Is my 1/4 scale busa DR1 Fokker too heavy??
My Feedback: (23)
MI
My dr1 weighs in at 17lbs 13oz. Power is a dle30 with stock muffler. Two 2000mah nimh batts. It took almost 2lbs on firewall to balance. The builder put the servos in the tail, not sure why. I know that means more weight up front, but I calculated moving them forward and running controls back and it doesnt seem like it would make much difference. All said, it flys like a dream, almost seems floaty on landing. Just wondering if almost 18lbs seems heavy for this model. I hate to change anything because it flys so nice.
My Feedback: (95)
RE: Is my 1/4 scale busa DR1 Fokker too heavy??
If it flies good, I wouldn't worry about it. Mine weighs in at exactly 17 lbs. It balanced out without any nose weight with a G-26 w/mag ignition, RX and smoke battery packs close to under cockpit area. Just make sure the C.G. is correct and your engine is well tuned.
My Feedback: (95)
C.G. exactly as per plan which is about 3-5/8" from leading edge back underneath the top wing. I do not recommend flying it tail heavy, If you have a dead stick, it will loose airspeed very fast and it will drop like a rock. The plane has alot of lift but also alot of drag. It is a good flying plane when set up correctly but it does not like to take off or land in cross wind situations. Hope that helps
