Reload this Page >
ESM BF-110C ZERSTORER 95" TWIN
Old 08-17-2013, 06:35 AM
  #76
rcwarbirdbuilder
My Feedback: (104)
rcwarbirdbuilder's Avatar
I was on ebay last night looking at engines, found only one DLE 30cc, but lot of listings for a AGM 30cc. it looks like the DLE with the Name changed on it. Ordered two of them, so I took down the for sale add for the 110 and placed the RGC 26 on ebay, got two bids on it now at $22.
Old 11-11-2013, 10:44 AM
  #77
ilmiglia
ilmiglia's Avatar
Hi Kahloq, I'm building the 110 electric, this is my setup
Hacker A60 - 22S x 2
ESC Fullpower 90 Amp HV X2
Prop 17,9 x 11 3 blade varioprop X2
Batt Fullpower 8S 5000 40C X2
Custom Sierra Air retracts
What you think ?
Also I plan to position the batteries in front of the fuse and the esc in the engine nacelles but I' worry about the lenght of the cables from the batt to the esc. Any suggestions.
Last, I read on various forums about the CG position and distances very differents. I'm bit confused now. I'm sure that the trick to have a good flying 110 is the correct CG.
Can you help me?
Thank you
Old 11-12-2013, 07:54 AM
  #78
kahloq
kahloq's Avatar
Sent you answer via PM
Old 11-20-2013, 04:06 PM
  #79
ilmiglia
ilmiglia's Avatar
Ciao Kahloq, the bf110 is my first twin and I'm not sure how to connect the 2 engines on the radio. I'm using an MX22 HOTT with 12 ch rx , do I have to use 2 separate channel or an Y will be enought ? The cables ( 6mm) that run from the ESC in the nacelles to the batteries in the nose are 29" long, what do you think?
Old 11-20-2013, 04:20 PM
  #80
JL1
My Feedback: (93)
If you have the channels then I would use one channel for each so you can make individual adjustments to sync the engines. If not, then a Y will work ok and you can make adjustments mechanically
Old 12-31-2013, 04:07 AM
  #81
dgiatr
dgiatr's Avatar
http://www.youtube.com/watch?v=YtpPh2o7DcY&feature=c4-overview&list=UU2ze-WlF_-nrFLhgNo57dSw
Old 12-31-2013, 11:19 AM
  #82
TA152
Bf110 cockpit video
http://www.youtube.com/watch?v=q6O1W...YNdMGVCcIZzAFw
Old 02-05-2014, 04:54 AM
  #83
wernerfischer
Smile
does anybody can help me where to get a BF 110 ESM canopy to buy to replacement mine that is broken? i have already contacted everybody around the world and no way.......... please i would like help from someone.......thanks
Old 03-10-2014, 09:56 PM
  #84
ptdan
Hi Wernerfischer
Have you tried Bigplanes.nl??? They have some in stock
Regards Dan
Old 03-10-2014, 10:11 PM
  #85
TA152
Originally Posted by ptdan
Hi Wernerfischer
Regards Dan
Nope. Btw, I have waited nearly two years for a new canopy here in Norway. It was broken on both my kits when I opened the boxes
Old 03-11-2014, 07:25 AM
  #86
alanc
and thats why i will not buy any more artf models of any sort, all spares back up is minimal, or nil, and i used to sell esm models!!!!
Old 03-11-2014, 09:14 AM
  #87
ptdan
Same here, had to glue mine.. Got a new one from bigplanes, but it was broken too. Esm canopys are a little fragile
Old 03-11-2014, 09:15 AM
  #88
Mpizpilot
My Feedback: (45)
Wow, thats a serious turn in outlooks.
Old 03-11-2014, 09:19 AM
  #89
alanc
ive got Wilson, of YT looking for you, fingers crossed
Old 03-16-2014, 02:54 AM
  #90
ptdan
Hi
I am about to maiden my BF 110, have 2 20 dle engines. Sounds great But the correct cg???? 140mm???
Regards Dan
Old 03-16-2014, 03:30 AM
  #91
TA152
I used the CG from the manual.
Old 03-16-2014, 04:25 AM
  #92
ptdan
Thanks or tak hr, good sunday
Old 03-16-2014, 04:43 AM
  #93
kwik
kwik's Avatar
I see that VQ Warbirds has Ty Browns excellent canopies and cockpit kits. But the 110 canopy is missing in the inventory.
That is really too bad, since almost everyone buying the 110 will need a replacement. Ty, where are you?
I think it would need to be in 2 or perhaps even 3 pieces. If the gunner-part was in one piece, it would be easier to make the gunners part open-close.
Old 03-16-2014, 05:11 AM
  #94
70 ragtop
My Feedback: (24)
I agree on Ty, could also try Firepower. The 110 isn't listed yet, but checkout the note on the ESM canopy page concerning if someone with an undamaged, untrimmed canopy would let them borrow it to make a plug....
Not sure if Ty does the same thing, but worth dropping both of them a line
http://tysplanes.com/
http://firepowerrc.com/ESM%20Canopies.htm
Old 03-16-2014, 05:53 AM
  #95
TA152
Bare hyggelig
Old 07-28-2014, 06:24 PM
  #96
rcwarbirdbuilder
My Feedback: (104)
I thought I would never get back working on my 110, looked like rain today and the weather was cool so I figure I would go outside in the yard and try starting the engines. This is the 3rd and final set of engines I am going to install on this plane, settled for a pair of AGM 30cc gassers. Reason I put off getting back to work on this plane was the AGM engines have a carb linkage set up which I find difficult to work with. I took the carbs off and ordered a pair of DLE carbs they have the linkage more in line with what I am use to working with, the levers are workable and easier to attach to the throttle linkage. I have the choke hooked to wire which will come through the bottom of the cowl.
As it turned out these engines both started on the first try, closed the choke and turned it over with a starter, it poped so I opened the choke and turned it over again and it started immediately. for new engines they idled and ran decent on the first try.
Name:	ELMHURST 7-5-2014 001.jpg
ID:	2018173   Click image for larger version
Name:	ELMHURST 7-5-2014 002.jpg
Old 07-28-2014, 07:12 PM
  #97
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
Wow! 30cc twin.. My "destroyer" was too fast w/ DLE20's. your plane is seriously way overpowered... I applaud you, sir!!! Way to go!!! I've been missing mine since it's demise and I very much wanted a twin again... I bought the DC-3 but it's still sitting on a shelf in the "man-cave" since it doesn't do anything for me... The BF-110 is my all time favorite!
Old 07-29-2014, 04:18 AM
  #98
wernerfischer
dear friends i have got a canopy to my BF 110 ESM in this store:
http://www.arfpros.com/
Ms. Robin Shapiro is the owner, fantastic store, it has arrived totaly new and very well packaged, it's worthwhile to buy there! Hugs! werner
Old 07-29-2014, 06:34 AM
  #99
rcwarbirdbuilder
My Feedback: (104)
I am back on the VQ site thinking of buying the Val and keeping the cost down by taking one of the AGM 30cc from the 110 to fly in the Val but that seems like lot of work, gotta think on this a little more before I do it.
Old 07-29-2014, 06:38 AM
  #100
rcwarbirdbuilder
My Feedback: (104)
I know the feeling.."almost ready to fly, soon to be scrap, warbird brotherhood"... I bumped the rudder on the 110 or the kids knocked the fuselage over and stripped the rudder servo, got another I am waiting on from Tower Hobbies, I may get to fly it this weekend if The servos arrives and I get it swapped out..
Here is the flight video on YouTube from the last flight before the current engine change out, video by club member Rick Reynolds.
https://www.youtube.com/watch?v=Gmj09-wvql4
