P-40 Brotherhood (All P-40's Welcome)
#1152
LDM there is a lot of it going around, we will all be back to scratch building soon.
It must be very hard for a manufacturer of kit or ARF to make money especially if your kit is very good quality. Just trying to keep prices down and know how many to produce, what people need etc. With big kits I'm surprised they don't make a batch to order, get so many pre-orders and then make them.
Not a business I would like to be in.
Smaller kits not so bad a they are not usually to the same standard, so cheaper to make bulk. Unfortunately we all want the most for our $$$$ so it pushes the market down, leaving cheap and very expensive with not much of a middle price.
#1154
I would love to go 4 stroke, with something like a Valach Motors 60cc or a Kolm EZ65. But then again, I may go on the side of a little cheaper like a Zenoah G62! But I definitely want to get something that can turn a 24" 3 blade.
#1158
#1159
My Feedback: (9)
I agree with the 85 as best option if your budget can swing it - I am turning a 22-10x3 Biela on a G-62 and while it does it with no issues the performance is minimal. Its on a heavy bomber & the G-62 is great nose weight but I dont see it spinning a 24". You can see the Biela 22-10x3 - G62 performance combination on my Stuka - https://www.youtube.com/watch?v=QaOCHl8ACFQ
As part of the continuing illness of scale, my eyes require the look of 3 blades when I fly regardless the sacrifice of performance.
#1162
I may end up ordering an engine a lot sooner than I had anticipated. Friday evening I mocked up some rough engines out of styrofoam blocks to see if they would fit under the cowling.
Kolm EZ65 mock up
Valach VM60S1 mock up
Kolm EZ65 mock up
#1164
My Feedback: (303)
I would go with a bigger KOLM! I am getting the IL-135 or the IL-150. I don't think you will be happy with the 65...
You are very wrong on the G62!! I have a G62 STOCK and I am running a 27x6 2-Blade on it!! Has MORE than enough power! I have it on a Balsa USA 1/3rd scale Sopwith.
#1165
#1166
My Feedback: (22)
Just looked up the Kolm EZ65 powerplant. I see the Yellow P-40 has a 86 inch wingspan and is said to come in around 27 pounds. Not sure what to compair the EZ65 to, but my Byron is 83 inch wing span, weights in at 28 pounds and flys well on my DA-50 with a 22x8 producing 26 pounds of thrust. The Byron pulls well, climbs well, and does great large scale loops. I did have to add 3 pounds of lead to the nose to balance her, so I guess a heaver (larger cc) engine could have been installed, but the 50cc is what I had.
Keep us up on the progress
If the EZ65 creates more power (Thrust) it should do well.
#1167
#1169
Hi,
Well, sadly I didn't get around to getting myself one before they were gone. I had one left and generally, I don't compete with my customers so Chicoflyer got it! I previously had a Y/A P-40 ARF and it was amazing. Sliding canopy, full rivets, etc. I had a G-62 on it and she ripped. Full right rudder on takeoff, but she was much faster than this TF. This one flies a little 'easier' but is more bouncy on the landings. It doesn't quite have the warbird feel of the Y/A, but she'll do now for the thrill.
#1171
My Feedback: (22)
P-40 Brotherhood
Master Roster
Started 8-31-2012
Updated: 11-04-2014
Brotherhood Update, we now have 127 in our squadron.
Welcome to the P-40 Brotherhood
127. YellowAircraft
If you would like to join the P-40 Brotherhood please make your request on this thread and I will assign you a number.
Never can tell when you may run into another P-40 Brother some where, so join now.
1. Warbirdrcer OK, USA
1.5. Talimena Kidd OK, USA
2. Chad Veich AZ, USA
3. dasintex TX, USA
4. Meschmidt TX, USA
5. gaumflyer Gaum, USA
6. gaumflyer’s Dad Gaum, USA
7. tp777fo SC, USA
8. Dash7ATP VA, USA
9. 77chickenhawk CA, USA
10. ccostant MA, USA
11. Capt G NV, USA
12. RBean PA, USA
13. P-40 Driver TX, USA
14. LQUAN CA, USA
15. raptureboy PA, USA
16. SVX UT, USA
17. AmishWarlord NC, USA
18. Duplicator41 ID, USA
19. gregandhollie IN, USA
20. LDM PA, USA
21. spadsriver09 IN, USA
22. mobyal VA, USA
23. Ram-bro NE, USA
24. Lifer MO, USA
25. Peter OZ Queensland, Australia
26. tocstrum NJ, USA
27. Barron VA, USA
28. darren763 MN, USA
29. DrYankum NJ, USA
30. M Callahan OH, USA
31. gsmarino2000 CO, USA
32. Cpt Crash NM, USA
33. proffj550 NM, USA
34. psheffield AZ, USA
35. Quikturn IA, USA
36. trent smith Australia
37. wireman NJ, USA
38. jblloyd MS, USA
39. Dave Bugz U.K.
40. Ford34tom WA, USA
41. doolittles ME, USA
42. SPEED51J FL, USA
43. P-39 fan WI, USA
44. US185Damiani PA, USA
45. bookmaker FL, USA
46. 108buzz NJ, USA
47. Naval Flight Officer FL, USA
48. Super Chief GA, USA
49. n8622t AR, USA
50. jetster MI, USA
51. predman CA, USA
52. jet22b WA, USA
53. askham Dragor, Denmark
54. rppoind TX, USA
55. Antoinebobrob Beijing, China
56. NoFlaps KY, USA
57. yard-dart LA, USA
58. 2muchfun MO, USA
59. skull1971 TX, USA
60. raaf Adelaide, Australia
61. tardster IL, USA
62. mike early KY, USA
63. Hot Rod Todd IA, USA
64. Yogi CT, USA
65. Woody218-RCU ND, USA
66. RPRCBuilder OK, USA
67. p510851 NJ, USA
68. rebranger AL, USA
69. DAKOTANOVASS ND, USA
70. lomcevac540T NC, USA
71. Texan2 TX, USA
72. Texan2’s Dad
73. Eray2012 KY, USA
74. Lormuhl WA, USA
75. Sonofasailor KY, USA
76. mpro326 GA, USA
77. Aluminum Overcast MI, USA
78. lrb75 VA, USA
79. bleinmiller KS, USA
80. bigtim CA, USA
81. blainer48 NE, USA
82. Corsair2013 UT, USA
83. top gun reed MO, USA
84. scale_sloper
85. CAPT. DAN IN, USA
86. gjhinshaw MO, USA
87. Need for Speed RCU IA, USA
88. Jaybird ME, USA
89. rcjake AZ, USA
90. RCGuy41 MD, USA
91. elmshoot IN, USA
92. Hawk131 CO, USA
93. dutchy50 Australia
94. Jinxx HI, USA
95. Jim Branaum TX, USA
96. 64helipilot UT, USA
97. hairy46 WY, USA
98. bsovermars Canada
99. peruse12 Australia
100. warbirdmustang KY, USA
101. rcmiker MI, USA
102. GIVdriver NE, USA
103. Fly2XS MN, USA
104. Cobra1 MD, USA
105. SWORDSN SC, USA
106. C.O. IL, USA
107. hsukaria MI, USA
108. draftman1 CA, USA
109. JRFan Canada
110. Warbirdbob FL, USA
111. Magnum RC OR, USA
112. dbsonic CA, USA
113. Avaiojet FL, USA
114. Lightning 759
115. kaikokid New Zealand
116. Matt Smailes
117. FlyingJ664
118. LordAndreas
119. aghost TX, USA
120. smurfjet NM, USA
121. magwie SC, USA
122. Packrat74 TX, USA
123. Simple CA, USA
124. clive NSW Australia
125. Kevin Perry Canada
126. dgiatr Greece
127. YellowAircraft CA, USA
Master Roster
Started 8-31-2012
Updated: 11-04-2014
127. YellowAircraft
3. dasintex TX, USA
7. tp777fo SC, USA
8. Dash7ATP VA, USA
11. Capt G NV, USA
12. RBean PA, USA
14. LQUAN CA, USA
16. SVX UT, USA
20. LDM PA, USA
22. mobyal VA, USA
23. Ram-bro NE, USA
24. Lifer MO, USA
27. Barron VA, USA
37. wireman NJ, USA
38. jblloyd MS, USA
39. Dave Bugz U.K.
46. 108buzz NJ, USA
49. n8622t AR, USA
50. jetster MI, USA
51. predman CA, USA
52. jet22b WA, USA
54. rppoind TX, USA
56. NoFlaps KY, USA
64. Yogi CT, USA
67. p510851 NJ, USA
71. Texan2 TX, USA
72. Texan2’s Dad
74. Lormuhl WA, USA
76. mpro326 GA, USA
78. lrb75 VA, USA
80. bigtim CA, USA
84. scale_sloper
88. Jaybird ME, USA
89. rcjake AZ, USA
90. RCGuy41 MD, USA
92. Hawk131 CO, USA
94. Jinxx HI, USA
97. hairy46 WY, USA
103. Fly2XS MN, USA
104. Cobra1 MD, USA
106. C.O. IL, USA
109. JRFan Canada
114. Lightning 759
116. Matt Smailes
117. FlyingJ664
118. LordAndreas
119. aghost TX, USA
121. magwie SC, USA
123. Simple CA, USA
126. dgiatr Greece
#1175
LDM,
Sure. It's a nifty little unit sold by Mile High RC. It doesn't come with instructions, so they say you should know your way around an engine. You need a 13mm long-reach socket and a gear puller. The unit comes with a replacement drive washer/thrust washer and a one-way sprocket that go on your crankshaft. The unit includes two sets of standoffs, the shorter of which go with the DLE 55. I bought the starter unit which negates the need for s speed control, and goes directly in between your receiver and your battery ( I used 3-cell lipo). The motor that comes with it is just a plain old Mabuchi-looking 480, but it's geared up to give you better than 100 starts per charge.
Makes it so much fun!
