If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 26 to 50 of 168
  1. #26
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ECOMRC Fokker D-VII
    Here are a few pic's of the servo mount and the wing supports.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1815883   Click image for larger version.
ID:	1815884   Click image for larger version.
    Jim Stanton
    Millington, TN 38053
  2. #27
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now that I know the upload of pic's can be done I'll upload some more tongiht. I have the tail secton done and the DLE-30 mounted. The lower wing is installed and I fiberglasses the engine compart area both front and back of the fire wall. The firewall was to small according to the instructions for the DLE-30 so I re-enforced it with firberglass.
    Jim Stanton
  3. #28
    kahloq's Avatar
    Join Date
    Jan 2006
    Fort Collins, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice size. I have the H9 Fokker DVII thats a slight bit smaller. Overall, the assembly looks almost identical...especially up front, but the H9 is 64.6" wingspan. That extra 4.4" will give this ECOM one a decent presence.
  4. #29
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are a few pics of my progress so far. The DLE-30 was a little wide with the stock muffler so I ordered the JTEC narrow muffler for this engine. I still had to grind out a small area on the fuselage for the muffler bolt on the engine to get it to fit.[:@]
ID:	1816180   Click image for larger version.
ID:	1816181   Click image for larger version.
ID:	1816182   Click image for larger version.
ID:	1816183   Click image for larger version.
ID:	1816185   Click image for larger version.
    Jim Stanton
  5. #30
    Join Date
    Aug 2002
    WATERFORD, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks good
  6. #31
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Last night I finished connecting the fuel tank to the DLE-30 and the elevator & Rudders are now complete. I hope to start on the upper wing assembly tonight. I think that may take a couplt of evenings so I can get it right I'll post some more pic's when I have the upper wing installed.
    Jim Stanton
  7. #32
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I got the top wing installed and boy was it a job. Trying to get the right incedance with the supplied wing structs was harder than it looked[:'(] But I got the job done. I also installed the guns and the pilot. Here are a few pic's
ID:	1817694   Click image for larger version.
ID:	1817695   Click image for larger version.
ID:	1817696   Click image for larger version.
ID:	1817697   Click image for larger version.
    Jim Stanton
  8. #33
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I Finished the ECOMRC Fokker D-VII. This is an ARF that you will need to do some modes yourself to get it to be a strong airframe. Check all of the glue joints. I had to add 6oz of weight to the engine cowl to get it to balance at the CG point of 4 1/2". [:@] That is even with a DLE-30 in it for power. Here are a few pics of the finished D-VII.
ID:	1818847   Click image for larger version.
ID:	1818848   Click image for larger version.
    Jim Stanton
  9. #34
    I received mine, it is very nice. Have mot started on it yet.
  10. #35
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I flew mine last weekend and almost lost it. The CG is wrong and the plane flew like it was very tail heavy. I got it back on the ground with mine damage. Make sure your CG is closer to 100mm and not 114mm. The wing between the wheels needs to be at the same incidence and the lower wing on the body which is 0 degrees. Mine was positive when I flew it and with the CG being off the plane was almost out of control.[:@]
    Jim Stanton
  11. #36
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hard to tell from the manual and mine isn't here yet. Is it two aileron servos or 4?
    Also, what size wheels are they?
    I've got a 33GT coming as well for it.
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  12. #37
    vertical grimmace's Avatar
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Fokker DVII only has 2 ailerons. I am sure 2 servos is all that is needed. I have 2 on my quarter scale.
    Let's just say, they will be satisfied with less. " Ming the Merciless
    BUSA Bro # 13
  13. #38
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh duh! First WWI model!
    I'll go back in my corner.
    FWIW the manual says 8 servos, I was like whoaa...
    www.JaxRC.com
  14. #39
    _Tommy D's Avatar
    Join Date
    Feb 2004
    East Islip, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Any more flying reports?
    http://tommydsblog.blogspot.com/
  15. #40
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I flew it last Saturday and with the CG at 114mm (4 1/2") the plane was tail heavy. I was told this plane flys very well if the CG is at 100mm (4") I have added about 1lb of weight to the nose of the plane trying to get the CG at 100mm and I think I have it there now. I will give another flight report once I can get back to the field. I am agraid with the Holidays coming up and weather it may be a few weeks.[:'(]
    Jim Stanton
  16. #41
    I am a little frustrated with mine. Lots of mods needed at evry step, poor hardware. I would swear this was made by ESM! Same hardware and small issues at every step. I can't help but feel that we are the guinea pigs, that is was not built and tested before being sold. It will be alright in the end, I think, and I think the price is ok for what it is.
  17. #42
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Datavision,
    Do not use the CG in the instructions. [:'(] I installed a DLE-30 in mine and still had to add 6 oz of weight to the nose to get the CG at 146mm(5.25") I almost lost it on the maiden flight. [:@] I added another 16oz of weight to the nose to get the cg at 114mm(4.5") and the plane was still tail heavy in flight. I got a post from a gut in Euorpe and he said the plane flys very well if the CG is at 100mm(4"). I am wooking on trying to get the CG at 100mm and do another flight.
    Jim Stanton
  18. #43
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My kit is here, I'm waiting on the engine.
    I talked to my buddy Alex at IFlyTailies and might get one of his instrument sets for it.
    Setup so far..
    OS33GT for power
    JR 921 DSMX with my 11x
    Savox digital servos
    www.JaxRC.com
  19. #44
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sounds likea very nice setup. Lets see some pic's as you put her together. Remember the CG issue in you build.
    Jim Stanton
  20. #45
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea, I'm glad you gave me a heads up on the CG.
    Don't worry, there will be pictures. I'm also probably going to shoot some video with my Go-Pro mounted in the cockpit.
    www.JaxRC.com
  21. #46
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now that really sounds awesome. I will be looking forward to see that video.
    Jim Stanton
  22. #47
    Join Date
    Jan 2010
    Bryan, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    are the wings flat with no dihedral? i'd consider making some thinner looking n-braces for the wings. can the engine not be installed upright?
  23. #48
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A scale Fokker wing has thinner airfoils as you proceed to the tip. Like a tapered wing, only this is a rectangular platform. The top of the wing is flat, creating slight dihedral in both the top and bottom wings. This is one of the most interesting aspects of the Fokker DVII and is one of the reasons it flies like it does. This creates a sort of washout as well.
    I was wondering the same thing about the engine. Not only do these things like to nose over, it would be hard on plug caps inverted. Not to mention an upright install would just look better.
    BUSA Bro # 13
  24. #49
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I installed a DLE-30 that was recommended by Troy built hobbies where I bought it from. If you install the DLE-30 up right you will have to cut open the top of the cowl to make room for the spark plug and ignition cable. I thought that would just look to funny. Remember this is not a 1/4 scale plane and is smaller than the Balsa USA 1/4 scale Fokker.
    Jim Stanton
  25. #50
    Join Date
    Aug 2002
    The Colony, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the information. I just got mine for christmas. Will be installing the dle35 for power and changing out the wheels. Have not decided whether I will recover it in a different scheme yet. Will follow this thread and post pics as well.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
