If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2003
    R, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Seagull Dewoitine 1.20 ARF ????
    guys, I don't know much about flying weigh vs wing loading so I ask, do you think my Magnum 180 4Stroker is to heavy for this Dewoitine ??
    BTW, I could put better/stronger retracts in it.
    the Magnum 180 weight with Muffler is: 38.9oz, that is only 8oz more than their 120 4Stroker
    http://www.horizonhobby.com/products...20-arf-SEA2580
    Wingspan: 71.0 in (180.0 cm)
    Wing Area: 764.0 sq in (49.3 sq dm)
    Wing Loading: 30.5 - 33.2 oz/sq ft
    Flying Weight: 10.1-11.0 lb (4.6-5.0 kg)
    thanks guys !!
    Jim
  2. #2
    Dash7ATP's Avatar
    Join Date
    Mar 2002
    Smithfield,, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Seagull Dewoitine 1.20 ARF ????
    I'm thinking the 1.20 should be plenty of power.  8 oz is a lot of weight that far forward, and might require wenght in the rear to balance for good flying. Extra weight is almost never your friend.
    I have a 1.20 in a similar sized P-40 with a fiberglass fuselage that is probably heavier than what this will weigh and it flies very well.  Of course this is just my opinion. There will be plenty of guys here who want as much power up front as they can squeeze in. They may be faster, but they also land harder, anad stall quicker. This usually leads to a much shorter life...............
    Dash
    "When you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return."
    AMA # 8870, Member since 1978.
    Waco Brotherhood # 219.
    P-40 Brotherhood #8.
  3. #3
    Join Date
    Feb 2002
    Vestal, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jim, war birds are notorious for being tail heavy. If that is the case with this one your extra wt in the nose will be needed. If it were me I would go bigger knowing that it takes ioz in the tail to = 4oz in the nose.
    As for the stock retracts in any 60 size or larger war bird arf I have a box full of them. They work great on 40 size models if you have enough room.
    Wt is not a problem if you land like the full size, 45 degrees of flap, carry throttle , keep a close to 0 AoA, use throttle to increase or decrease sink rate. If you don’t understand any of this stuff, you need to find someone who does to teach you. And you are not ready for this plane, you want a 750 sq. in wing that wt 8.5 to 9# and has flaps to learn on.
    Joe
    If it don't fly it wount cetch my eye.
    Personally customizing model aircraft since 1968.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
