Maj. Woody's Top Flight Giant Corsair ARF
Reply
Old 11-19-2012, 05:20 PM
  #51
pacoflyer
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Maj. Woody's Top Flight Giant Corsair ARF
I'm still in the hunt for another TF P-47.
Probably will strip and glass like you did to yours and will stick with a DLE 55
paul
pacoflyer is offline
Old 11-19-2012, 05:28 PM
  #52
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Both of my DLE 55's have been very powerful and trouble free. Just an amazing engine.
Dom
MaJ. Woody is offline
Old 11-23-2012, 07:22 PM
  #53
willey
My Feedback: (32)
willey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: MaJ. Woody
23 three flights now as of today. The Corsair is a real stable platform and a great aerobatic Warbird. I think I have the landings figured out. Aprox 1/2 throttle on final, 1/4 throttle on short final and then 1/8 throttle just above the numbers and all the way to touch down which is not a wheel landing but not quite a 3 point either. When she is down you can pull all the power off. I have used this technique the last several landings with little to no bounce at all. The only frustrating thing has been that damn dummy radial. It is made of paper thin plastic and has required me to pull the cowl off after every flying session to repair it. I have used some glass cloth were applicable and now have the entire inside coated with a thin layer of goop which should hold everything together while providing some dampening to the vibration. I also swapped out the tail wheel with a 2'' Dubro solid rubber aluminum hub tail wheel. I drilled holes around the hub ti lighten it up but mostly to improve it's appearance. It is painted white and looks much better and does not go flat like the stock one.
Hey Woody! how you been, sounds like your havin fun... read'n your issue with the radial, you might want to build one over the winter, I will post pics of the radial I built/installed in my Byron Staggerwing soon so you can see, which is the way you probably want to mount in your corsair, this link though, will show you one I just finished for my waco sre, its mounted different then the staggerwing but give ya an idea what I'm talkin about, you could eliminate a few steps and they still look good, well.... hope to do some flying with you this coming summer, have great holidays, talk to you soon.
willey from erie
http://www.rcuniverse.com/forum/m_11..._1/key_/tm.htm
willey is offline
Old 11-24-2012, 02:46 AM
  #54
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Willey. If I have not sold the Corsair by then, we can fly at Octurbofest. They have opene3d that up to Giant Scale planes now.
Dom
Old 01-30-2013, 05:41 PM
  #55
BodiesByBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good . After reading through the thred it has helped me in figuring out how to set up the gear doors
BodiesByBean is offline
Old 01-30-2013, 05:49 PM
  #56
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. They function flawlessly. All door cylinders, fill valves and retract valves are BVM. I have no leaks in my system. Holds air for weeks and weeks at a time.
Old 01-30-2013, 06:50 PM
  #57
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dom/Major Woody;
Nice Corsair, I have a TF Giant P-40 Running a DLE55 and a JTEC P-40 Wrap Around Pitts Muffler which looks very similar to the one on your Corsair; a few P-40 people have had their JTEC P-40 Wrap Around Mufflers Crack and fall apart, I'm not saying this might happen to yours and I didn't want mine to meet a similar fate, so I made some Modifications to my Muffler to prevent any problems, may not have been needed, but better safe than sorry; I posted this for your consideration in case you have any problems with your Muffler or hear about others having similar problems.
The way I see it, when these engines run they naturally and normally vibrate and shake like crazy, and the one end of the Muffler needs to be supported, and the weld between the rectangular manifold and cylindrical Muffler should be braced for extra strength; if not, the vibration will be excessive on the unsupported end of the Muffler, and will cause the bolts to come loose and/or cause the welds to fail.
ID:	1846267   Click image for larger version
ID:	1846268   Click image for larger version
dasintex is offline
Old 01-31-2013, 03:10 AM
  #58
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow that looks really solid. Nice job and thanks for sharing!!
Dom
Old 03-02-2013, 05:09 AM
  #59
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This plane is still for sale. I will sell my entire R/C Estate which includes airplanes, radios, servos, hardware, field equipment, support equipment, chargers...basically anything and everything I have R/C related for one low price. Contact me for more details.
Dom
Old 04-03-2013, 09:25 AM
  #60
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This beautiful Corsair is still available for sale. Start off the new flying season with a Giant Scale Warbird!
See ad here:
http://www.rcuniverse.com/market/item.cfm?itemID=907786
Old 06-07-2013, 02:14 AM
  #61
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is hard to believe, but this beautiful Corsair is still available for sale. Turn key and ready for all your summer flying events!
See ad here:
Old 06-07-2013, 01:45 PM
  #62
smaze17
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dom if you change your mind about shipping I'll take it right now
S
smaze17 is online now
Old 06-24-2013, 04:38 AM
  #63
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Come get it this week!!
http://www.rcuniverse.com/market/item.cfm?itemID=922456
Dom
585-749-1252
Old 06-29-2013, 03:35 AM
  #64
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just made a remarkable discovery. My Corsair fits into the back of my wife's Pontiac Vibe! It was like it was made for it. Rear seats folded down, nose first, gear down. The cowl slides between the front seats and the main wheels pass past the rear seat backs on down onto the rear head rests. The wheels are locked in place so the Big Bird cant roll around. Plenty of clearance at the rear for the tail. Lots of room on the sides for my support gear. I may just need to keep this magnificent bird for when the R/C Flying bug strikes! I was planning to bring it to the RCCR fun fly today, but it is raining cats and dogs outside. I will try to snap a picture of the fit when the rain stops.
Old 06-29-2013, 03:53 AM
  #65
John Taylor
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dom, I'm surprised you did not check this out sooner. Glad you have a way to transport it. Hope to see you at the Rovers meet. John T.
John Taylor is offline
Old 06-29-2013, 03:56 AM
  #66
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi John.
The Sky Rovers meet is always one of my favorites but again I cant make it. It is always the same week as Oshkosh. Oshkosh is a must attend event for me.
Dom
Old 06-29-2013, 05:47 AM
  #67
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pics. Notice how the wheels are naturally chocked.
ID:	1896028   Click image for larger version
ID:	1896029   Click image for larger version
ID:	1896030   Click image for larger version
Old 06-29-2013, 05:49 AM
  #68
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Corsair looks great with the 3 bladed composite prop. A $100 prop!
ID:	1896032   Click image for larger version
ID:	1896033   Click image for larger version
Old 06-30-2013, 02:38 PM
  #69
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I brought the Corsair to the RCCR Fun Fly Today. 7 Perfect flights! This baby really rips. The guys were urging me all day long to reconsider selling it. They even threatened to post fictitious comments about how bad it flys. LOL. Gotta love them for wanting me to stay in the group. Truthfully, they were all very impressed with the flight qualities and reliability. I still have her in the classifieds, but really am reconsidering selling now that I know I have a way to transport the model. It would be hard to replace such a fine model.
Old 06-30-2013, 03:08 PM
  #70
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just make sure you drain all the gas out, seal the overflow line and put plastic under it or you'll be sleeping in the garage for a long time (either that or she will re-kit it!).
samparfitt is offline
Old 06-30-2013, 03:23 PM
  #71
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HA, LOL.
I think I left her car fume free but she just left in it. I am keeping my fingers crossed that I dont get balled out when she returns!!
Old 07-02-2013, 02:49 AM
  #72
MaJ. Woody
My Feedback: (26)
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I have decided to keep my Corsair
As soon as the RCU Classifieds starts working, I will remove the ad.
It is just too nice of a model to let go. I may be headed to Olean in a couple of weeks with it. That is always a good show.
Old 07-02-2013, 07:25 AM
  #73
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good for you. Now you don't have to suffer the "gee I wish I hadn't sold that plane" issue.
Besides Full scale is nice but RC is too
BobH is offline
Old 07-02-2013, 09:06 AM
  #74
f14tomcatfreak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
shes definitely a keeper .. great choice dom!
f14tomcatfreak is offline
Old 07-22-2013, 06:24 AM
  #75
sdcranford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for this thread. I am getting ready to place an order for this airplane/engine combo. I got excited when I came to the part of you selling it and was ready to drive to pick it up regardless of distance, if you ever change your mind I'll pay your asking price and drive the 16 hours to pick it up. Unless of course I've already ordered mine.
I did notice the Hangar 9 model is coming soon and it has some extras but I'm not sure it's worth the extra $250. Although the bomb/tank drop would be really neat to add to either model.
sdcranford is offline
