Adding panel Lines and Rivits to already covered war birds
Reply
Old 01-30-2013, 05:44 AM
mikes68charger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Adding panel Lines and Rivits to already covered war birds
Ok I have been doing a lot of resurching on the different ways to add detail to your already covered war brides. The ones I'm working on are TF Gaint P47,P40, and P51
i need some ideals how to fix this
I got my P47 from my buddy who passed away and he got it last year at Teleto in OH
It's covered in silver and has nice panel lines in a dark silver with a ton of rivits. I have spent over $40 looking for a silver marker to finish the job on this plane with no luck. (Office Max, Joians, HobbyLobby) Everything I find has to much metallic/shinny. I just fig out last night I can remove the rivits with some paint thinner. Even thou it will be a pain as for some reason he used the big rivit methought with the canopy glue only on one side if the plane, I guess the original owner planed on going back over these with a marker
I have seen the vid on you tube about useing a heat tool to make nice rivits with brass fuel tubes wich look great, but if any one can point me in the direction on a flat silver marker for rivits I may just finish it as is.
mikes68charger is offline
Old 01-30-2013, 05:48 AM
mikes68charger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Adding panel Lines and Rivits to already covered war birds
Here are some pics.
ID:	1845972   Click image for larger version
Old 01-30-2013, 06:02 AM
mikes68charger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The othere issue I'm haveing in finishing this modles is the cowl. It's real nice and feels thick but there is cracking in the paint that makes it look like crap
Were the white is cracked you can see black in the crack marks. These cracks are deep. Can hang your nale in them. So I dont know if it is a clear coat or primer/base coat issue. And why some of it turned pink is beyond me.And its odd as it looks like the stock base silver is un effected.
How would you fix this?
ID:	1845975   Click image for larger version
ID:	1845976   Click image for larger version
Old 01-30-2013, 06:53 AM
Dash7ATP
Dash7ATP's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My first question would have to be is the present finish on the plane. Plastic film or paint? If it's an ARFwith a film, fon't worry about it. The only type of rivits you couild use will be on a tape of press on dry transfer. The tape looks like crap and the press on (think ProMark) will require more pressure to apply and you'll bruise the balsa underneath it.
IFit's a painted surface, you can do it pretty easily, but will pprobably have to add more paint to make it look OK. The burned in rivits do look good. I'v done several projects using that technique. HOwever for the best results, it should be used only ona glassed and painted surface, and I'm thinking an epoxy or automotive type paint. Iuse a wood burning tool with a modified tip. You need to be able to use different sized brass tubes with sharpened edges for the differfent sizes of rivits or fasteners. You will also need to be able to control the voltage going to the tool as the temperature is very critical and changes from one surface to another. By that Imean a fiberglass cowl will requier a different temperature than a glassed balsa surface. These are ony for flush type rivits, obviously.
For the raised style rivits, a small blunt type needle filled with white glue is what Iuse.
The cowl paint is obvoously due to a mismatch in type of paint. Sand it all off and start over. Sorry.
Dash
Dash7ATP is offline
Old 01-30-2013, 07:06 AM
John Redman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On a film covered model you can easily add the traditional flush rivets done the same way on many Top Gun or Scalemaster's quality models. I outline the entire process in my Hangar 9 P-47 build series of videos.
http://www.horizonhobby.com/article/...underbolt-30cc
See videos 13, 14, and 15 for the panel lines, rivet detail, and weathering. Easy Peasy!!!
John Redman is offline
Old 01-30-2013, 07:15 AM
mikes68charger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mr John I wached your you tube clip last night and I think you way is going to be my only option.
I was planing on going to the hobby store durning lunch to see if they had that heat iron you used.
My qestion to you is, you have to spray the flat coat down first then do the rivets? Or as Mine already hase the lines should I do the rivits then the clear coat?
Would you mind showing a close up pic of our work?
It wasa little hard to tell how the finsih product looked up close on your clip.
Thanks for sharing.
Old 01-30-2013, 07:57 AM
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take the cowl and sand off all the paint, you'll need to repaint it.
You dont want to rivet over the rivets that are already on the plane. You have two options. Remove the covering and recover. Then follow John's Videos and use his method to detail. Or leave the rivets etc. as they are. That is unless you can remove them via alcohol or another solvent.
A trim iron from any of the manufactures will work just fine. You'll need to make the adaptor for the brass tubing. Not a difficult chore.
FYI not to get to anal or anything but the "rivets" on the canopy should be phillip head screws and not huge.
BobH is online now
Old 01-30-2013, 08:18 AM
Ron101
Ron101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think fritz dezings clear rivits for ARF's look pretty cool... in fact that is what I'm planning for my Giant Scale H9 P-47
looks easy and gives a good effect... also like the fact I can iron out wrinkles and they will be fine...
I've pressed in rivits in monokote and after bubbles form when you heat the film it pulls out the rivits
http://www.fritzdezings.com/products-main-decals.html
Ron101 is offline
Old 01-30-2013, 08:49 AM
John Redman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As Bob said, any trim iron will work fine. Hangar 9, monokote, any or them.
I sprayed the flat clear before so the pencil would have something to grab onto and show the line compared to striaght plastic covering.
If you are happy with your lines, then just rivet. You do not need to clear the rivets, the clear is only needed if you do the weathering I show to seal it.
I believe there are better close ups in this thread where I showed the full build thread of the model.
http://www.rcuniverse.com/forum/m_10...m.htm#10906674
Old 01-30-2013, 10:40 AM
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John, fyi. thank you for doing the tutorial. It's a good starting point for people who lack the knowledge but have the desire to create something better than just what came in the box.
BobH is online now
Old 01-30-2013, 11:11 AM
mikes68charger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BobH
Thanks guys I Just went to my Local Hobby store and place my order for this iron.
BobH
I know the rivits look bad, but I did not do them, Im trying to save the plane.
The marking all seem to come off with some paint thiner, so I think I will strip the whole plane down and do like shown.
I don't like the rivits on here, but only paid $500 for this bird with DLE55 and retracts...
Also I took the cowl to the HB store and they think the white turned pink becouse that part of the cowl was orginaly red and it bleed throw.
Old 01-30-2013, 02:08 PM
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check this web site, maybe you find something interesting for your project...
www.nsmodelers.rs
mirce is offline
Old 01-30-2013, 02:47 PM
JSZ
JSZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or if you prefer you could contract the job out. I have done five of these over the past year. Completely uncover, glass, panel line and rivets and paint a scheme of your choice.
ID:	1846135   Click image for larger version
JSZ is offline
Old 01-30-2013, 02:49 PM
JSZ
JSZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ID:	1846137   Click image for larger version
JSZ is offline
Old 01-30-2013, 02:50 PM
JSZ
JSZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry about the double post, don't know why that happened.
JSZ is offline
Old 01-30-2013, 04:28 PM
TTRotary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dash7ATP
Dash
Actually, you can dress up the film covered ARFs a bit as well, as per the pictures below. I started by ironing on the Kote for full adhesions everywhere, and then I used 1.5/16 alum tube in a small drill chuck to indent the wood and film. I used a cuticle tool for the panel lines - you want something sharp enough to make a fine mark, but not x-acto knife sharp obviously. It's not scale but it looks decent and the indents are not affected by re-ironing. The trick is really to understand how much pressure to use and to use the wood for the indent mark. Id did this freehand in about 1 hour. No big deal.
ID:	1846176   Click image for larger version
ID:	1846177   Click image for larger version
TTRotary is offline
Old 01-30-2013, 04:32 PM
TTRotary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Dash7ATP
Dash
ID:	1846179   Click image for larger version
ID:	1846180   Click image for larger version
TTRotary is offline
Old 01-30-2013, 05:07 PM
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks pretty good to me.. Good technique and good job.
BobH is online now
Old 01-30-2013, 05:48 PM
aircraftbuilder67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would like to add that I watched Mr. Redman's videos on panel lines, rivets and weathering several times before going for it on my 47.I havethe 1.50 version that pre-datesthe current 30 cc versionand is OD on top and greyon the underside vs. the current aluminum. So far, I think I can report success and very satisfying results. When I first started spraypainting the flat coatand scribing, I was quite nervous. This is the first time I have detailed out a plane, but the videos couldn't have been done any better in teaching and demonstrating the techniques. One thing I have tried and liked was using the stainless steel ruler laid on the wing when doingthe rivetswhich allowed me to make straight rivet lines and as a bonus, the ruler gradationsallowed me to have some semblance of consistant distance between the rivets. I used a low power soldering iron that had a screw in tip to do the riveting. I removed the tip and used successively smaller K&S brass tubes to get down to the size I wanted for the rivets. For the 1/6 P-47, a 0.250" rivet is about 0.041" as per the video. I think the tube I am using is about 0.062" and the next larger OD for the larger fasteners. Good luck!
aircraftbuilder67 is offline
Old 01-30-2013, 07:15 PM
essyou35
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can get cracks like that if you dont wait long enough for a coat to dry before adding another.
essyou35 is online now
Old 01-31-2013, 04:57 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: essyou35
Or if the surface isn't properly prepared before you paint over it.
TomCrump is offline
Old 01-31-2013, 05:04 AM
redbiscuits
redbiscuits's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mirce
www.nsmodelers.rs
Mirce's finish/detail set works very well and you don't have to burn holes in anything, damage the wood or covering, and you get constancy. It is no shortcut in riveting by any means, but the results are pretty nice. If it were me I would start over on a fresh fiberglass cowl from Fiberglass Specialties, your going to have a lot of time in sanding and re-prepping the surface for new paint.
Good Luck.
ID:	1846390   Click image for larger version
ID:	1846391   Click image for larger version
redbiscuits is offline
Old 01-31-2013, 05:50 AM
mikes68charger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the diff between the fiberglass specilties and the stock TopFlite cowl?
Old 01-31-2013, 06:20 AM
redbiscuits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure if there is a size difference, you would need to ask them if it will fit the ARF, it should. Other than that it will be bare fiberglass.
Old 01-31-2013, 10:27 AM
on_your_six
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and a beautiful job he duz.
Quote:
ORIGINAL: JSZ
on_your_six is offline
Reply
Display Modes
