TF FW190 GIANT ARF
Old 06-04-2014, 07:30 PM
  #2976
tuskegee
tuskegee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW.....And lets reset. And How is your day...?
tuskegee is offline
Old 06-04-2014, 08:52 PM
  #2977
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Chris Nicastro View Post
Hysol is an aerospace grade of epoxy so in fact its better than traditional hobby epoxy, so, anyway, fyi...
See, this is what I meant to say... Well said!! Now......Lets get back on topic..If possible.
Ramstein44 is offline
Old 06-05-2014, 12:07 AM
  #2978
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've often wondered about Hysol.
It ain't cheap, IIRC - but a lot of people seem to use it where an extra-stregth epoxy is required.
Like gluing the turbine blades together in a Change Sun CS 12 blader when they up the LiPo & RPM to ensure they don't explode at increased max revs
I have also read that it's a bit 'stiffer', and won't run everywhere as easily as "normal" epoxy does.
Must get some one day and see what all the fuss is about...
BJ
BJ64 is offline
Old 06-05-2014, 04:34 AM
  #2979
dmyers0403
My Feedback: (48)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use Hysol a lot but Hysol has its certain application for fillits, voids etc but is not for everything. Thinner better penetrating epoxies should be used where tighter joints, clamping are needed etc.
dmyers0403 is offline
Old 06-05-2014, 04:44 AM
  #2980
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Who retails Hysol?
Lifer is offline
Old 06-05-2014, 04:51 AM
  #2981
tuskegee
tuskegee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I get mine from Grainger. But I will check. It is pricey but they have all lot of different types for different projects.
tuskegee is offline
Old 06-05-2014, 06:04 AM
  #2982
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aircraft Spruce sells T88 structural adhesive. It's the epoxy that folks that build real planes with. Been using it for years!
sparky4lawndart is offline
Old 06-05-2014, 06:30 AM
  #2983
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sparky,
Thanks! I'll look into it. Bye the way, I build "real" airplanes, too. They just don't carry me.
Lifer is offline
Old 06-05-2014, 06:41 AM
  #2984
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is where I get mine.
http://www.altecare.com/toolshysol.htm
Old 06-05-2014, 07:06 AM
  #2985
sparky4lawndart
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Lifer View Post
sparky,
OMG! I should have said "full size". LOL
Old 06-05-2014, 08:10 AM
  #2986
Ron Stahl
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As an alternative to Hyso;l I have used West systems 610. Its about 20$ for a tube that fits into a std caulking gun and gives you about 4 times the amount of epoxy over Hysol. You can get it at any West Marine shop or Jamestown Distributers on the web. The only down side is since it is a larger tube you can't get it inside some places.
Ron Stahl is offline
Old 06-08-2014, 12:36 PM
  #2987
sparky4lawndart
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I go out today with my TF GS FW190 and see that I have a leak in the tank. I pull it apart and see that the seam in split so I ask around and low and behold one of my buddies has the same size tank sitting in his truck bed... They look identical so I plumb the new tank in and all is well... First flight it runs lean and stalls after 2 minutes so I dead stick it in and everything is okay... I richen the High end a bit (1/8 turn) and fuel up, air up, and go fly with a buddy of mine, Tim Cardin, with his "Man o War" P51... formation flying, loops on the dead line, military rolls less than 40 feet apart.. It was great. My timer on my radio goes off (2 minute warning) and then the engine quits 50 feet up the run way dead line and 20 feet off the deck... drop the gear, fly over 500 feet of runway and land in the weeds... cart wheel tears the wing off the fuse and breaks one horizontal stab in half and wrecks another $35 Zoar 22X10...
I'm soo bummed... I'm going to be in repair mode for a few days.
Old 06-08-2014, 12:45 PM
  #2988
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it were me, I would not mount my servos to the hatch! I mount my servos in rails in the wing, then use the hatch for access. Vibration is going to cause you to lose screws. I am sure this is how the Arf was engineered, but it is not the best method for an airplane this size. I am sure this will be too much work for some though.
vertical grimmace is offline
Old 06-09-2014, 02:32 AM
  #2989
ticketec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BJ,
You can get Hysol from either DA Australia, or intairco here in Oz.
Not cheap, but very very good. A word of warning, I use it when building my Jet's and over time the hysol shrinks a little more than when it was first set. I means that it can put the glass around the joint a little making the bulkhead outline and glue joint visible from the outside of the model.... just the tinyest of shrink, but on a glossy model, It sticks out.
dave
ticketec is offline
Old 06-10-2014, 12:48 AM
  #2990
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ta TT
I think I've seen/heard of it being sold somewhere around here too...
BJ
BJ64 is offline
Old 06-10-2014, 10:21 AM
  #2991
vertical grimmace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A fellow club member was flying his FW 190 last night. He had all but given up on trying to land it without the ground loop. In fact he offed to sell it to me! Well, as a last try, he put in toe-out. It worked great. He had 2 very nice landings, with good control. Just though I would pass this along as I witnessed it last night. Anyone having problems may give this a try.
Old 06-10-2014, 05:05 PM
  #2992
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe thats why the full scale FW had toe out
BobH is online now
Old 06-10-2014, 06:03 PM
  #2993
Chris Nicastro
Chris Nicastro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to McMaster Carr and look up Hysol. They have a good product page that shows the different kinds and general apps.
http://www.mcmaster.com/#loctite-hysol/=scs4mc
I use 9462 usually.
Chris Nicastro is offline
Old 06-11-2014, 12:58 PM
  #2994
FlyRoswell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Subd
FlyRoswell is offline
Old 06-11-2014, 01:13 PM
  #2995
kwik
kwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It did?
kwik is offline
Old 06-13-2014, 11:49 AM
  #2996
Hot Rod Todd
Hot Rod Todd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After a dozen posts about Hysol I think we need to see a good flyin' photo!
Hot Rod Todd is offline
Old 06-13-2014, 12:06 PM
  #2997
ptdan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very very Nice picture...
ptdan is offline
Old 06-13-2014, 02:32 PM
  #2998
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There's a few "toe out" ones in amongst the Hysol ones too
But ditto - lovely pic
That's the one you did all the rivet work on, yah?
BJ
BJ64 is offline
Old 06-18-2014, 06:24 AM
  #2999
p51fw190f4u
p51fw190f4u's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my fw190.
ID:	2006424   Click image for larger version
ID:	2006425   Click image for larger version
p51fw190f4u is offline
Old 06-18-2014, 08:10 AM
  #3000
cubarican323
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sucks to hear the fw went down. Do you still have that esm twin engine I sold you?
cubarican323 is offline
Contact Us Archive Advertising Cookie Policy
