Reload this Page >
Ed's Ziroli B-25 Build
Old 11-28-2016, 02:12 AM
  #276
hook57
My Feedback: (21)
Originally Posted by acdii
Argggh! Thanks pal!
Old 11-28-2016, 06:17 AM
  #277
acdii
No problem, took me a while to find it myself. There aren't any links to it, have to use the search function on their home page.
Old 01-23-2017, 06:06 PM
  #278
Fili
Fili's Avatar
How you Guys coming along?
ID:	2197909   Click image for larger version
ID:	2197910   Click image for larger version
Old 01-23-2017, 06:13 PM
  #279
acdii
I got the wing and fuse done, but having trouble with the stab, trying to figure out the linkages using pull-pull instead of a pushrod.
Old 01-23-2017, 06:41 PM
  #280
Fili
Fili's Avatar
For the rudders?
Old 01-23-2017, 07:15 PM
  #281
acdii
Yep, was going to use G10 and 4-40 ball links, but after making one, found they are too big and wont fit in between the sheeting, so have to either use the plastic ones, or get a thinner sheet of G10 and 2-56 ball links. Its the bellcrank that I have to figure out, but have to get the sizing done first. I also need one of those center ball link 2-56 couplers, all I have are 4-40. The stab is not as thick as I thought.
Old 01-24-2017, 04:45 AM
  #282
Fili
Fili's Avatar
I ended up mounting wing servos in the fin itself, and the ele servos in the Horizontal stab as well. I know it'll take a bit more weight to get her balanced, but it is what it is.....
ID:	2197994   Click image for larger version
Old 01-24-2017, 06:32 AM
  #283
acdii
That's what I am trying to avoid. I still have not chosen an engine for it yet. I would like to keep the tail as light as possible, the entire plane as well before making a decision. I want to go 4 stroke gas, and if I can get the weight to stay low, then a pair of FG-30's may work, or a pair of FA-180 with CDI may work.
Old 08-22-2017, 07:01 AM
  #284
SWAMPER40
building my 101 B25 and a quick question on the fuse do you guys leave the crutch in or do you remove it once you get all the stringers glued in ?
Old 08-22-2017, 08:23 AM
  #285
acdii
I left mine in until it got in the way of the wing install. You need it in place in the wing opening and nose until it is fully sheeted, otherwise the fuse will twist.
Old 11-27-2017, 06:21 PM
  #286
Fili
Fili's Avatar
Howz it going guys? Moving along here.Working on the top gun turret, then cleaning up to prop for panel lines, rivets...
ID:	2246398   Click image for larger version
ID:	2246399   Click image for larger version
Old 11-27-2017, 06:35 PM
  #287
acdii
Other than the wing mounts, and stabs glued on, haven't touched it. Been busy on smaller planes. I do have a nice pair of NGH 38CC 4 stroke gas engines for it though.
Old 12-12-2017, 05:05 AM
  #288
SWORDSN
My Feedback: (13)
Fili I have tried to respond to your B25 questions through RCU but I don't think you are receiving my answers.
I will list them here.
I used a 10 oz slant front tank which gives me about 9 min run time in ground test.(12 oz would be better)
I mounted ignition on plywood plate zip tied to top two engine stand offs.DLE35RA
I hope Ed is ok with me using his thread
Old 12-27-2017, 04:48 AM
  #289
Fili
Fili's Avatar
Thanks for the reply SWARDSON! I was able to find 16oz tanks that fit, and after I got and mounted them I found a 21oz tank, they are, however, backordered until early Jan. I can wait as its stupid cold and snowy up here in the northern province..Lol. I'm moving along with the detailing and will post pics tonight. I'm almost done with the rivets and panel lines.
Old 12-27-2017, 12:53 PM
  #290
Fili
Fili's Avatar
Just a few pics... I'm almost done with the riveting and panel lines. A few things to clean up and I can paint. I also need to finish my throttle cables, but I really want the bigger (21oz) tanks that are still backordered until early jan.
ID:	2248936   Click image for larger version
ID:	2248937   Click image for larger version
ID:	2248938   Click image for larger version
Old 12-27-2017, 01:33 PM
  #291
SWORDSN
My Feedback: (13)
That's a lot of fuel and it will be forward of the CG. You will probably use about half on a average flight,not sure of the effect,maybe someone else can jump in.
Old 12-27-2017, 06:23 PM
  #292
Fili
Fili's Avatar
Hmmmmm...... You got me thinking.
I have G38s in my C47, I forgot how big the tanks are. I set my timer to ten minutes, typically I'm ready to come in by then. I've run over a few times, but never have run out of fuel. However, I really want to chase the fighters around this year with the B25. I'd like ten plus min if possible and not have to worry about running out and losing an engine. I think I'm going to have to go back and see what tanks I have in the C47..
Old 01-18-2018, 05:34 PM
  #293
Fili
Fili's Avatar
Very close to done. A few inside things to do and order, three blade props, hubs... almost ready!
ID:	2251520   Click image for larger version
ID:	2251521   Click image for larger version
Old 01-19-2018, 04:14 PM
  #294
acdii
Looks much better than mine! LOL What did you use for the aileron hinges?
Old 01-21-2018, 06:49 AM
  #295
Fili
Fili's Avatar
Thanks! I used Robart hinge points
Old 01-21-2018, 07:41 AM
  #296
acdii
So you didn't go by the plans for hinging? Did you add a leading edge and V shape it then for center pinning?
Old 06-18-2018, 07:48 AM
  #297
Fili
Fili's Avatar
Maiden went very well. No trim adjustments, half flap landing. Lovely flier!
