Reload this Page >
Fokke RC Messerschmitt 109e 1/5th scale
Old 10-05-2014, 06:12 AM
  #76
deatonbt
With the wing center section being part of the fuselage as per the original with the gull shape, I'm wondering where the access to the radio is. Is it through the cockpit?
Brian
Old 10-06-2014, 12:13 AM
  #77
Brad330l
Brad330l's Avatar
Brian
That is yet to be decided Brian but I could be cutting a hatch in the bottom of the fuselage but it will all depend on how things go while building the front of the structure.
With my ESM109 I put all of the servos and radio gear right behind the fire wall keeping the weight well forward and was able to put in a scale cockpit and pilot and still keep it light.
Cheers,
Brad
Old 10-06-2014, 11:34 AM
  #78
fokke
fokke's Avatar
Originally Posted by Brad330l
Well I finally got sick of waiting for that instrument panel fokke (it did not arrive mate), and got into the shed to play with my retracts that I have sorted.
https://www.youtube.com/watch?v=wiflFT5QHpc
Now it was time to start with the fuselage internal structure that connects every thing together. In the pictures you will see I needed to trim a bit of material off to get things to fit just nice. With this kind of kit (Limited Editions) one must expect this and time must be taken to get things fitting right and nice and square. So with a bit of trimming and sanding and test fitting things are starting to come together. I'll continue dry fitting every thing I can before committing to glue.
Next is to drill for the retracts and start cutting out the fuselage openings.
Cheers,
Brad
Nice progress Brad ! Sorry about the instroment panel , this was the second wich I sent .
About the service hole , on my model I can service all stuff from the cockpit hole , on the model of my friend from Bulgaria Nikolay he made hole on the bottom, so as you want
ID:	2038066   Click image for larger version
ID:	2038067   Click image for larger version
Old 10-07-2014, 03:27 AM
  #79
Brad330l
Brad330l's Avatar
Thanks Mate. Maybe I better come over there for a visit, have a beer and get that instrument panel haha,,
So continuing I am trying to go 5 steps forward before committing to glue, checking fit and angles etc to get things right.
One great feature of the way the model is built is the main spar that goes through the major parts of the front structure so one is compelled to follow how things fit together there and make adjustments as required. As long as the structure fits in the glass fuselage and ends up with the basic angles in the right places gaps can always be filled and re-enforced with glass ribbon etc.
I can see now I will need some innovative thinking to get my retracts to fit in the scale location. Picture of that soon.
Cheers,
Brad
Name:	Not Quite Ligned Up.jpg
ID:	2038200   Click image for larger version
Name:	Front Structure 109.jpg
ID:	2038201   Click image for larger version
Name:	All Off The Spar 109.jpg
Old 10-18-2014, 10:21 PM
  #80
Brad330l
Brad330l's Avatar
So, time to start gluing things into place so I have done the mandatory 'glue test' with the pictured silastic type adhesive.
I first cut out the cockpit deck (to no real measurements) to gain access to the centre of the fuselage and used this as a test piece as seen.
I cleaned the surface with acetone and set the ply in place with a small fillet up the sides.
My mate Wayne built his ducted fan jet like this, sticking everything to the inside of the fuselage with silastic and it was very strong. Surface area is all important.
All the wood to wood joins will be thickened resin glued.
So I'll report back with the results.
Cheers,
Brad
Name:	BF109 Glue Test.jpg
Old 06-14-2017, 01:18 PM
  #81
fokke
fokke's Avatar
The same model like your in Austria, I hope you like it
Cheers
Old 06-14-2017, 01:21 PM
  #82
fokke
fokke's Avatar
This new platform of the forum is totaly sh.... t
Two post with one click ..........
Old 11-26-2018, 09:06 AM
  #83
DrScoles
My Feedback: (18)
DrScoles's Avatar
Has anyone got a gas engine in this kit without the head showing? Small in-line twin maybe?? Lots of room to move firewall back, just can't stomach such a detailed kit having a motor showing... Electric is obviously an option, but I like noise....
Old 11-26-2018, 11:10 AM
  #84
fokke
fokke's Avatar
Hi Michael
If you check the link of our website you can see there the different variants for engines
