P-40 Brotherhood (All P-40's Welcome)
#276
My Feedback: (60)
RE: P-40 Brotherhood (All P-40's Welcome)
I know a about the skyshark close out sale. the camo one came in the day they shipped my green one. oh well may have to own both! LOL also, there is free shipping on the planes worth around $70.00.
#277
My Feedback: (60)
Hi Everyone, I am the newest member P510851. I have a question for you. I have a skyshark 82" p-40 and wanted a good retract for it so I ordered the Robart 150 rotating retracts. are they ok or are there problems with the fit?
Tony
Tony
#278
RBEAN.
So far so good.they are very light out of the box but of course by doing scale mods will add more weight but that hasnt upset it at all.i had a lot of problems finding a large size p40 in ozz and the cmpro was what i ended up with.its been a good airframe to try some scale mods on and is performing well.
cheers raaf #60
cheers raaf #60
#279
IL
Just a quick update guys, I started covering the fuselage on the P40 this week. Yea I'm doing the Flying Tigers theme but I like it. I hope to get more done this week when the rest of my covering gets here and then I'll start getting the radio equipment in her. Here's some pics, hope ya like...
#280
My Feedback: (14)
I'm really having issues with my engine. 6 flights and the last 3 have been dead stick. I made a bad decision to extend the gear instead of belly landing in some rough ground and knocked both gear out of the wing. No other damage and easily repairable. When the engine is running right the plane is a dream to fly.
#281
My Feedback: (12)
I feel your pain. I make the same mistake with my Kyosho P-40 on a dead stick. I was on downwind but I thought I had enough energy (speed and altitude) to make a turn for the runway. I extended the gear, initiated a bank and the airplane dropped like a rock. Didn't rip the gear out but bent both struts flat against the wing. If I would have kept the gear up everything would have been fine.
My problem with the engine (Saito 65) is that is was overheating inside the cowl.
#282
My Feedback: (22)
Been making some headway on the TF 1/7 electric conversion:
Here are the readings from my bench test:
Power 60:
15x7 3 blade Master Airscrew prop 6920 RPM at 36Amps at 22.2 volts
15x7 3 blade Master Airscrew prop 7700 RPM at 45Amps at 25.0 volts
14x9 3 blade Master Airscrew prop 7540 RPM at 43Amps at 23.0 volts
Power 90:
16x8 3 blade Master Airscrew prop 5950 RPM at 40Amps at 23.0 volts
16x10 3 blade Master Airscrew prop 5920 RPM at 37Amps at 23.0 volts
As a comparison, these are pushing the numbers I was getting with a DLE-20 gas.
My first flight was with a TF P-47 ARF at around 9 pounds with the Power 60 with the 15x7 3 blade Master Airscrew prop. Flight was clean with a scale speed, not overpowered, but not underpowered. The 14x9 should add some speed, but no flights with it yet.
We did decide to move up to the 90 combination for the TF 1/7 P-40 kit built which will be in the 12 pound range. Not airworthy yet, but getting closer.
Power 60:
Power 90:
#283
Oh but the DLEsounds so much better than hmmmmmmmmmmm real warbirds make noise, I can't imagine a real P-40passing by going hmmmmmmm I agree though electric power is impressive.
#284
At what point in the flight are you having engine quit? I had some issues with mine quiting only a couple of minutes into the flight and it turned out to be overheating. I added some baffling and it really helped.
#285
My Feedback: (14)
ORIGINAL: raptureboy
#286
That was going to be my next suggestion as Ihad a small piece of metel from the factory that got under the float needle and kept flooding the engine. Sounds like you have it down now.
#287
On the possible DLE 20 cooling problems, what I did was duct air from the scoop above the spinner to the area of the carb to prevent the carb getting too hot from the pitts muffler just under the carb and causing vapor lock. I used a flexable plastic tube. The air flow was from above the carb, down past the carb and then the muffler and out the rear of the cowling keeping the muffler heat away from the carb. It works, no problems even in the hottest weather at full power.
#290
I have two of these, a CMP, with an OS 160, 3 blade prop, mechanical retracts which are kinda flimsy. (I'll get a better pair at swap meets this winter, I hope), but it flies straight as an arrow, will do anything! Lands kinda hot, but it's a war bird! Second one is a VQ 60 size with a magnum 4 stroke, on board glow & mechanical retratcts.
Rotating retracts are hard to keep workin, especially when u land like I do!! I have tried the "cheap" ($10 -15, + shipping) oleo struts from ChinaProducts (bidPro), they help & hold up fair.. metric set screws won't stay tight, strip, loose out, etc. but the struts haven't bent yet at least. I mount all landing gear with nylon #6 screws so as to shear off & so far they have saved wing rebuild!!
#291
My Feedback: (22)
rebranger, Welcome to the Brotherhood #68
Welcome to the P-40 Brotherhood
P-40 Brotherhood
Master Roster
Started 8-31-2012
Updated: 12-06-2012
Brotherhood Update, we now have 68 in our squadron.
Welcome to the P-40 Brotherhood #
If you would like to join the P-40 Brotherhood please make your request on this thread and I will assign you a number.
Never can tell when you may run into another P-40 Brother somewhere, so join now.
1. Warbirdrcer OK, USA
1.5. Talimena Kidd OK, USA
2. Chad Veich AZ, USA
3. dasintex TX, USA
4. Meschmidt TX, USA
5. gaumflyer Gaum, USA
6. gaumflyer’s Dad Gaum, USA
7. tp777fo SC, USA
8. Dash7ATP VA, USA
9. 77chickenhawk CA, USA
10. ccostant MA, USA
11. Capt G NV, USA
12. RBean PA, USA
13. P-40 Driver TX, USA
14. LQUAN CA, USA
15. raptureboy PA, USA
16. SVX UT, USA
17. AmishWarlord NC, USA
18. Duplicator41 ID, USA
19. gregandhollie IN, USA
20. LDM PA, USA
21. spadsriver09 IN, USA
22. mobyal VA, USA
23. Ram-bro NE, USA
24. Lifer MO, USA
25. Peter OZ Queensland, Australia
26. tocstrum NJ, USA
27. Barron VA, USA
28. darren763 MN, USA
29. DrYankum NJ, USA
30. M Callahan OH, USA
31. gsmarino2000 CO, USA
32. Cpt Crash NM, USA
33. proffj550 NM, USA
34. psheffield AZ, USA
35. Quikturn IA, USA
36. trent smith Australia
37. wireman NJ, USA
38. jblloyd MS, USA
39. Dave Bugz U.K.
40. Ford34tom WA, USA
41. doolittles ME, USA
42. SPEED51J FL, USA
43. P-39 fan WI, USA
44. US185Damiani PA, USA
45. bookmaker FL, USA
46. 108buzz NJ, USA
47. Naval Flight Officer FL, USA
48. Super Chief GA, USA
49. n8622t AR, USA
50. jetster MI, USA
51. predman CA, USA
52. jet22b WA, USA
53. askham Dragor, Denmark
54. rppoind TX, USA
55. Antoinebobrob Beijing, China
56. NoFlaps KY, USA
57. yard-dart LA, USA
58. 2muchfun MO, USA
59. skull1971 TX, USA
60. raaf Adelaide, Australia
61. tardster IL, USA
62. mike early KY, USA
63. Hot Rod Todd IA, USA
64. Yogi CT, USA
65. Woody218-RCU ND, USA
66. RPRCBuilder OK, USA
67. p510851 NJ, USA
68. rebranger AL, USA
P-40 Brotherhood
Master Roster
Started 8-31-2012
Updated: 12-06-2012
3. dasintex TX, USA
7. tp777fo SC, USA
8. Dash7ATP VA, USA
11. Capt G NV, USA
12. RBean PA, USA
14. LQUAN CA, USA
16. SVX UT, USA
20. LDM PA, USA
22. mobyal VA, USA
23. Ram-bro NE, USA
24. Lifer MO, USA
27. Barron VA, USA
37. wireman NJ, USA
38. jblloyd MS, USA
39. Dave Bugz U.K.
46. 108buzz NJ, USA
49. n8622t AR, USA
50. jetster MI, USA
51. predman CA, USA
52. jet22b WA, USA
54. rppoind TX, USA
56. NoFlaps KY, USA
64. Yogi CT, USA
67. p510851 NJ, USA
#292
My Feedback: (22)
I have made more progress on the P-40 over the weekend and this evening.
During this electric conversion I attempted several powerplant mounting ideas, and after deciding on an engine box I returned to one of my previous plans to use standoffs.
Photo 1, 2, 3, and 4 show the remains of an engine box reduced to template wood for locating the engine mount bolt pattern and centering the spinner bulkhead.
Once the template position was confirmed as seen in Photo 4, I drilled the firewall for the standoff hardware as seen in Photo 5.
Photos 6 and 7 are the results of the above. I use large area washers on both sides of the firewall, and both sides if the engine mount’s ears to spread out the operational loads, all secured with self locking nuts on both sides of all mounting locations.
All totaled I have a lighter set-up and an adjustable mounting system for thrust.
Photos 8 and 9 is where I left off with some applied paint.
#293
Mike Early, I have a VQ P-40 electric conversion. What retracts did you believe were the best in your VQ pP-40's? Has anyone have any experience with Hobbyking 90 degree rotating rertacts with the 5mm dia wire strut? The mechanical retracts just have too much play inthem and are kinda a pain in the dupa to set up. I'm kinda partial to the new breed of electric retracts.
#296
My Feedback: (22)
Update on the E-Flight Power 60 1/7 TF P-40 electric conversion.
This plane started as a TF 1/7 Kit, but my friend and his son fly all electric, so we went with the Power 90.
Paint is going on the bird as you can see in the photos.
Does anyone know where I can purchase some 1/7 scale vinyl markings for the Flying Tigers scheme?
#297
ORIGINAL: P-39 fan
Mike Early, I have a VQ P-40 electric conversion. What retracts did you believe were the best in your VQ pP-40's? Has anyone have any experience with Hobbyking 90 degree rotating rertacts with the 5mm dia wire strut? The mechanical retracts just have too much play in them and are kinda a pain in the dupa to set up. I'm kinda partial to the new breed of electric retracts.
I used Century Jets in all my corsairs and p-40s because I have a few sets. I've had to learn how to tweak them and adjust them. I've also learned how to fly heavy warbirds on them. Obviously the future of retracts is electric. I have used retracts from hobbyking and hobbypartz with success. I will try the E-Flites rotating retracts one day and add some oleos, Eventually I expect them release a 60-120 size set of rotating retracts.
#298
ORIGINAL: WARBIRDRCER
Casey
#299
Steve;
Your P-40 is looking good!!! Now when you get it finish, I would be more than happy to take it off of your hands!!! But I know the answer to that!!!
Please keep the pictures coming.
Sonny
aka
jet22b
Sonny
aka
jet22b
#300
NY
Cool.. Here's mine.. Pica 1/5 G62 power RAAF scheme
http://www.youtube.com/watch?v=JLx6C...ature=g-user-u
