If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 39 of 174 FirstFirst ... 2937383940414989139 ... LastLast
Results 951 to 975 of 4330
  1. #951
    SrTelemaster150's Avatar
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: TF FW190 GIANT ARF
    ORIGINAL: BobH
    I don't think it'll fit in the Cowl. The 450r wouldnt fit in my Sis-T cowl.
    See post 938 quoted below.
    ORIGINAL: Tom in Cincy
    I am going to install the 450r. I temporarily mounted it up on the fire wall with sheet metal screws. Its a bit too long for the cowl (less than 1/4 inch). The valve covers are hitting up front. So I can shorten the motorbox by.25'' or slide the gun cover forward a little, or add a ring around the front of the fuselage. It really is that close to fitting maybe 1/8'' off.
    It shouldn't be hard to shorten the motor box. The rocker covers could also be modified or eliminated ALA Moki.
    I'm also planning on running a 450R3, but on CDI ignition. It should make about 6HP on 15% nitro. running CDI @ 34* BTDC.
    C&H has a prototype single module/hall sensor CDI.
    250mm = 9 7/8" BTW, not 10". That 1/8" could make the difference. The FG 84 is 180 pots (same hieght as 150) on the 150 stroke (same as the FA450R3) crank/case. It is the same OA diameter as the FA450R3.
    Unless they lengthened the FA450R3 rods, it will be under 8:1 compression ratio. I don't see 5.7 HP from an 8:1 CR 84cc gasser.
    Now if the rods were 180 length in a 150 deck height case, that would be 12.77:1. My 12.77:1 CR FA180HC CDI engine is making 3.5 HP W/the 220 BB carb on 15%, 4 HP on 30% 8% lube glow fuel.
    An FA540R3 12.77 CR methanol burner on CDI would easily be making over 8HP.
    Club Saito #785 - FA91S, FA-115, FA150, FA180, FA180HC/BBC, FA200TI, FA300TTDP: All with CH Ignitions CDI/Glow fuel
    SIG BH #42
    - 1/3 Spacewalker, Rascal 110
    CUB BH #231 - Wings Maker 1/5 J-3 Cub
  2. #952
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My cheating rivits going on. Wish I would've had thee years ago..
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1841205   Click image for larger version.
ID:	1841206   Click image for larger version.
    "IF" I'd stop staring at them, I'd get more done to them.
    Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
  3. #953
    Fly4Real's Avatar
    Join Date
    Sep 2004
    Olathe, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Ram, Where did you get the cheatin' rivets? That looks incredibly handy!!
    www.BestPilots.Typepad.com
  4. #954
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Werk77.com. N8622T, squared me away with this site. Thanks again my friend! If it weren't for your positive "influence", I wouldn't have gone this far on the build.
  5. #955
    Join Date
    Oct 2003
    Lebanon OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been lurking on here for a few weeks now. I can't wait to get one of these and bash it up! I like to take all of your cool mods and I create a binder from which to work from.
    Now I just need my job to help out and not downsize so I have the funds for this bird.
    www.hobbiesxtreme.com
  6. #956
    Tommy_Gun's Avatar
    Join Date
    Apr 2004
    Ione, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Saito fg57t fits in cowl with room to spare!
ID:	1841268   Click image for larger version.
    It\'\'s called \"Warbird Racing\".
    So ask yourself, is that a warbird?
  7. #957
    dasintex's Avatar
    Join Date
    Sep 2004
    Displaced Canadian in Central Texas TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The question is if the not yet available Saito FG84 will fit?
    P-40 Brotherhood #3
    P-47 Brotherhood #32
    Spitfire Brotherhood #29
    Citabria/Decathlon Brotherhood #58
    Not so scale, Almost ready to fly, Soon to be scrap,
    Warbird Brotherhood #58
    Top Flite: GS P-40 & FW190, Great Planes:
    Super Skybolt and 30cc CITABRIA
    Hanger 9: Twist 60; Value Hobbies: Mini-Stik 25
    Future Project:Top Flite GS A6M ZERO
    RIP: H9 Spitfire & H9 P-47
  8. #958
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone sitting back installing a G-62 in this?
  9. #959
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dasintex
    That's already been established.
    FA450R3 fits therefore the FG84 being the same dimensional (in diameter) will also fit.
    Motor box must be set back by 1/4".
    SIG BH #42
  10. #960
    Tom in Cincy's Avatar
    Join Date
    May 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I made some additional measurements on the firewall fit for the Saito450r. It looks like moving the firewall back 1/2" - 7/16" will be required. I went ahead and cut the firewall out and cut the key slots back 1/2". I then tack CA'd the wall back in,mounted the engine, and the thrust washer now protrudes 1/8"-3/16" past the cowl. The valve covers now clear the cowl all the way around as well.
    If anyone is concerned about how well the factory glue job is, don't be. It took me close to 2 hours to get it out and cut the 5 slots. My usual trick of heating up a 1" putty knife with a propane torch and sliding it in there to melt the glue took forever. The glue does not melt, it burns!
    Indeed the 450/FG84 will fit but some surgery is required.
    \"Nosen Cessna 310 Club #10\"
  11. #961
    Chris Nicastro's Avatar
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Since the FG 57 fits so will the 300TDI if anyone wants one I have one listed to sell.
    Like a midget in a urinal I knew I had to stay on my toes...
  12. #962
    Join Date
    Jan 2013
    , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    lot of good work done here so far, watching this thread closely
  13. #963
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    More work. The rivits are cool but still very time consuming..
  14. #964
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Whats your plan with the rivets, primer/sanding/remove rivets? Or just leave them and paint over with primer and final paint?
    This is a pretty good approximation to full scale rivets but real rivets are sanded flush to the skin. (Yes, with exceptions) What you see on bare metal planes is the color difference between the metals. On painted planes you see more of an indentation and maybe the edge of the rivet. So in going with this technique I would go with sanding primer back down to the vinyl rivet and once exposed stop and paint color.
    Are you doing panel lines too? Same manner with line tape and sanding?
    Your going to have a pretty trick TF FW for sure, looking forward to the finished results!
  15. #965
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Chris, this will be one to add to the bunch . Many, many years back when I was new to detailing, I was given this information. It's very helpful! Also check out RCscalebuilder.com for more helpful detailing and building tips.
    http://www.tompierce.net/190/index.htm
  16. #966
    Fly4Real's Avatar
    Join Date
    Sep 2004
    Olathe, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tom Pierce's website was a revelation to me as well Ram. Really good info and ideas for detailing. That has been up for over 10 year now. Wow! Has it been that long??
  17. #967
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Chris Nicastro
    Hey Chris, here is my recommendation to you.... Zip lip, eyes open, pay attention... Now you will actually see the work in progress reach its final completionπŸ˜„. Trust me, Ram44 knows more about a FW190 in his little finger than most know in their whole body.😳
    "Go low if you wanna make a show"
    P-40 Brotherhood #49
    Jimmy
  18. #968
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah, that site was a asset among others. Thanks, I never go into details on my knowledge on the FW190 but some of this stuff just comes with the territory, especially since they’re the main plane I build. I try to venture out but the little swastikas running through my veins always bring me back; that and my fellow Luftwaffe building brethren. lol
  19. #969
    MX240's Avatar
    Join Date
    Nov 2003
    PoDunk City, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It took a good part of the afternoon to put in the standard non-retracting. I had been reading about how tight the Robart units is. I am sure mine wasn't as bad but it didn't fit as easy as the old Mustangs.
    I use a 4/40 wire down the left side to hook into a Great Planes nylon steering arm GPMQ4264. Have to drill a new hole closer to the center. I have very little trouble with this set-up.
    I don't think it looks too bad myself as it blends in nicely.
    Lots of help from "Fuzzy" the cat.
    Jim
ID:	1841560   Click image for larger version.
ID:	1841561   Click image for larger version.
  20. #970
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MX240
    Lots of help from ''Fuzzy'' the cat.
    Jim
    How about a picture of it retracted?
    SIG BH #42
  21. #971
    Tony Gag Jr.'s Avatar
    Join Date
    Jan 2002
    Terryville, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anybody had an issue with the black fiberglass exhaust parts having cracks? I recieved 2 planes from Tower and both had cracks. I sent the first one back and recieved my replacement today. The one I got today appears to have been repaired and painted. I am pretty surprised Tower sent me this one. I will call them in the morning so I can return this one. Hopefully the third one will be better. Here are a few pictures of the repair.
    Tony
ID:	1841578   Click image for larger version.
  22. #972
    Ramstein44's Avatar
    Join Date
    Nov 2007
    Aurora, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine wasn't cracked but it was seperated from the fuse where yours is cracked, aprox 1/16.
  23. #973
    Join Date
    May 2002
    Cincinnati, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No cracks here. Looks like they were pushed in. Like shipping damage. UPS dropped my first one so hard it cracked the tail off.
    Hopefully 3rd times a charm.
  24. #974
    sharam's Avatar
    Join Date
    Jul 2002
    SF Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys, my electric Robarts are very noisy, electrically speaking! When I retract or deploy on the bench, the aileron servos start jittering! The retracts have their own separate power supply so it must be the wires and their proximity. I need to add some donut filters and move some wires around.
    Anyone else have this problem?
    Trex 700 OS105 Vbar, Logo Xxtreme 800, Goblin 770
    TopFliteFW-190 DLE55, P-51 DA50, P-47 G-62
    CARF Tutor evojet160, CARF Hawk K-140
    CDF Huey Jakadofsky Turbine
  25. #975
    Join Date
    Jun 2004
    WILLIAMSTON, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is that with a 2.4 system?
    Semper Fi
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
