BALSAUSA NIEUPORT 28 1/3 SCALE
Reply
Old 09-13-2017, 06:19 AM
  #251
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing.
After the LE was secure, the 1/4" thick rib where the wires connect had to be re-glued. The broken 1/4"X1/2" balsa that spanned this rib was replaced with some basswood. That area was re-sheared and new sheeting added to the top and bottom of the wing.
With the structural repairs done, assembly is needed to insure alignment of all parts.
If the shop wasn't such a mess, I could assemble the plane in the shop but I'll have to wait until it stops raining for an outdoor assembly!
ID:	2231775   Click image for larger version
ID:	2231776   Click image for larger version
Name:	shop 2017 01.JPG
ID:	2231777   Click image for larger version
Name:	shop 2017 02.JPG
ID:	2231778   Click image for larger version
Name:	shop 2017 03.JPG
samparfitt is offline
Old 09-15-2017, 08:55 AM
  #252
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
'Hard part' is done!
While re-assembling the parts, I found the upper struts cross wires were bent with one broken. Some soldering and hand bending fixed those.
Next: cover and paint.
ID:	2232042   Click image for larger version
ID:	2232043   Click image for larger version
ID:	2232044   Click image for larger version
ID:	2232045   Click image for larger version
Old 09-15-2017, 11:38 AM
  #253
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its always great to see a WW1 bird being repaired, and not thrown out ! I have a 1/4 N28 to rebuild this winter, so seeing a 1/3 N28 on the repair is inspirational
I didn't make it to Owatonna this year ... but some of my friends did, and they had a great time as always. Sounds like it was WW1 heaven !
I think the reason for squared edges on trailing edges is it makes the air shear of the edge instead of rolling/wrapping around the curved trailing edge surface. Sort of like if you were jumping a bike of a ramp with a squared off top versus a rounded pile of dirt...I hope that makes sense !
foodstick is offline
Old 09-15-2017, 12:44 PM
  #254
R/C Art
My Feedback: (38)
R/C Art's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Sam,
Looks like you will be ready for next weekend, eh?
Art
R/C Art is offline
Old 09-16-2017, 07:18 AM
  #255
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sam,
Good job on the rebuild. She'll be as good as new and flying again.
BobH is online now
Old 09-20-2017, 11:13 AM
  #256
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Covering (solartex).
I was surprised that, not only did the new solartex stick to the existing painted covering, but the the heating iron also removed all the wrinkles in the old covering. This made the repair a lot easier, not having to remove all the existing solartex.
If I would have know this, I would have been a little more careful on how much material was cut back on the repairs.
ID:	2232907   Click image for larger version
ID:	2232908   Click image for larger version
ID:	2232909   Click image for larger version
ID:	2232910   Click image for larger version
Old 09-20-2017, 11:38 AM
  #257
R/C Art
My Feedback: (38)
R/C Art's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Solartex is good stuff! Next time you see my N-11, check it out a little closer. It has acquired several patches over the years.
See you at the GCRCC Dawn Patrol/Warbird event this weekend.
R/C Art is offline
Old 09-21-2017, 06:45 AM
  #258
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Painting:
What's the chance of a fairly large, dead limb falling down and hitting your wing: about 100% in my case. Fortunately, no damage, it hit the ground, first, and then fell on the wing.
With little over spray, only minimal masking was done for the bottom tan color.
Thick HD Behr 100% exterior acrylic paint was used, thinned down 50% with blue window washer using a 12 dollar harbor freight touch up gun.
After gun cleanup, I realized the top of the stab also needed painting.
And after another gun cleanup, I figured I might as well paint the entire bottom of the the one wing to give it a more uniform look!
ID:	2232984   Click image for larger version
ID:	2232985   Click image for larger version
ID:	2232986   Click image for larger version
ID:	2232987   Click image for larger version
ID:	2232988   Click image for larger version
Old 09-21-2017, 10:21 AM
  #259
samparfitt
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When it's 87 degrees outside in Ohio, one needs only wait 3 hours before masking off the previous paint application!
Applied the light green, dark green and brown.
Painting done.
ID:	2233019   Click image for larger version
ID:	2233020   Click image for larger version
Contact Us Archive Advertising Cookie Policy
