Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 12-11-2014, 07:28 PM
  #3526
dmyers0403
My Feedback: (48)
The EME70 is a sweet engine. Bought mine from Milehigh with starter installed. Installed on 96 inch AMR-RC stick to replace DLE50. Ran perfect out of box. Very smooth with great throttle transition. Running 24/10 Zoar. Installing second on a TBM 92 inch Zero to replace ZDZ80.
Old 12-11-2014, 11:23 PM
  #3527
jagdpanther9
jagdpanther9's Avatar
good to hear positive things about the eme 70cc twin. I would like to swing a 23x10 3 blade from tbm for my 190. does a 2200mah 3 cell work for the starter or what do you use? also I see the ring gear and starter are on the back of the motor it looks like the stand offs should give enough clearance though.
Old 12-12-2014, 11:32 AM
  #3528
MX240
MX240's Avatar
Originally Posted by mirored
Absolutely love the Demon Cortex 3-axis gyro. Rather pricey but you can find them on sale periodically.
I checked out the Demon Cortex gyro and even called DreamWorks.
It didn't sound like something I would want as the instructions and the person told me I would not want it on hold for landing.
I don't know about take offs. Sounds like a 3-D type thing to me. you whip your plane up for a harrier...flip on hold and watch.
Not into that stuff anymore.
Old 12-12-2014, 04:36 PM
  #3529
BJ64
BJ64's Avatar
...which begs the question for 3D flying - isn't it meant to be all about Pilot control and not the electronics doing all the work?
Not having a go at electronic stabilization as such - it sure has its uses in things like Warbirds, big jets etc.
But for all that whirly trwirly 3D-specific stuff, I would have thought the marvel of all those manoeuvres was that the Pilot was controlling them... (??)
BJ
Old 12-12-2014, 05:25 PM
  #3530
mikes68charger
My Feedback: (34)
I have iceman 3axis gyros in my Top Flite Gaint Fw190, P51,P40 and F15 turbine
Its nice makes you less worried about the weather and helps with take of and landings. It helps a lot but you still have to fly her like the big war birds they are
Old 12-12-2014, 07:00 PM
  #3531
MX240
MX240's Avatar
Thanks Mike....yes with any gyro a person has to help out a little on take offs and landing...which works for me.
I think the jet guys use heading hold on take offs...but they can't touch any thing or the plane goes crazy?? Just what I read.
Here are some other choices from Chief Hobbies....I think I will stick with my cheap JR gyros on rudder only.
http://www.chiefaircraft.com/radio-c...o-systems.html
Old 12-12-2014, 07:02 PM
  #3532
dmyers0403
My Feedback: (48)
I use a 3S-1300mah and it last several starts, enough for a full day with plenty to spare. Standard engine stand offs are same as used on non starter version and need some spacers to allow gear bolt head clearance, about 3/16".
FYI: I read a post where a guy was told to use 2S because his switch would not work on 3S. I have never experianced this.
Old 12-12-2014, 08:13 PM
  #3533
BearBow
that would be great bear! I am nearly positive that it will fit as I printed off the dimensions and measured my cowl but until someone physically tries it ... I thought if anything that the front plug would need some clearance.
It will fit using a da70. But there's a max of 1/4" clearance at each spark plug. I'm pretty sure you'll need a 1.0"x0.5" hole on each side for the spark cap.
Old 12-12-2014, 08:14 PM
  #3534
BearBow
Maybe see if the dle60 twin is smaller?
Old 12-12-2014, 09:54 PM
  #3535
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
hey guys.. I know you guys are pretty amazing but I gotta tell you.. The DLE55RA really does pull this airplane around with authority... I'll admit the twins are pretty awesome but, wow, is that a lot of work!
I love my TF GS FW190.. absolutely my favorite plane in the hangar... I love the way it looks, the way it flies, and landing clean on the mains gets me "sprung"...
I'm working on my 1/4 scale Clark Spitfire now and it's DA inline 100 twin... wow. what a motor... I think my next build will be a Meister with this motor if I can figure out the exhaust.
the motors from MileHighRC are really high quality I like the sound of the 70cc (especially with the starter). okay.. I gotta setup to go fly tomorrow! it's the weekend brethren.. let's take to the skies!
Old 12-12-2014, 10:14 PM
  #3536
jagdpanther9
thanks for checking bear, I was hoping not to hole the cowl. I wonder if there is any shorter boot that could be used without making r/f problems for the receiver? I tried a different plug boot on a model once and upon preflight when the engine was revved up the control surfaces would freak out and twitch like crazy. it was with spektrum 2.4. I switched the plug boot back and problem gone. I also had the same problem with an optical kill switch with the same receiver an ar7000. removed the OKS and problem gone.
it sounds like I might just go with the eme 60cc single W electric start is suppose to have the same dimensions as the dle 55 and @ 6.2 hp it will still swing a 22x10 3 blade.
but the twin would be so smooth!!! but the saito R3 84cc would sound SOOO cool! but the evo 777 radial glow would be SOOO cool! and....slimy. trying to keep it simple but Cool.
Old 12-13-2014, 12:57 AM
  #3537
zadeda
Мой двигатель jc60, ширина 265 мм, с носить свечу крышку. Двигатель одет в плотный, без отверстий.
Old 12-13-2014, 07:32 AM
  #3538
SWORDSN
My Feedback: (13)
You can say that again!
Old 12-13-2014, 07:42 AM
  #3539
Lifer
Lifer's Avatar
Lmao!!!!
Old 12-13-2014, 09:07 PM
  #3540
ForcesR
Bearbow, I am not trying to start an argument here, but my measurements are as follows
FW-190 Cowl is 272mm diameter or 10 3/4 inch diameter.
Engine with spark plug caps installed is 250mm wide or 9 7/8 inch wide.
Total clearance remaining is 22mm or 7/8 inch.
Divided by 2 for each plug cap = 11mm clearance for each plug cap or 7/16 inch clearance from inside of cowl.
You will not need to cut any holes in the cowl for spark plug cap clearance since 7/16" is more then the 1/4" max required
Roger
Old 12-14-2014, 12:40 AM
  #3541
jagdpanther9
it seems like the eme 70 twin will fit from what I have measured as well. both the eme 60 single and the 70cc twin are out of stock right now so I figure I will wait till they come in and get the word from mile high as to how the 70cc twin fits their TF fw190.
Old 12-14-2014, 08:23 AM
  #3542
zadeda
Зазор С одной стороны-2 мм, с другой -. 0
ID:	2054947   Click image for larger version
Old 12-14-2014, 09:42 AM
  #3543
spaceworm
Thank you very much. Pictures are the universal language. Please accept from me apologies for the comments from LIFER and SWORDSN.
Sincerely, Richard
Old 12-14-2014, 11:02 AM
  #3544
ForcesR
Good day Zadeda, I agree with spaceworm, thank-you very much for posting. The two photos you posted of the JC 60 twin has almost the same foot print as the EME 70 twin. The JC 60 is another twin engine one could choose to fit the FW-190 cowl..!!
Roger
Old 12-14-2014, 11:08 AM
  #3545
ForcesR
Unhappy
BearBow, unfortunately the DLE 60 is 274mm wide, larger than the 272mm cowl on the FW-190.
Roger
File Type: pdf
Old 12-14-2014, 12:12 PM
  #3546
mikes68charger
My Feedback: (34)
Well fellows I maden my FW190 today.
All I can say is wow. Some of you guys had me really worried about this one, even though I have a Top Flite Gaint P40, P51, P47 and the fw190
It took off gently and was very smooth. Used less rudder control than the p40 needes
I have to say those electric robarts look really nice going up on takeoff. I see why you guys like them so
I got 3 flights in and each landing was better than the last.
I was worried about the long gear but just kept the tail up as long as I could. Trust me my GeeBeeR3 is a lot harder to land than this gaint
Old 12-14-2014, 12:34 PM
  #3547
mikes68charger
My Feedback: (34)
Oh yeah. DLE55 standard with stock muffler.
I put a Iceman gyro but this bird flys so well I never even turned it on
ID:	2055008   Click image for larger version
ID:	2055009   Click image for larger version
Old 12-14-2014, 01:46 PM
  #3548
zadeda
Udlennite a platform also transfer accumulators forward. Machine guns need to be lowered a little in a bottom. The pilot needs to be put above. It will reduce the mass of freight. Excuse for my English! I use online translation. Not always it turns out correctly.
ID:	2055051   Click image for larger version
Old 12-14-2014, 02:06 PM
  #3549
zadeda
Sincerely, Richard
Everything is good! If you could read the comments after transfer to Google, this same happens cheerfully! Thanks for understanding! With pleasure I read all subject.
Old 12-14-2014, 05:10 PM
  #3550
rcguy59
My Feedback: (8)
rcguy59's Avatar
Finally finished mine. DLE55 w/ homemade all-steel wrap-around pitts muffler.(I needed the mass) Sierra main gear and wheels, Futaba control. Came in just under 27 lbs.
ID:	2055087   Click image for larger version
ID:	2055088   Click image for larger version
ID:	2055089   Click image for larger version
