
BJ64's Avatar
LoL
BJ
Name:	F111 closeup Pt Cook 2.jpg
Old 04-09-2014, 08:44 AM
  #2800
Nordicz
My Feedback: (7)
Well Played BJ
Z
