lead weight
Reply
Old 11-08-2012, 05:43 PM
dash3riprock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default lead weight
Anybody know a good source for some lead weights? Im tired of running to my LHS for those little stickys every time i need to add weight. theres got to be something ealse im not thinking of. somthing i can drill and use screws on. I have used rolls of pennies and epoxy with pretty good success but i need a little more this time. any ideas ? Thanks, Joe
dash3riprock is offline
Old 11-08-2012, 05:53 PM
uncljoe
uncljoe's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: lead weight
BB's   (usually at ammo dept) are a great source get then at walmart  , 5 pound plastic container  about 8 bucks  pore the amount you need into a plastic bag . you can also add epoxy to secure them in the bag.
 Semper Fi
 Joe
uncljoe is offline
Old 11-08-2012, 05:54 PM
samparfitt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I get 25 lb bags of buck shot (was about $40) from local gun range:
http://www.targetworld.net/
I'm sure you have something, similar in your area.
samparfitt is offline
Old 11-08-2012, 06:03 PM
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tire balance weights
Live Wire is offline
Old 11-08-2012, 07:21 PM
tunakuts3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gary Prince ( ram3500 -rcu) sells steel powder that you mix with epoxy to form a thick paste that can be applied to the inside of cowls or other areas up in the nose. http://www.rcuniverse.com/forum/m_10...m.htm#10903110 pm him for more info or search for more of his threads.
tunakuts3d is offline
Old 11-08-2012, 07:34 PM
Peter_OZ
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fishing sinkers and lots of heat
Peter_OZ is offline
Old 11-08-2012, 07:38 PM
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used 1/4" thick steel plate cut out to fit the firewall. Then mount the engine. Usually on short nose round cowls like on Zero's and Stearman's. Of course it helps have a metal cutting band saw.
Edwin
Edwin is offline
Old 11-08-2012, 07:47 PM
Check6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use lead flashing for chimneys. Get it at hardware stores and Home Depot You can fold it quite easily and make blocks.
Fred
Check6 is offline
Old 11-09-2012, 03:45 AM
carlbecker
carlbecker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lead shot in the 25lb bag. Make holding weights or epoxy pie where ever needed.
carlbecker is offline
Old 11-09-2012, 05:07 AM
MajorTomski
MajorTomski's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And if you need nose weight, on my last two models I bought flat round or triangular fishing weights at Academy sports. Then drilled and tapped the sides of my engine mounts and screwed the weights to the engine mounts. Puts the weight as far forward as possible, minimizing the amount needed and lets you remove or lighten the amount if needed as you get comfortable with the plane.
MajorTomski is offline
Old 11-09-2012, 05:36 AM
gibb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My buddy and I use a small cupcake metal cooking sheet. Fill the cupcake form with shot or whatever you like and hit it with the propane torch. Let it cool and turn the sheet over and you have a nice block that you can drill a hole through or glue on.....recommend the bolt on method. Again, use the mini cupcake sheet.
gibb is offline
Old 11-09-2012, 05:48 AM
scale only 4 me
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice tip
I did want to try that "SteelPowder" someday too
scale only 4 me is offline
Old 11-09-2012, 05:50 AM
a65l
a65l's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd say Wal-mart for lead sinkers, but those things are rather expensive..... but they can be pounded into whatever shape you need and then held in with silicone adhesive...
a65l is offline
Old 11-09-2012, 07:06 AM
tfarmer96
tfarmer96's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dash3riprock
This is where i get my lead
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
tfarmer96 is offline
Old 11-09-2012, 07:30 AM
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dash3riprock;go toyour local "Scuba Dive Shop" in your area, theyshould have a good selection of various lead weights, size, shapes, weights etc.,that can be drilled and attached to your aircraft to suit your needs.
Roger
ForcesR is offline
Old 11-09-2012, 08:06 AM
STUKA BARRY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why not usable weight? If you need to add weight, purchase a larger battery. It does'nt make sense to add dead weight. A larger battery will solve your balance problem as well as adding more flight time.
STUKA BARRY is offline
Old 11-09-2012, 08:25 AM
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I didnt have room for 5lbs of battery.
Edwin
Edwin is offline
Old 11-09-2012, 08:26 AM
check6ii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I get mine at the local dive shop. You can get some that goes on a weight belt, and shot thats in a strong woven bag. On the bag I emty out whatever amount needed.
check6ii is offline
Old 11-09-2012, 09:47 AM
GerKonig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: gibb
Great idea...
Gerry
GerKonig is offline
Old 11-09-2012, 10:00 AM
aa1a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I go to my local tire store and ask for some used tire weights. They are usually reluctant but when I tell them what I want them for they will give me me a couple handfulls. Bring your own bag. They are using steel instead of lead now so there is less and less lead in the mix. They are dirty but the price is right.
Jim
aa1a is offline
Old 11-09-2012, 11:12 AM
radfordc
radfordc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Decoy strap weights work great. They are soft and flat and can be easily cut, drilled, or bent to shape.
Walmart has them http://tinyurl.com/bchqoe5
radfordc is offline
Old 11-09-2012, 12:04 PM
Moggy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zinc plates used on boats. You can usually get used ones at a marina in the spring for free.
Moggy is offline
Old 11-09-2012, 12:50 PM
wayne d
wayne d's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would recommend Ram3500 (gary Prince) and his steel powder. Very easy to use and besides lead is toxic when melted. I took some old paper tubes from wing tubes, sealed the end with packing tape, mixed up 30min epoxy and poured it in. When its cured it can be cut on a band saw without clogging up the blade. Best thing is you can cut it to any size you need. And its heavy stuff when its mixed.
wayne d is offline
Old 11-09-2012, 02:21 PM
lkruse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wheel weights at Harbor Freight. They are available and cheap.
lkruse is offline
Old 11-09-2012, 06:02 PM
dadragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Edwins steele firewall is a clean idea,you dont need to epoxy a bunch of crap to the cowl just BUILD it into the plane.good idea ED.
dadragon is offline
Reply
Display Modes
