Fuel clunk line for gas?
Reply
Old 11-09-2012, 06:55 AM
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fuel clunk line for gas?
What do ya'll use for clunk tubing in large gas tanks (32 oz or bigger). Tygon gets too stiff after a year and neoprene tends to split at the end over time when used with a heavy clunk. Taking the tanks out and changing lines every year is getting frustrating as some planes are not easy to do. Thanks, Paul
Meschmidt is offline
Old 11-09-2012, 07:04 AM
tfarmer96
tfarmer96's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fuel clunk line for gas?
Quote:
ORIGINAL: Meschmidt
I use neoprene gas line and a walbro tank filter/clunk. I havent had any trouble out of the neoprene gas line yet... that doesnt mean anything its just yet..
http://www.landscaperpro.com/echored...rlp340830.aspx
tfarmer96 is offline
Old 11-09-2012, 08:35 AM
F4u5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used Tygon for years, and have never had the stiffness issue. It is true a get a bit hearder, but just a bit, and it will acutally soften again in gas. This is why I store the tanks with a littel fuel in them (keep lines soft). Of course, I always put Stabil in my fueling can all the time. If your line is extremely stiff, I would guess it is a lower grade tygon, or fkae tygon...especially the blue stuff. I use this tygon from McMaster Carr, and I have planes 10 years old that I have never changed lines on:
Fuel and Lubricant Yellow Tygon PVC Tubing
Tygon Formulation: F-4040-A
Very flexible
Soft (Shore A57)
Temperature Range: -35° to 165° F
Use with barbed fittings
Not only will this tubing remain flexible when used with gasoline, heating oils, cutting compounds, and coolants, it also withstands lower temperatures than other fuel and lubricant tubing. Tubing is semi-clear yellow; you can see something is in the line, but the view is limited.
View information about the chemical compatibility of PVC tubing.
ID OD Wall Bend
Radius Max. psi
@ 73° F Available
Lengths, ft. Per Ft.
5/64" 9/64" 1/32" 1/4" 40 10, 25, 50 5552K43 $0.80
3/32" 3/16" 3/64" 1/4" 50 10, 25, 50 5552K22 .72
1/8" 1/4" 1/16" 1/4" 50 10, 25, 50 5552K23 .82
3/16" 5/16" 1/16" 1/2" 35 10, 25, 50 5552K24 1.17
1/4" 3/8" 1/16" 1" 30 5, 10, 25, 50 5552K25 1.49
5/16" 7/16" 1/16" 1 1/4" 25 5, 10, 25, 50 5552K26 1.91
3/8" 1/2" 1/16" 1 3/4" 20 5, 10, 25, 50 5552K27 2.23
3/8" 5/8" 1/8" 1" 35 2, 5, 10, 25, 50 5552K32 4.64
7/16" 9/16" 1/16" 2 1/4" 15 2, 5, 10, 25, 50 5552K33 2.93
1/2" 5/8" 1/16" 2 3/4" 15 2, 5, 10, 25, 50 5552K28 3.02
1/2" 3/4" 1/8" 1 3/4" 30 2, 5, 10, 25, 50 5552K42 5.47
5/8" 7/8" 1/8" 2 1/2" 25 2, 5, 10, 25, 50 5552K31 6.22
3/4" 1" 1/8" 3 1/4" 20 2, 5, 10, 20, 25 5552K29 7.03
For clunk, the best is the Bennelt filtered clunk for smoke. You can use it with fuel, it is heavy (compared to the heavy weight Du-Bro stuff) and it fliters
http://www.bennettbuilt.com/shop/Tan...Gas_Large.html
Jeff
F4u5 is offline
skillet92
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have found that if you keep gas in the tank the lines will stay flexible. I use tygon.
skillet92 is offline
Old 11-09-2012, 09:44 AM
Scar
Scar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When I asked that question, the answer I got was "Viton". Bought some, will re-plumb tanks this winter. It's expen$ive.
Best wishes,
Dave Olson
Scar is offline
Old 11-09-2012, 12:01 PM
Moggy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 on Viton I use it for the lines in the tank and Tygon for exterior lines. WHen you consider the amount you use inside the tank it 's cheap.
Moggy is offline
Old 11-09-2012, 12:24 PM
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where can you get Viton?
Old 11-09-2012, 06:10 PM
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Leave a little gas in the tank an your line will stay soft.
vertical grimmace is offline
Old 11-09-2012, 06:23 PM
Moggy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.mcmaster.com/#viton-fluor...tubing/=k3gp93
Moggy is offline
Old 11-09-2012, 07:28 PM
Meschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I store my planes nose down for more room. Leaving gas in the tank is not an option. I'll try some of this Viton tubing. Thanks moggy
Old 11-09-2012, 07:45 PM
BOLTMAN
BOLTMAN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have just set up a Dubro 24oz tank with Viton as the clunk line. As it sits at the moment ( no fuel in it yet ) the clunk ( std Dubro ) does not even touch the bottom of the tank. Will it soften once fuel ( gas ) goes in it? I don't like the idea of leaving fuel in it for storage.
BOLTMAN is offline
Old 11-09-2012, 09:44 PM
overbuild
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stihl dealers have a black flexable fuel line about twelve inch inlength for use inside fuel tank. It worksgreat for me. The costper piece was about $1.75. It stopped my problem of the clunk not returning tothe tank bottom.I also use a weedwacker weighted kiunk.
overbuild is offline
Old 11-09-2012, 10:10 PM
F4u5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bolt, Yes, it will soften with Fuel. How much may depend on the quality of Tygon you use.
Jeff
F4u5 is offline
Old 11-09-2012, 10:29 PM
600Bob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using the Rotoflow tanks now, never have to take them apart or fix leaks again...I hope.
600Bob is offline
Old 11-09-2012, 11:11 PM
BubbasanJohn
BubbasanJohn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 rototanks!!! Great product
BubbasanJohn is offline
Old 11-10-2012, 05:57 AM
Granpooba
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 600Bob
Have yet to try a Rotoflow tank. But from what I have heard and read, they may be the way to go. Next plane will most likely have a Rotoflow installed.
Granpooba is offline
Old 11-10-2012, 07:50 AM
Moggy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I'm putting a minimum of $2000 in the air I'm not going to skimp on $5 a foot for viton.
Moggy is offline
Old 11-10-2012, 12:51 PM
airega1
airega1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is the best idea I've seen! saves on fuel line, easy replacement
airega1 is offline
Old 11-10-2012, 05:45 PM
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is that flex piece Viton?
Looks like a good idea. The Viton I have is too stiff, I used a heavy clunk and had to put a nut on this for extra weight.
I'll try this, thanks
OliverJacob is offline
Old 11-11-2012, 03:56 AM
airega1
airega1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: OliverJacob
I doubt if Viton was used for that install, I would use Tygon
BYW this was not my idea I picked it up here on RCU
airega1 is offline
Old 11-11-2012, 05:26 AM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out the fuel line made by Echo for their power equipment. Stands up very well to todays gas and is very flexible. It's also available in several sizes. I work on small engines for a living, and find the line from Echo to need less replacement than other brands I work on. Just ask you local dealer to show you the "bulk" Echo fuel line. I beleive what you need would be #90014 or #90015. I don't use gas anymore so I have sorta gotten away from the set-ups.
TLH101 is offline
Old 11-12-2012, 06:19 AM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The stuff y'all are buying at the chain saw shops is Viton which is hands down the best fuel tubing for gas clunk lines.
Add a ceramic clunk and you've arrived at a bullet proof tank installation.
Poulan 530095646
BarracudaHockey is online now
Reply
Display Modes
