TF FW190 GIANT ARF
Old 05-30-2014, 11:36 AM
  #2951
Hot Rod Todd
Hot Rod Todd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by kwik View Post
Toe in, Toe out. Wonder who is right?
For most planes toe-in helps with steering stability. Because of the angle of the gear any toe in on the 190 can cause the wheels to tuck under and amplify the affects of the ground loop. From my experience so far there is no doubt in my mind, toe-out is much better than toe-in on the Top Flite FW-190.
Hot Rod Todd is online now
Old 05-30-2014, 12:33 PM
  #2952
slembones
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right
slembones is offline
Old 05-30-2014, 12:34 PM
  #2953
Chris Nicastro
Chris Nicastro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another anology I use that helps visualize the toe out benefit is from racing 1/8 or 1/10 scale buggies. Toe out gives another added benefit besides helping calm the front end down with a little drag. When jumping with toe out if the landing angle is less than perfect then the first front wheel to touch down will pull the car outward and help level the car. If it had toe in under the same circumstance then the car trips over that wheel and rolls over. Of course if the camber angle exceeds +5 degrees it probably wont matter as the mass is now over the contact patch and the car will probably roll over.
On any of my warbirds and planes Ive helped set up for guys Ive added toe out and they work great. Just try it for yourself and see. It will make landings easier and smoother than before.
Chris Nicastro is offline
Old 05-30-2014, 12:39 PM
  #2954
slembones
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes it works great. Toe out that is.
Old 05-30-2014, 12:50 PM
  #2955
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Toe out. Got it.
kwik is offline
Old 05-31-2014, 04:38 PM
  #2956
Chris Nicastro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today my buddy nearly lost his FW when the right aileron plate lost the two front screws in flight. The plate flexed backward and caused the right ail to go up and the plane was doing the downward death spiral. He backed off power dropped gear and put in opposite controls to regain control. It worked and he brought it back on final to land. He touched down with a little bounce and since he was pretty much maxed out on the controls he couldn't do much else so the FW bounced and cartwheeled.
So, just FYI, check your servo mount plate hardware often to prevent this from happening to you. He was using the stock hardware.
Broken wing gear mount and blew out the rear fuse wing mount and bulkhead, cowl, prop, etc.
Also, the electric Robart gear worked the first flight then the right gear wouldn't lock in the up position on the second flight. Im still not a fan of the electric set up and my air system has still performed flawless for over 35 flights.
Old 05-31-2014, 05:33 PM
  #2957
SWORDSN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My flying buddy has electrics in a P47 and F4U and has had about the same results.Sometimes the tail wheel won't come down and he recycles and it works.I've has good results with air also.
SWORDSN is online now
Old 05-31-2014, 11:38 PM
  #2958
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That doesnt sound good. Somethimes it helps to glue thick chunk of balsa under each corner so the screws get something to bite in.
Regarding both Air and Electrics, and the Williams Brothers 12200 wheels;
The Williams 12200 wheels are thicker than the stock ones.
So on mine, the wheels started to press against the bottom oft he wheel well.
This means that the oleo can get stuck in the up-lock position. Somethimes, a bit randomly , one wheel didnt come out.
Belly landing.
So, to avoid this, I made a 2 mm plate of aluminium with the 3 screw holes in it, and used it as a shims for the gear mount.
The wheels should really be moveable when in up position.
kwik is offline
Old 06-01-2014, 08:27 AM
  #2959
SteveD-RCU
SteveD-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up a set pf Williams Bros 14600 wheels for my FW,I see on the package that the covers snap on and off and that one can drill a 1/16" hole on the other side to help push it off on the other.Has anyone else tried this?I cant seem to get the cover off...I also got my electric retracts back from Down and Locked and they work fine,One of the motors was done and they did some upgrades
SteveD-RCU is offline
Old 06-01-2014, 05:10 PM
  #2960
sparky4lawndart
sparky4lawndart's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
in a recent post someone wrote to check the wing servo hatches. I haven't ever and went flyin today w/o looking. Had three flight today and loved every minute of it. When I went to pack my FW in the truck I saw the left wing aileron servo hatch had only 1 screw in it and was flopping around on there... scared the ***** out of me. I'm gonna go through the entire bird and check 'em all tonight...
New rule: Pre-flight the entire bird the night before and before each flight. No more gas, air, and fly for me without checking over the plane!
sparky4lawndart is offline
Old 06-01-2014, 05:19 PM
  #2961
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I screw my servos in, then take each screw out one at a time and apply a tiny drop of CA into the screw hole, then put the screw in again.
Seems to hold 'em in nice n tight
"Loctite" for Balsa
BJ
BJ64 is offline
Old 06-01-2014, 09:40 PM
  #2962
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont know...CA as Loctite...???
Wood glue seems to work for me as Locktite for wood screws.
kwik is offline
Old 06-02-2014, 07:49 AM
  #2963
p51fw190f4u
p51fw190f4u's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got toe out,too.
p51fw190f4u is offline
Old 06-02-2014, 08:03 AM
  #2964
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Loctite" for Balsa
BJ
I do the same thing. Have don this for as long as I've been building.. I remember one of the first kits I built mentioning this method.. I also run a screw or toothpick with CA through the door/hatch cover into the mounting block for the servos bottom which makes the unit one piece. This way that block has a lower chance of separating from the torque or stress.
Ramstein44 is offline
Old 06-04-2014, 02:54 AM
  #2965
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you may have actually suggested it to me somewhere sometime.
Works like a charm
BJ
BJ64 is offline
Old 06-04-2014, 05:24 AM
  #2966
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Loctite" for Balsa
BJ
I hope you aren't screwing anything into balsa & expecting it to hold. The sub surface is usually light ply, spruce or hardwood.
Quote:
That is exactly what the instructions that come W/ the TF GS FW190 say to do except W/ the additional step if backing the screw out before a semi-permanent bond occurs & them re-tightening the screw.
SOP for me on any airframe.
I use epoxy to glue the blocks to the hatch in addition to the screws. Again, per the instructions & SOP on any airframe.
SrTelemaster150 is offline
Old 06-04-2014, 08:22 AM
  #2967
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe you misunderstood me or I failed to get my point across. No instructions I've ever seen mention the extra method I posted. Placing a screw through the bottom of the block or toothpicks??? Show me.
ID:	2001097   Click image for larger version
Old 06-04-2014, 08:51 AM
  #2968
steph69
steph69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no you didn't I understood everything you said , sr telemaster seems to have a bit of a chip on his shoulder he is the same in all the other threads.
steph69 is offline
Old 06-04-2014, 09:49 AM
  #2969
SrTelemaster150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The hatches on my TF GS FW190 all have 1 screw going through the hatch cover into each if the blocks.
Yes I guess the toothpick & CA might be an extra step, but it just doesn't seem like it would add to the integrity if a full epoxy joint exists over the entire surface between the block & hatch.
Old 06-04-2014, 09:51 AM
  #2970
SrTelemaster150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Seems to me that you are the one that has copped an attitude. Just because you might not understand something doesn't make it invalid.
Old 06-04-2014, 11:06 AM
  #2971
slembones
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you all have attitudes, that is why there is only 12 people on RC universe.
Old 06-04-2014, 12:39 PM
  #2972
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well SrTelemaster, I guess until you try it you won't know. It's more of a CYA factor and it's definitely better to have that extra security. Having built and flown so many giant scaled aircraft, I know from that experience; it does add the extra peace of mind factor. Like any glued joint, adding screws or in this case, toothpicks or dowels will add strength (ask any carpenter). I also Hysol my joints which IMO is better then epoxy but that's another off topic area I care less to go into.
Old 06-04-2014, 12:47 PM
  #2973
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ramstein, Hysol IS epoxy......
kwik is offline
Old 06-04-2014, 12:49 PM
  #2974
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thx.
Old 06-04-2014, 07:15 PM
  #2975
Chris Nicastro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hysol is an aerospace grade of epoxy so in fact its better than traditional hobby epoxy, so, anyway, fyi...
Display Modes
