Reload this Page >
Corsair F4U-1A Top Flite Giant ARF Modifications
Old 04-20-2015, 10:58 AM
  #376
SWORDSN
My Feedback: (13)
There is also a thread on building by the book,both have good info
Old 04-20-2015, 12:48 PM
  #377
hludowieg
Where can I find it?
Old 04-20-2015, 02:51 PM
  #378
SWORDSN
My Feedback: (13)
Don't know how to post a link,but if you do a search "Top flite giant corsair disappeared" you will find it in this warbirds forum, it's 31 pages.
Old 04-20-2015, 03:51 PM
  #379
handyman 220
My Feedback: (54)
Here is a link http://www.rcuniverse.com/forum/rc-w...sappeared.html
Old 05-10-2015, 03:52 PM
  #380
Shaun Evans
Shaun Evans's Avatar
Hi,
Will the DLE 55 (Side) stock muffler fit inside the cowl? If not, how much hacking are we looking at?
Old 05-11-2015, 11:06 AM
  #381
rt3232
Hay Y/A from other threads and post, from what I remember that's a NO
Cheers Bob T
Old 05-11-2015, 02:38 PM
  #382
Shaun Evans
Bob,
Thanks.
Shaun
Old 05-11-2015, 04:28 PM
  #383
rt3232
Hi Shaun aka Y/A
Did not mean to be so blunt on the last post, but had to take our girl to the airport, what I would suggest is a pits rap around I am using Bisons and Jtec good luck with both, the bison's for some reason seam to be a bit quieter
Cheers Bob T
AMA13377 Corsair Brotherhood # 6
Old 05-11-2015, 04:32 PM
  #384
Shaun Evans
Bob,
No, I was happy to just get a response finally! I have the J-tech one for the P-51, but was hoping to use a stock one. Seems like if it won't work it's so 'barely' a miss, I might just do it anyway. Looks like I might be able to either do a blister or even heat the sucker up and push on it.
Thanks again for the input!
Old 05-12-2015, 03:38 AM
  #385
rt3232
Shaun
With a lot of the guys going sparky(electric) the Hobby Shop the I go to seams to have an abundance of good used mufflers.
Cheers Bob T
Old 05-12-2015, 12:58 PM
  #386
Shaun Evans
Found a solution!
Old 05-12-2015, 05:27 PM
  #387
rt3232
Post a pic Please.
Cheers Bob T
Old 05-13-2015, 11:02 AM
  #388
eskiserkan
I think to fly it with Saito FA-325 radial. It fits perfect inside of the cowling. Anyone have experience with this stuff ?
Old 05-13-2015, 04:37 PM
  #389
rt3232
Not me sorry
Cheers Bob T
Old 05-13-2015, 09:13 PM
  #390
Chris Nicastro
Chris Nicastro's Avatar
Yes it will fit and theres video on YouTube. There is a Japanese modeller flying this combo in one video I watched. Its not fast just adequate enough to fly around scale like.
Better option is the Saito 84FG.
Old 05-15-2015, 07:53 AM
  #391
Shaun Evans
Hi,
Can anyone confirm that the stock cowl included with the ARF is polyester resin and not epoxy?
Old 05-15-2015, 10:21 AM
  #392
JeffH
My Feedback: (43)
It is indeed polyester, pretty thin polyester at that.
Old 05-15-2015, 10:34 AM
  #393
Chris Nicastro
@YA
Yes and very thin. If you cut it expect it change over time with the heat, even the edges of the head opening changed.
If you looked at my old post regarding the cowl flap mod I did what happened over time was the segments flattened out. If I did that mod again I would sand and back them with epoxy and carbon fiber so they keep the shape once cut.
  #394
JeffH
My Feedback: (43)
Yes, I have flown one with the 325 in it. On a nice cool day, it is great. Once the temperature goes up, the performance really suffers. Vertical is limited and take offs must be allowed to build up speed before you start your climb.
Old 05-17-2015, 05:07 AM
  #395
SWORDSN
My Feedback: (13)
Originally Posted by YellowAircraft
Hi,
I have a stock muffler in mineI did cut a slight relief hole
ID:	2096507   Click image for larger version
Old 05-17-2015, 05:11 AM
  #396
SWORDSN
My Feedback: (13)
After installing the dummy radial the muffler was touching the cowl,which required the cut
Old 05-18-2015, 07:28 AM
  #397
Shaun Evans
Swordsn,
Is it an optical illusion or is your cowl not sitting straight on the fuselage in those pics?
Old 05-18-2015, 10:49 AM
  #398
SWORDSN
My Feedback: (13)
Swordsn,
Those pics were taken during cowl alignment.It was not in the final position.
Old 05-18-2015, 12:04 PM
  #399
rt3232
Hi
swordsn
that is a neet trick for holding the cowl, seams I all ways learn something when I just surf these threads.
Cheers Bob T
Old 05-20-2015, 03:40 AM
  #400
SWORDSN
My Feedback: (13)
Originally Posted by rt3232
Hi
swordsn
Cheers Bob T
Thanks Bob,we all learn from these threads and make friends from all over.
