If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 4 of 4 FirstFirst ... 234
Results 76 to 81 of 81
  1. #76
    rlemaster's Avatar
    Join Date
    Apr 2006
    Lakeland, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Finishing for a TF GS P-51D
    Hi Chris,
    Thanks for the tips. This was definitely not fish-eye. I've run into that some as well.
    I did put on a light coat first, but it is definitely possible that it went on and formed "droplets" instead of going on smooth.
    I can never seem to find that "mist" coat that people talk about. The the paint is pre-thinned, I'm wondering if maybe it was
    slightly too thick and perhaps it didn't flow out correctly for my wet coat. Of course, if the first part is true it would just
    expose that first coat's roughness. After the priming stage, I had the surface almost glass smooth so I know it isn't that.
    I've uploaded a couple of pictures to show you what I'm getting.
    Leroy, thanks for the tip. I went with a "cheaper" choice. However, these were only for small graphics and lettering. I'm going to do the big graphics with paint.
    Russ
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1814014   Click image for larger version.
  2. #77
    Chris Nicastro's Avatar
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thats a paint and set up problem. It may be too thick or you can up the pressure to 45psi. It looks like its shot at a low pressure and its too thick.
    Up the pressure and test it. If not then use 40psi and thin it a little more then test it again. It should spray on thin and wet and when you over lap each pass they should blend nicely.
    This one shot like it was wall texture! Lol
    What paint system is it?
    Can post photos of the containers?
    Like a midget in a urinal I knew I had to stay on my toes...
  3. #78
    rlemaster's Avatar
    Join Date
    Apr 2006
    Lakeland, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Chris,
    If I fail at this, I could always go into ceiling texturing business.
    I did pump up the pressure tonight and it is better. I had to mix up a lighter color than what these pictures show so I
    lightly sanded to get some of that texture out and resprayed. I do think the paint is slightly too thick so when I spray
    the top I'll thin it a bit. The leading edge is where it shows the most on this run and there was still a little bit of
    texture there that I wasn't able to sand out. I think the leading edge issue is because I'm being overly cautious not
    to cause runs. Another thing I noticed was that the rivet indentions where I popped the vinyl out left some
    adhesive residue. I thought I had gotten all of this out with goo-gone, but obviously not. As you can see it caused
    some of them to not be as clean as I would have liked. Live and learn huh
    I'm enclosing a picture of the paint I'm using. I had to mix it of course since they only sell
    primary colors, black, white and metalic. This is paint that I bought from AutoZone (it's about $25.00 per quart,
    not sure if it is worth that or not).
    Thanks for all the tips. Hopefully I'll have better luck when I spray the top of the wing.
    Russ
ID:	1814050   Click image for larger version.
ID:	1814051   Click image for larger version.
  4. #79
    rlemaster's Avatar
    Join Date
    Apr 2006
    Lakeland, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got the top done. I thinned the paint a bit (probably need to thin even more) and raised the pressure to roughly 40psi.
    This did help. It isn't perfect by any means, but practice makes perfect.
    Here are some pics of some of the detail stuff and the same corner that showed lots of orange peel for the first spray.
    Yes, you do see a small amount of metalic in there. The raised details were done with cut out vinyl and it turned out
    ok except that the scale is larger than I'd like.
    Russ
ID:	1814056   Click image for larger version.
ID:	1814057   Click image for larger version.
ID:	1814058   Click image for larger version.
ID:	1814059   Click image for larger version.
  5. #80
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: frets24
    Leroy, could you check that vendor for dry transfers; Aerotech.com is an industrial staffing company. Did you mean Aeroloft.com? That's where I have had mine from in the past, though Cindy doesn't ring a bell...Can't remember the young lady's name that I spoke to[&:]
    Sorry, it's www.aeroloft.com
    Here is some stuff that may help someone doing graphics placement.
ID:	1814161   Click image for larger version.
ID:	1814162   Click image for larger version.
ID:	1814163   Click image for larger version.
ID:	1814164   Click image for larger version.
  6. #81
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thats looking much better. I suggest trying one small batch at a higher reduction and see how it behaves so you know what to expect. So far the details look great and your not blowing them out with too much paint so just keep going.
    On the fuel cap, if your not already planning to do something, I suggest you use a circle template and a scribe tool to scribe a circle part line around the cap. That and the spot of red paint with the decal will make that detail pop.
    The next time you try to make the raised rivets, like your saying they look too big, you can make them smaller in anticipation of the paint thickness and visual effect. You dont need to make the part to perfect scale what your looking for is the suggestion the detail is there and its accurate. It doesnt stop with just cutting the vinyl, thats just part of the path to the finished effect. But now you know and next time it will be spot on.
    Keep it going you have the momentum now!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
