EASYTIGER LA-7
My Feedback: (98)
RE: EASYTIGER LA-7
I think you should've used better plugs than the XT60's with this battery setup. It will be interesting to see if they work out, I don't use them on anything more than 3 cells.
Nice plane BTW.
Nice plane BTW.
RE: EASYTIGER LA-7
those are 8mm connectors with 10agw wire they were soldered using a micro torch i dont think the gonna come loose these are not what u think they are , these are the larger one to the xt 60 that hobby king carry for high voltage the should hold up to the task, if i use higher cell count then ill use the gold bananna 8mm plugs thanks soarrich
RE: EASYTIGER LA-7
ORIGINAL: neville thomas
Said that, I really doubt you will have a problem with the XT60...
Gerry
#31
RE: EASYTIGER LA-7
i have the anderson setup, but sorry to say again i'm not using the xt60 these look just the same,these are XT90 high voltage connectors, for the motor these are the XT150 you can see the difference in size, i would not dare use the xt60 even for 8s setup
#37
RE: EASYTIGER LA-7
gear doors and yes lunch for my birthday joe's crab shack got nothing on this. i laminated 1/32 ply to .015 aluminum sheet with goop it will be impossible to part the two and it holds it form for the doors.
#41
RE: EASYTIGER LA-7
thanks bubba im trying my best but it was a good birthday. today i made the antennas heres what i came up with the top of the turtledeck has a ply and balsa housing glued in with goop that houses the mass for removal.
