If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 11 of 11
  1. #1
    Join Date
    Feb 2006
    camden, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Need retract servo wiring help
    Ok guys i have 2 jr 791 retract servos that i am putting in a h9 150 mustang. They only work off of 4.8 and i am going to run life batts for the reciever. How can i run a separate 4.8 nimh for the retracts and still connect them to the reciever?
    Michael.M Waco brother #187
    P-47 Brotherhood #22
    And Certified Warbird Nut
  2. #2
    aghost's Avatar
    Join Date
    May 2002
    Amarillo, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Need retract servo wiring help
    Try this. This image came from RCU several years ago. Don't remember who should get credit for it.
    You can add a Y at the retract servo point in the graphic to go to both retracts.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  3. #3
    Join Date
    Feb 2006
    camden, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WOW! Thank you. That is excactly what i am looking for.
  4. #4
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Or you can get a step down diode like we use for tail rotor servos and ignitions.
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  5. #5
    Join Date
    Jan 2003
    Nolensville, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have found that the Smartfly regulators are a great solution to this issue. They have both adjustable voltage versions and preset (like 6v) ones. High quality and modular so if you change things out the regulator can be easily removed.
    Whit
  6. #6
    Join Date
    Feb 2006
    camden, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That was my first choice till a fellow club member told me that if the retract jams opening or closing it will drain the reciever battery quickly. He was the one that suggested i run them off a separate batt. But i could not understand excactly what he meant. The diagram clears it up for me.
  7. #7
    Join Date
    Jan 2003
    Nolensville, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good point, I'm only using air driven systems so I had not considered that.
    whit
    ORIGINAL: skillet92
  8. #8
    Join Date
    Oct 2005
    Near Pfafftown NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: wphilb
    whit
    ORIGINAL: skillet92
    Electric retracts don't automatically do that if they jam. The advertising of the ones I've purchased explains why they don't.
    Good flying wit ya today
  9. #9
    Join Date
    Feb 2006
    camden, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rock i have down and locked retracts on 3 of my planed and yes they dont jam and drain the battery because of built in overload protection and will still try to go the other direction if you need them to, but on this h9 150 mustang i am going to try and set it up with the factory retracts and us jrs 791 retract servo. They will jam and might not stop draining the battery if they do. Of course with that much torque they might also distroy themselves. Lol
  10. #10
    Greg Wright's Avatar
    Join Date
    Sep 2008
    Illinois
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mike,
    I'm not sure if this is an option for you but you might be able to run them thru a JR Matchbox if possible and then that would be just like a Y-harrness but it would give you the opportunity to run a separate 4.8 volt battery thru the match box to power just the two servos. And still only use one channel in your receiver. Or you could run the two servos thru this dual output voltage regulator from Spektrum also and not have to worry about adding anymore weight to the plane.
ID:	1859183   Click image for larger version.
    Greg Wright
    Team Horizon Member/ Horizon Hobby/Spektrum/Hangar9/ E-Flite/Blade Heli's
  11. #11
    ram3500-RCU's Avatar
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: wphilb
    Whit
    I second this post.
    Cheers,
    Gary P. / use Steel Powder for ballast not lead. PM me for more information.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
