P-40 Brotherhood (All P-40's Welcome)
#1476
LDM,, thank you for telling me about the fuselage.. I would like to go Gas but I know Glow is simpler and lighter, and a 4St use little fuel. and to add my other plane had a Magnum 180 4St and it really wasn't that messy, a Velocity Stack would help keep it cleaner. I found a Saito 100 for a good price, but then I looked at Saitos to get more info on the 100 and I saw their 115 and 125 use the same 91 Case, wow,, their 115 is looking good to me, I'm keeping my mind open..
Charley, the box and manual does not tell me what the plane should weigh for flight, and I have not weighed it, it's not together yet.. BTW, I have looked and looked and your link is the only thread i found on the VQ .60 size P-40..
something I have to comment on about these guys that put a 20cc Gas engine in their .60 size Warbirds is that they put these 16 inch diameter props on them, and that is much to large for the Scale of a plane with a span of only 62 inches, it's Ok on an Acrobatic Edge, but it seams to me even a 14 inch diameter prop would be long too on a 62" span Warbird, seams a 13 would be more scale
Jim
Jim
Last edited by the Wasp; 04-20-2017 at 07:40 PM. Reason: I am trying to find where to change the size of the letters
#1477
My Feedback: (14)
Jim
Jim
#1479
the Wasp, I installed a DLE 20 in a VQ P-40. I had moved the landing gear closer in to be more scale. It weighted 9 lbs with a 91 FS. With two 2200 ma Nimh batteries, total weight came out to 10.4 lbs. CG was 103 mm at the root. It had plenty of power, and flew a little "heavier" than with a 91 FS. It flew better than a kit built Top Flite P-40. No tendency to snap in tight turns or loops. Landing speed with flaps was reasonable. Had a set of original Lado electric retracts. I replaced the Nimh batteries with two 1,200 ma Life batteries. that got the weight down to 9.9 lbs. The plane had over 200 flights on it and was looking pretty rough. VQ covering does not hold up real well. During the winter of 2015 I recovered the leading edge of the wings, the elevators and rudder and top of fusilage in front of the canopy. About five flights later, had radio failure and lost the plane. It turned out it was the Futaba transmitter. I later discovered it would fail intermittently. It went in fairly level so even though the airframe was totaled, all the hardware survived and is now in a Top Flite 60 size P-40 ARF, which flies great.
#1480
Not sure how I stumbled onto this thread but I would like to join this brotherhood. I just picked up a 3/4 built TF giant P-40 model from a buddy which I am in the process of finishing.
Here it is just after adding the fuselage decals.
#1481
see my link, a bit much, but wouldn't it be cool in my VQ .60 size Warhawk !!
http://www.mecoa.com/hp/120/2209.htm
heirmeistr, very cool !!!
Jim
Jim
#1483
heirmeistr, I hate to show this to you, but read the 7th reply in the link, good luck, I hope you do not have to wait long !!
http://www.rcuniverse.com/forum/glow...-exhausts.html
Jim
Jim
#1488
Please add me to the P-40 Brotherhood. Been out of the hobby for the last 4 years because of a knee injury. Finally got it operated on 4-28-17. Plan on being able to get up and down again. Have a Top Flite Gold half built.
Leroy
Leroy
#1489
My Feedback: (14)
Keep a little power on during the approach, keep the nose of the plane level or even slightly down, use full flaps, and land on the main wheels first.
#1493
Rob pike
Does anyone know if Rob Pike (Final Touches) is back in business.
I am looking for some of his detail pieces for my Ziroli P40.
#1497
wow a very good flight, very cool with the clouds behind the plane, I love "big air" fling,
what brand is your plane, what size/wing span, and what size engine ???
mine is the VQ .60 size 62" span, same pain scheme as your, same tail, I want to buy the Saito 125 for it, but at around 10 pounds I don't think I could get the 125 to idle low enough with a 15 inch prop to keep the plane from rolling at idle, so I am thinking of the Saito 115 and turn a 14 inch prop
Jim
Jim
