Reload this Page >
SPITFIRE MK9 Composite ARF
Old 10-07-2012, 07:08 AM
dany golan
dany golan's Avatar
Default RE: SPITFIRE MK9 Composite ARF
Thanks Roy
The dimensions of the exhaust stacs are:
Total length of each exhaust 50 mm
Exit opening length 30 mm
Exit opening width 10 mm
Old 10-07-2012, 07:28 AM
dany golan
dany golan's Avatar
ORIGINAL: Rebel Flyer
Nice looking Mark... I do have a few questions.
1. How far back did you have to move the engine back?
2. How much weight did you have to add up front?
3. What equipment, if any did you have aft of the cg?
4. Are you using the small inboard flaps that you have to cut out?
I want to do the same mark and I also have a DA85 with the Slimline muffler. I also have a Quadra 100 and have not decided which motor to go with.
The Quadra is about 10 pounds too.
Thanks for the input. Rebel
Thanks Rebel
We installed the engine directly to the firewall . We had to cut the lower part to allow the installation of exhaust. By the way, the Slimline exhaust is very wide and touches the cowl sides.Therefore, we had to push the cowl sides out about 3 mm on both sides.
We added about 3 kg in the nose above the engine
We installed the tail landing gear, ruder end elevator servos + the reciver behind the cockpit.
Yes, we use the inboard flaps. We conected them to the main with guid pin like the full size plane
Old 10-07-2012, 07:34 AM
dany golan
dany golan's Avatar
Building the instrument panel
ID:	1808798   Click image for larger version
ID:	1808799   Click image for larger version
ID:	1808800   Click image for larger version
ID:	1808801   Click image for larger version
ID:	1808802   Click image for larger version
ID:	1808803   Click image for larger version
ID:	1808804   Click image for larger version
ID:	1808806   Click image for larger version
Old 10-07-2012, 07:36 AM
dany golan
dany golan's Avatar
Building the Chassis control
ID:	1808810   Click image for larger version
ID:	1808811   Click image for larger version
ID:	1808812   Click image for larger version
ID:	1808813   Click image for larger version
Old 10-07-2012, 07:38 AM
dany golan
dany golan's Avatar
Building the Throttle quadrant
ID:	1808815   Click image for larger version
ID:	1808816   Click image for larger version
ID:	1808817   Click image for larger version
Old 10-07-2012, 07:40 AM
  #31
dany golan
dany golan's Avatar
The cockpit is now assembled including all scale details
ID:	1808819   Click image for larger version
ID:	1808820   Click image for larger version
ID:	1808821   Click image for larger version
ID:	1808822   Click image for larger version
ID:	1808823   Click image for larger version
ID:	1808824   Click image for larger version
Old 10-07-2012, 07:43 AM
  #32
dany golan
dany golan's Avatar
Building the cannons and machine guns
ID:	1808826   Click image for larger version
ID:	1808827   Click image for larger version
ID:	1808828   Click image for larger version
ID:	1808829   Click image for larger version
ID:	1808830   Click image for larger version
Old 10-07-2012, 07:45 AM
  #33
dany golan
dany golan's Avatar
Operational navigation lights
ID:	1808832   Click image for larger version
ID:	1808833   Click image for larger version
ID:	1808834   Click image for larger version
Old 10-07-2012, 07:52 AM
  #34
dany golan
dany golan's Avatar
Building the radiators
we modified the original radiators cowls edding the flaps and radiators screens. We used car air condition radiator screen. we cut parts of it and intalled in the cowls
ID:	1808838   Click image for larger version
ID:	1808839   Click image for larger version
Old 10-07-2012, 07:54 AM
  #35
dany golan
dany golan's Avatar
Assembly and installation of the systems and components such as: Receiver and electrical system, servo and flight control systems, Landing gear air system, fuel system, Ignition system, Chock system (servo operated), switches and more....
ID:	1808841   Click image for larger version
Old 10-07-2012, 07:56 AM
  #36
dany golan
dany golan's Avatar
Painting process and marking
We used Hambrol modeling paint and finished with 50% mat transparent lacquer
ID:	1808843   Click image for larger version
ID:	1808844   Click image for larger version
ID:	1808845   Click image for larger version
ID:	1808846   Click image for larger version
ID:	1808847   Click image for larger version
ID:	1808848   Click image for larger version
ID:	1808849   Click image for larger version
ID:	1808851   Click image for larger version
ID:	1808852   Click image for larger version
ID:	1808853   Click image for larger version
Old 10-07-2012, 07:59 AM
  #37
dany golan
dany golan's Avatar
And finally the Meiden with the controls in Avi Sirota`s good hands
ID:	1808855   Click image for larger version
ID:	1808856   Click image for larger version
ID:	1808857   Click image for larger version
ID:	1808858   Click image for larger version
ID:	1808859   Click image for larger version
ID:	1808860   Click image for larger version
ID:	1808861   Click image for larger version
Old 10-07-2012, 10:23 AM
  #38
nudger
Hi dany golan
Just like to say some of the best modelling work I've seen,and that cockpit is a work of art.
Excellent. Nudge
Old 10-07-2012, 12:10 PM
  #39
rcguy59
My Feedback: (8)
rcguy59's Avatar
WOW!!! Fantastic work. You've done it justice and then some.
Old 10-07-2012, 04:27 PM
  #40
roydefiant
amazing, thanks for measurements
Old 10-07-2012, 05:50 PM
  #41
kwblake
Unbelievable craftsmanship. I have to tell you, that when I first looked at the photos of your plane, I thought " why would they be posting photos of the restored aircraft?" The top far right photo must be of the real thing. You gentlemen are true master craftsmen.
You should all be very proud!
Old 10-07-2012, 06:19 PM
  #42
kwblake
Oops. I misread your original post. I thought this was a build by your club. Two of you? Unreal !!
Old 10-07-2012, 06:54 PM
  #43
FireBee
My Feedback: (34)
Dany, Avi,
You have completely mastered this Spitfire. Every detail is incredible and as a whole she is truly an awesome airplane. Looks great from every angle in the air or the ground shots.
I volunteer at the museum where the restored aircraft is flown quite regularly. Here is the link
http://www.militaryaviationmuseum.org./
Along the back wall of the hanger is a picture when she was found in a school yard in your country. The restoration and your replication is perfect . . As I'm sure the pilot is just out for afternoon tea!
Regards, Mike
Old 10-07-2012, 06:58 PM
  #44
FireBee
My Feedback: (34)
You need to post some thoughts and pics on the RCU thread. "Spitfire Brotherhood". Such a plane should be seen by all.
R, Mike
Spitfire Brotherhood #8.
Old 10-07-2012, 08:10 PM
  #45
fw190
My Feedback: (37)
Amazing work! Thanks for sharing
Old 10-08-2012, 01:30 AM
  #46
verbails
Hi Mr Golan
Your work and that of your friend is awesome. I work on a airfield with several Spitfires and I can confirm you cockpit it bang on accurate now if you only had a 14 inch tall person you could ditch your transmitter.
Chris
Old 10-08-2012, 04:33 AM
  #47
avi sirota
Hello all,
Thanks for the kind words and compliments. This project was interesting in doing both the background investigation as well as the scale detailing and flying.
Working with Dany is challenging because everything must be accurate and more then that-unique. Other then the nuts and bolts almost everything was made by hand out of everyday items such as wood plastic or any other "junk" in the workroom. You can only imagine how many times we called each other in strange hours of the day (and night) saying: hey! I've got an idea how to make the panel\guns\flaps and so on…
On the other hand we followed the KIS rule: keep it simple .
Part of my job in this project was to install the radio and power equipment without violating the cockpit. I had many nights spent routing and modifying the entire plane just to go around the cockpit. Looking at the entire plane one can find a new item every time even after hundreds of hours with it.
Thank you for spending the time to follow our project.
Avi
Old 10-08-2012, 04:54 AM
  #48
flyingchef
My Feedback: (93)
flyingchef's Avatar
Beautiful work!
You mentioned that 3Kg (6.6lb) of nose weight was added, what is the plane total weight?
If you make a trip to Denver, bring your Spitfire, I would love to fly mine and yours in formation!
Great Job again!
Old 10-09-2012, 12:58 PM
  #49
dany golan
dany golan's Avatar
Thanks everyone for your kind words.
Bruno,
The overall weight of the aircraft is 18 kg (39.6 lb)
The model flys Great
We would love to fly together with you, but we are located on the other side of the globe .....
Old 12-11-2012, 01:31 AM
  #50
dany golan
dany golan's Avatar
Hello everyone
Here's some pictures and video from the annual meeting of the Israeli Scale club that took place last weekend at Ketziot in southern Israel
The Spitfire is flown by Avi Sirota
http://www.youtube.com/watch?v=GXlWF...ature=youtu.be
ID:	1828800   Click image for larger version
ID:	1828801   Click image for larger version
ID:	1828802   Click image for larger version
ID:	1828803   Click image for larger version
ID:	1828804   Click image for larger version
ID:	1828805   Click image for larger version
ID:	1828806   Click image for larger version
