Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 10-20-2015, 01:08 PM
  #4001
dasintex
My Feedback: (10)
dasintex's Avatar
Robarts Landing Gear Issues
With all the issues with Robarts Retracts made for this Bird, what about using Sierra gear; I know they cost more, but will they fit without too much problems or modification and if so what sort of modifications are needed for them to work?
Old 10-20-2015, 03:42 PM
  #4002
Tony Gag Jr.
My Feedback: (124)
Tony Gag Jr.'s Avatar
That is the route I am going to take when I am ready to install retracts. No way am I going to waste money on the Robarts. Skyshark makes a pretty nice little mod kit for the Sierra.
http://www.skysharkrc.com/item/Top-F...erra-Gear-1201
Old 10-20-2015, 07:58 PM
  #4003
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
The system looks OK but the railings look fragile. You should modify them for 5/8 spruce. Those look like 1/4 ply.
Old 11-21-2015, 12:27 PM
  #4004
FokkerD7
FokkerD7's Avatar
I have ready for maiden flight. 1/2 glass Home Depot satin latex exterior house paint. Futaba guidance, Robart air,Fox 3.2 Kirby graphic.
Old 11-21-2015, 12:28 PM
  #4005
FokkerD7
FokkerD7's Avatar
ID:	2131690   Click image for larger version
Old 11-22-2015, 07:17 AM
  #4006
108buzz
My Feedback: (14)
The problem with the Robart TF FW190 and TF Zero Robart gear is that in Robart's infinite wisdom the weld the pins into the trunion. This weakens the metal pins. If they would just secure hardened pins in the trunion without welding them, they would find that the pins would not bend so easily. I bet they will say they did that so the pins would bend and not rip the gear out of the wing. LOL. Good excuse, I bent mine in my zero on a average landing. A guy at are club is a machinist and he has JB welded some hardened pins in another members TF FW190 and he has had no problems at all. Anyway, GO with the Serria. They are worth the extra money!
Old 11-22-2015, 07:44 AM
  #4007
Lifer
Lifer's Avatar
Is the problem with the Robart FW-190 gear continue to this day or is it just the early releases?
Old 11-22-2015, 07:52 AM
  #4008
108buzz
My Feedback: (14)
I am not sure. If I were to guess, they probably are the same. I have the Serria for my FW190, but will have the harden pins put in my Zero this winter. I have bent them twice and the landings were not that bad that they should have bent. I wish I went with the Serria Zero retract now.
I'll will upload picture of the FW190 Serria retracts.
Old 11-22-2015, 07:59 AM
  #4009
108buzz
My Feedback: (14)
You can see the side stryt is functional and locks when the gear is fully extended.
Serria FW190 Gear inserts: http://www.skysharkrc.com/item/Top-F...erra-Gear-1201
Good FW190 Serria Gear Info: http://www.rcscalebuilder.com/forum/...595&PN=1&TPN=2
ID:	2131802   Click image for larger version
Old 11-22-2015, 08:21 AM
  #4010
Lifer
Lifer's Avatar
Thanks for the reply. I'm contemplating my next project and I like the Top Flite warbirds, but the Robart gear issues are a concern. I have a set of Sierras in a .60-size Top Flite P-40 and they perform great but they are pricey. You always get exactly what you pay for but I have a budget.
Old 11-22-2015, 12:32 PM
  #4011
WarbirdPilots
My Feedback: (209)
Default Warbird Pilots 1/6 ~ 1/5 Scale WWII German Luftwaffe Pilot, Top Flite Giant FW-190
Hello, My name is Adam Martin of Warbird Pilots. www.warbirdpilots.com I have been getting a lot of questions lately as to which pilot fits the Top Flite Giant FW-190. So I wanted to take a second to show you the pilot I offer for this aircraft and how it fits.
The pilot is the 12" Tall, 1/6 ~ 1/5 Scale WWII German Luftwaffe Pilot
http://www.warbirdpilots.com/product...lot-figure.htm
As you can see the pilot comes with all that is shown. Pilots come completely dressed and ready to install. The figure comes with a beautifully painted head and highly detailed clothing and equipment specific to the Luftwaffe. Right down to the German oxygen mask. I also made all the clothing, accessories, and equipment fully removable to allow you to change the pilot and give it your own personal look. Finally, I designed it with a wire frame, cotton body that is incredibly light (5 ounces) and allows it to be manipulated and bent in any position.
As you can see from the pictures below, the entire figure fits incredibly well, and is very easy to adjust and to sit in the exact location you want. One advantage with the wire frame cotton body is that the figures seated height can be adjusted just by bending the figure further up or down its waist. That will allow the figure to sit higher or lower in the seat and get his eyes to look right down the gun sight.
And don't forget to look at the servo operated moving head option. I install a Hitec HS-55 servo in the figures chest allowing the head to be moved left and right. If you add this option, the figure will come complete with a wire coming out his pants, ready to plug and play.
http://www.warbirdpilots.com/product_p/servo-head.htm
I hope this helps you decide the correct size pilot to fit into your Top Flite Giant FW-190. Feel free to call or email me with any questions or if you just want to talk shop. I have been flying for 25 years and love warbirds.
Adam Martin
Business: 203-528-4352
[email protected]
Name:	RC Pilot figure German Luftwaffe 3.jpg
ID:	2131854   Click image for larger version
Name:	RC Pilot figure German Luftwaffe.jpg
ID:	2131855   Click image for larger version
Name:	RC Pilot figure German Luftwaffe 2.jpg
ID:	2131856   Click image for larger version
Name:	RC Pilot figure German Luftwaffe 4.jpg
ID:	2131857   Click image for larger version
Name:	RC Pilot Figure Top Flite FW-190.jpg
ID:	2131877   Click image for larger version
Name:	RC Pilot Figure Top Flite FW-190  1.jpg
Old 11-22-2015, 12:53 PM
  #4012
MX240
MX240's Avatar
Hi Guys,
This last Sept at a warbird event I had the first flight perfect.
The second flight when I cut to idle on landing my DA 50 died....what the heck! Never did that before.
A hour later going to fly again after motor start up any time I tried to bring back to idle the motor would about quite.
SO....I run the throttle trim up a bunch so it would taxi out.
After a good flight the motor would not idle down enough to land so a go around and bringing back the throttle trim.
I did get the motor to idle slow enough to land but screwed up the landing and broke the plastic cam on the Robart.
This morning I fought the FW190 inside socket screws for three hours as I must have used the too good Lock-Tight on screws.
Finally I just grabbed that big cowl and yanked it off breaking off the plywood liner.
That cowl will be held onto blocks with screws OUTSIDE from now on.
AND...I never did find any throttle linkage problems???????? So I am changing throttle servo.
Old 12-01-2015, 04:14 PM
  #4013
FokkerD7
FokkerD7's Avatar
I changed my socket heads out and put Phillips screws in. It's a lot easier to remove the cowl if I need to.
Old 12-02-2015, 12:52 PM
  #4014
zadeda
Есть фото? Замечание на предыдущей окраски фото: композиция из кресты на крыле консоли не исправить. Крест утилизировать ближе к центрам. В интернете есть много фото схем расположения опознавательных знаков.
Old 12-02-2015, 01:46 PM
  #4015
dasintex
My Feedback: (10)
dasintex's Avatar
Exactly!
Old 12-08-2015, 06:01 PM
  #4016
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
Hi Zadeda, I think the paint and markings are close but there's always a little artistic license!
Old 12-08-2015, 06:44 PM
  #4017
n8622t
My Feedback: (8)
I bet he flys a LA-7 or a Yak 3U
Old 12-09-2015, 12:54 AM
  #4018
zadeda
К моему глубокому сожалению, мой самолет разбился на закрытие летнего сезона... произошел отказ двигателя, дистанция была большая, и самолет, не дотянув до взлетно-посадочной полосы, врезался в дерево. На правой консоли разрушен полностью, на левой консоли, устойчивый не большой урон. Я хотел заказать новые, но цена в настоящее время курс доллара, кусаются. Я решила, что я лучше сделаю новый проект крыла, под набор retrakt от Ладо компании и я сделаю их съемными для удобства хранения.
Old 12-09-2015, 01:23 AM
  #4019
zadeda
Я не спорю, расцветки могут быть любые, на любой вкус, но договоренности различий, должна быть как можно точнее. Расположение и размер имеют очень важную роль! Можно ошибиться на 1/2 - 1 дюйм +/-, но не на 2-3, это уже большая разница. Это все равно, что рисовать глаза на висках, ближе к ушам, но не к переносице. Надеюсь я ясно привел пример? Или например нарисовать черные полоски на крыле Р-47, Р-51 на краю консоли, на элероны. Я думаю, что ошибка будет очевидной.
Old 12-09-2015, 01:45 PM
  #4020
n8622t
My Feedback: (8)
Zadeda I hope you are bi lingual so you can read this..... English man, EEEEEEnglish!!!!!!
Old 12-09-2015, 01:58 PM
  #4021
GalenB
My Feedback: (18)
From an online translator...
I'm not arguing, colors can be any, for every taste, but differences arrangements should be as accurate as possible. Location and size have very important role! You may make a mistake on a 1/2-1 inch +/-, but not at 2-3, this is already a big difference. It's like that to draw eyes to temples, closer to the ears, but not to the nose. I hope I'm clear cited? Or for example to draw black stripes on the wing of the p-47, p-51 at the edge of the console on the ailerons. I think the error is apparent.
К моему глубокому сожалению, мой самолет разбился на закрытие летнего сезона... произошел отказ двигателя, дистанция была большая, и самолет, не дотянув до взлетно-посадочной полосы, врезался в дерево. На правой консоли разрушен полностью, на левой консоли, устойчивый не большой урон. Я хотел заказать новые, но цена в настоящее время курс доллара, кусаются. Я решила, что я лучше сделаю новый проект крыла, под набор retrakt от Ладо компании и я сделаю их съемными для удобства хранения..
To my deep regret, my plane crashed at closing of the summer season. There was a failure of the engine, the distance was great, and the plane, not shy to the runway, crashed into a tree. On the right of the console completely destroyed, on the left of the console, sustained no great damage. I wanted to order new ones, but the price is currently USD rate, bite. I decided that I better do a new project under the wing set retrakt from Lado company and I will make them removable for easy storage.
It's not perfect but you can see what he is talking about... I am wondering about the "console" he keeps referring... Is there a translation loss?
Old 12-09-2015, 05:13 PM
  #4022
zadeda
Excuse friends! My browser is adjusted on machine translation from English into Russian, and when writing of posts by me in English, something went not and the browser translated the text back into Russian. I will try to restore everything a hronologichny order from a post #4014.
#4014. I asked FokkerD7, whether there is at it a photo? (post No. 4013)
Further, I pointed FokkerD7, to its error of an arrangement of identification marks on the wing console (a photo, a post No. 4005). "The remark on the previous photo of coloring of the console: arrangement of identification marks not correct. The cross has to be a little closer to the centers. On the Internet there is many photo of schemes of an arrangement of identification marks."
#4018. "To my deep regret, my plane crashed into closing of a summer season... there was an engine failure, the distance was big, and the plane, without having held on to a runway, crashed into a tree. The right console is destroyed completely, on the left console, not a big loss. I wanted to order new, but the price now and dollar exchange rate, bite. I decided that I better will make the new project of a wing, under the retrakt set from the LADO company. I will make wing consoles divided, for convenience of storage."
#4019 I answered sparky4lawndart: "I don't argue, the coloring can be any, for every taste, but signs of distinctions have to be as it is possible more precisely. The arrangement and the size have very important role! It is possible to be mistaken on 1/2 - 1 inch +/-, but not on 2-3 inches, it is already big difference. It all the same that to draw eyes on temples, is closer to ears, but not to a nose bridge. I hope clearly gave an example? Or for example to draw black strips on a wing of R-47, R-51 on the edge of the console, on ailerons. I think that the mistake will be obvious."
I hope my Google the translation isn't so awful. If there are questions, set.
Old 12-09-2015, 06:46 PM
  #4023
FokkerD7
FokkerD7's Avatar
Zadeda the word console are you referring to the wing?
Old 12-10-2015, 04:39 AM
  #4024
zadeda
Yes, the console is a wing, to be exact one part.
Old 12-10-2015, 06:54 AM
  #4025
HoundDog
My Feedback: (49)
HoundDog's Avatar
Found this on Landings,com did U own it at one time?
N-number : N8622-T\Aircraft
Serial Number : 52522
Aircraft Manufacturer :
CESSNA Model : 182CEngine Manufacturer :
CONT MOTOR Model : O-470 SERIES
Aircraft Year : 1960
Owner Name : DENNIS BILLY C JROwner Address :
13927 E QUAIL TRACK RD
Type of Owner : Individual
Registration Date : 01-May-2014Airworthiness Certificate
Type : Standard
