TF FW190 GIANT ARF
#1001
RE: TF FW190 GIANT ARF
Oh yeh, I forgot about wheel weights.
Most tire shops discard the old weights so you might score some of those for free!
I am so used to seeking pure lead for muzzleloaing bullets I forgot about wheel weights.
#1002
My Feedback: (23)
I installed the 3 battery packs (2 for receiver and one for retracts) in the "pockets" behind the shutters that lots of folks find were broken. Wrapped in foam they fit firmly in place.
First photo shows the weight box I made that holds the 14 ounces of lead shot and epoxy needed to balance the plane.
Second photo is me holding the plane on my fingertips and it balances fine with that 14 ounces of lead. (Sorry, timed photo, I was alone)
Photo 3 is sheet of screening glued to the cowl that I painted yellow and covers most of the engine cylinder. It may look better in the air.
BTW, for you folks that are mounting the cowl, be sure to add some epoxy or CA to those 6 blind nuts in the fuselage. Ihad 2 of then work free and the prongs were not bent. It looked like they were just pushed into the wood by hand.
#1004
That is where I am making my weight box as well. The fishing weights will fit nicely in there!
Pettit, nice clean job you did on yours! Thanks for the pic. I am surprised you only need 12 ozs. I am also using three batteries and I have put them where you did but I need 36 ounces.
Also, thanks for all the other great ideas. Ask and yee shall receive should be the motto of this forum!
#1015
My Feedback: (157)
I balanced a FW190 right side up once and when I took off, she handled fine until I retracted the gear changing the balance; then she was tail heavy! I believe this was due to the retracts forward rake which threw weight forward when down. This in my opinion would work for other warbirds but I wouldn’t do it on the 190.
#1016
My Feedback: (23)
The manual and the designer (David Johnson) recommends balancing the plane with the gear retracted and upside down.
When the gear is extended it gets a little nose heavy, which is a good thing on landing.
Alsdo, I under-estimated the amount of lead Iput under the engine box. It was more like 22 ounces. I initially was going to use 14 ounces but it balanced a bit "tail down" so I added another 8 ounces .
I forgot about that additional 8 ounces when I posted the weight needed to balance.
So, 22 ounces it is.
#1017
ORIGINAL: pettit
Alsdo, I under-estimated the amount of lead I put under the engine box. It was more like 22 ounces. I initially was going to use 14 ounces but it balanced a bit ''tail down'' so I added another 8 ounces .
#1018
My Feedback: (10)
ORIGINAL: tfarmer96
Mine ended up takeing 1 lbs and 10 oz. Shes ready for madien
#1020
ORIGINAL: dasintex
How did you go about adding your weight? did you balance yours inverted, gear retracted?
ORIGINAL: tfarmer96
I put 2 14/20 bolts into the bottom of the motor box. i also put some rtv on the box and the firewall. I balanced it upside down with the retracts retracted per the book. If Jimmy would get his finger out and finish that p47 and the weather would break we will be making the trip to Oklahoma City for a maiden weekend.
#1021
My Feedback: (10)
I'm guessing that's a Block of Lead, with the Bolts screwed through the inside of the Engine Mounting Box? Are you using a Pilot Figure that has contributed to the CG/Weight problem?
#1023
ORIGINAL: dasintex
#1024
My Feedback: (23)
Just a heads up about the removable top hatch. The plastic sheeting on it is VERY fragile and any rough handling, like trying to remove the hatch by pulling on the sides rather than in the center, will break the plastic.
Don't ask...
Ithen ordered a replacement hatch from Tower, It arrived today, packed in a cardboard box with a number of those plastic "air bags" protecting it. Too bad the SAMECORNER of the hatch that broke originally was hitting the cardboard and this one was broken too, in the exact same place!
Tower is sending me a third one and I recommended that they use bubble wrap and don't pack it too tightly.
Time will tell.....
Don't ask...
Time will tell.....
