Tail-heavy Top-Flite Spitfire
I'm currently using 3.3Kg servos (116 ounces) all over. The alternative microservos I MAY use (I'm not saying I will, just that I may), are 2.2Kg (77 ounces), with metallic gears and ball bearings. Following your statement, I understand they would still be a viable option if needed, except for the flaps. That would be good news, as I could replace 5 servos (each currently 46 grams, almost 2 ounces) for microservos, which weight 12.5 grams (half an ounce) each. That would be quite good (165 grams, or almost 6 ounces saved).
Cheers,
Seems like a DLE20 would solve your problem. Two birds with one stone.
Cheers,
Good day Diego, as you requested, I weighed the wing and fuselage on my TF Spitfire. The wing came in at 3lbs 2oz; the fuselage came in at 6lbs 6oz. I have also included a photo of the internal fuselage workings, as you can see there is vey little room to work with after all the electronics etc., is installed.
The TF Spitfire is an older design and is designed for a glow engine and not gas. If you plan on installing a gas engine to replace the glow engine, be aware that you will not be able to install an in cowl muffler due to where you have to place the electronic ignition box. With the ignition box installed under the engine box there is no room remaining for an in cowl muffler. That is the reason whythe muffler hangs out on the side of the cowl on my TF Spitfire.
Roger
Cheers,
You have made a beautifull job of your spit and have no doubts you will come back on here a happy man with a few flights under your belt.
Cheers,
Roger
Cheers,
Roger
Bob
Otherwise, I would echo what others have said. Tail -end weight is 5x nose weight fulcrum. So start at the very back and save every ounce. Not sure how many options you have however. Cockpit would probably have to go. I agree that 40oz will be a handful on this size plane, so try to get closer to mid-30s.
Regarding CG, I ALWAYS fly the maiden on any elliptical wing at CG = 25% root chord - no further back than that, no matter what the instructions say. This will take the snap out of the stall.
Landing configuration - Use a lot of flap. There is almost no such thing as too much deflection with split flaps. You will see full-scale using up to 75deg deflection. The split configuration will add lots of lift (up to 180% of wing CL in the flapped section, or 1.4xCL for the total spitfire wing) and lots of drag, getting that landing and stall speed way down. You should also mix 3-5degaileron reflex to full flaps to increase wingtip washout and give you more tip stall cushion. The added drag does not hurt either. These are slippery airframes and it takes a lot to get them slowed down. Finally, keep some power on all the way to the ground and minimize that elevator.
Your plane looks great by the way.
I have a pica spitfire with a 88 inch wing. it is fiberglassed on all surfaces, retracts and flaps. My spitfire weights in at 26 pounds and has a os bgx-1 as a power plant. due to the long tail all spitfires are tail heavy. mine has 5.5 pounds of weight in the nose. It flys awesome and is very stable. It is true, landing speed must be kept up. balance it and fly it. have fun
It,s not our fault ,.......................... ( just kidding )
Like you, i'm obsessed with building light, but it's just not possible with these fighters.
Although i wouldnt mind seeing a one roll rolling circle with a B25 or something !
That is a very broad statement is all. It depends on the builder and how you plan your build. Of course sometimes you cant get away from it but I bet if two different builders built the same model with their different skills and knowledge there would be a difference in the nose weight added.
Brad
19 OZ ,........................ thats a lot . But you are for sure , not the only one to add so much weight .
This is why , I chose the DLE-20 , or at least one of the reasons . 1 ) gas , cheaper on fuel 2 ) better chose of paints , doesn,t need to be glow fuel proof , 3 ) weight , to compensate for the tail heavy fuse . 4 ) cleaner fuel residue .
Down side ,.................. it is a heavy unite , but , if you add , all the front end weight , + the dead weight , I,m sure the lighter unite will be the DLE .
The last item to purchase is muffler , most likely from J-Tec . BUT ,........................ I am in the process of thinking about making my own muffler to fit . I cann,t weld ,......................... but I can fabricate ,... even make the jigs .
Now I,m hoping DLE , will come out with a DLE-20/RA
Following threads on the TF SPIT , especially the balancing of the ship ,.............. I try and keep in touch .
If there was a contest for the lightest , TF 60 size Spit , I,m sure Roger would win . ............ CONGRATULATIONS ( at least of what I,ve read , here and else where , maybe not )
Bob
Have to agree with you Bob . The lighter the easier it is to fly . BTW , very good solution , extending the firewall ( or nose ) .
But than there is " us guys " who land hot . I like a warbird to be heavy ( please don,t exaggerate what I,m saying ) , seems to add to the flying characteristics , with that added weight , like slipping ( if thats what it,s called " .
Nothing fly,s like a Spit .
Michel
Bob
I'm with you, Alan. I have trainers and sport planes for that butterfly feel. I like my warbirds to fly like heavy metal birds of prey.
i have been know to put ballast on the cg of a model, to make it stop blowing around like a butterfly, lightness, and models of fighters dont do it for me, i like the model to have presence
Brad
http://www.youtube.com/watch?v=bH54MtSLqxk
Well now ,....................... that makes three of us , they just seem to ride better when there heavy . slightly nose heavy .
Michel
