VQ .60 Hurricane Retract mechs
Hey guys, I have a VQ .60 Hawker Hurricane that I a rough "off-field" landing with. The impact caused both retract cases to fracture and at this point in time, nobody offers replacements for that particular plane. I am confident that there is something out there that would be close fit if not a direct drop in replacement. VQ makes a few other mechanisms for their other offerings but I have not been able to locate any dimensions on those units. Do any of you guys have some information on anything that could lead me in a direction to getting a set that will be appropriate in my application?.. thanks for any help guys.
RE: VQ .60 Hurricane Retract mechs
See if Spring Air has anything that will fit. That air down function is a great safety factor. I have about six sets from them and they perform superbly. Dan.
www.retracts.com
www.retracts.com
Sounds good Dan, I will keep it in mind. Right now I need to keep it simple with mechanical actuation like the old units.
I wonder if any of the units for their P-51 or Ki-61 would fit and work properly.. I took a junk mechanism from a H9 Spitty and it appeared to be the right size but i'm not 100%.. I tried to find those mechanisms at horizon but was not successful..
NJ
I suggest you take out the old ones and measure the withe and length and find something like it at Hobbyking. They most likely may have something that will fit.
http://www.hobbyking.com/hobbyking/s...-Retracts.html
The retract slots are a standard size and most mechanicals for that size bird will fit.
Spring Air IS a much better option, and they bolt right in, I have them in my VQ Hurricane.
I have about a dozen pairs in planes and would never use mechanicals again.
I replaced the VQ retracts with Spring Airs and Robart struts. Also enlarged the wheel wells and used larger wheels which work better on our grass runway. Went through two sets of VQ retracts before I gave up on them. The Spring Airs work great. I get about six cycles out of the small air tank. I also raked the gear forward with a 1/8" plywood shim at rear mount of gear for better ground handling.
ORIGINAL: irocbsa
How about a mechanical set from a Top Flite P47?
My Feedback: (13)
Go to Nitroplanes and get the large electric retracts. $8-$10.00. Cheap, no air lines/leaks, no hassles. Bolt in and plug into receiver. I have around 10 pairs of those. I have two of the .60 size VQ hurricanes because the model is a really good value for what it is.
Currently I have Rhomairs in my hurricane but am going to get rid of those. All my other style retracts will convert to electric were possible. Even working on converting my BVM F-16 to electric with the hardware off the electric retracts I have.
Steve
Steve
ORIGINAL: P-39 fan
Have you checked with Hobbypeople? They sell VQ planes and handle the retracts for various models.
