Info on Midwest AT-6 Please
GA
I'm looking for some setup information on a Midwest Texan. I picked this plane up at the Southeastern Model Expo show back in 2006 or so and haven't really flown it yet. I made an attempt to fly it and I suspect the C.G., incidence and thrust are a bit off. I've got the construction manual which details the recommended control throws, but I don't have the plans and the C.G. and thrust line is documented on them. I contacted Midwest to see if I could order a set of the plans, but they've closed the plane division and don't have the plans available. I'd gladly pay to have a set copied if possible.
If you have a Texan, can you help me out?
Thanks!
Greg
Thanks!
Greg
RE: Info on Midwest AT-6 Please
Greg, if no one knows, you can use this website to get you started. Dan.
http://www.geistware.com/rcmodeling/cg_calc.htm#mac
