EASYTIGER LA-7
Old 03-23-2013, 06:28 PM
neville thomas
Default EASYTIGER LA-7
got this kit back in feb just before the wram show ok before we get to bashing understand this this is no scale master kit it for the guys who dont like to build that want something different and u guys know me by know i like different tired of the lame mustangs and p47 that showup at warbird meet only not to see them fly keep your hanger queens at home no joy in looking at them. and i fly what i buils yes i do.
ID:	1865665   Click image for larger version
ID:	1865666   Click image for larger version
ID:	1865667   Click image for larger version
Old 03-23-2013, 06:39 PM
neville thomas
Default RE: EASYTIGER LA-7
her is what ill be installing for the power castle 160esc HV 12 on turnighy 6s 30c 5000 x4 10 amp of lipo as for the motor its similar to the turnigy it an 80-100-8 130kv max cells 18lipo won't be using that for the prop max is 30x10, itested with two props biella 24x12 d variable pitch and xoar 26x14 i like the xoar a ton of trust, im going to use some carbon props to get some more results later but the xoar will do for now.
ID:	1865669   Click image for larger version
ID:	1865670   Click image for larger version
ID:	1865671   Click image for larger version
ID:	1865672   Click image for larger version
Old 03-23-2013, 06:47 PM
n8622t
My Feedback: (8)
ok neville i was with you until you pulled that electric motor out[:@][&:][X(][:'(]
Old 03-23-2013, 06:54 PM
neville thomas
and for those of you who like to bash companys like easytiger stay out fro this post if you dont like it dont by it i prefer sierra over robart but i still by their products we are here as fellow modelers and men firt not women in the market. lets keep this clean i buy wat i like. as for this tread it just an informative build showing the small changes i made. if il like the way it flies then ill add more detail as you all know i got a 1/4 & 1/3 109 in the works hope to have the 1/3 out next summer gods' willing. in some of the pics you will see the arming switch and the momentary switch for the esc antispark. i got quit a ew things install in this bird turnigy dual fail safe bec with two turnigy 2300 nmh for the receiver considering ill be using high tork digitals got a new 9XR but ill test it in my smaller jets first before i install it here.
Old 03-23-2013, 07:03 PM
countilaw
countilaw's Avatar
Neville, looks like you got quite a bird there. I am really interested in seeing her fly.
Frank
neville thomas
electric aint bad , i prefer gas really but i wanted to try i myself after i watch a vid on youtube clean reliable power mor than my sachs 5.8 has will fly any 40lb bird you should try it n8622t never thaught that id ever by an arf either but here i am now a turbine ill still wait to buy.
ID:	1865676   Click image for larger version
Old 03-23-2013, 07:16 PM
neville thomas
thanks frank icant wait to fly it i should have my gear back from shindinmachineing in two weeks. now if u got a HV setup i suggest u get yourself a good charger like this one the 3010 1000w and a balance board and so heavy duty connectors like the one i've got xt150 and 90
ID:	1865680   Click image for larger version
Old 03-23-2013, 07:30 PM
neville thomas
harness fos batteries 10agw wire
Old 03-23-2013, 07:34 PM
neville thomas
forgot the pics
Old 03-23-2013, 07:37 PM
neville thomas
finally
ID:	1865685   Click image for larger version
Old 03-23-2013, 07:40 PM
neville thomas
the one thing i did not like the spinner it an odd shape and trouble to find one almost six inches
ID:	1865687   Click image for larger version
Old 03-23-2013, 07:43 PM
neville thomas
spinner and cowl
ID:	1865689   Click image for larger version
Old 03-23-2013, 08:21 PM
Mpizpilot
My Feedback: (45)
Subscribed. I've been eyeing this one. Interested in watching your build.
Old 03-24-2013, 05:16 AM
neville thomas
one thing i can say about this plane theres plenty of room to detail a cockpit and more if you like the frowarward compartment for the battery/tank bay was also reinforced with light 3/8x 3/4 pine stiffners it light ply bay just not strong enough to hold 46s packs for gas it ok to leave it that way . the retract for the mains are from airpower.com taiwan the 230 55lb they fit right in waiting for yhe struts which will be 3/4 from lenny at shindin.
ID:	1865843   Click image for larger version
Old 03-24-2013, 05:20 AM
neville thomas
here is the servo tray and receiver area
ID:	1865845   Click image for larger version
Old 03-24-2013, 05:25 AM
neville thomas
antispark and turnigy 6s 30c
ID:	1865848   Click image for larger version
Old 03-24-2013, 05:31 AM
neville thomas
wing pannels with flaps
ID:	1865850   Click image for larger version
Old 03-24-2013, 05:37 AM
neville thomas
my son who want to fly it really bad i told him to build his own and keep fly it on the sim, too ancious
ID:	1865854   Click image for larger version
ID:	1865855   Click image for larger version
Old 03-24-2013, 05:48 AM
neville thomas
fuse bulkheads and formers look at all tha room sweet
ID:	1865870   Click image for larger version
ID:	1865871   Click image for larger version
Old 03-24-2013, 05:52 AM
neville thomas
this is necessary when programing digital servos hitec programmer.
Old 03-24-2013, 05:56 AM
neville thomas
hitec programer good for ccw flaps and dual elevators set the endpoints and deadband
ID:	1865876   Click image for larger version
ID:	1865877   Click image for larger version
Old 03-24-2013, 06:00 AM
neville thomas
here are some pics of the tail wheel
ID:	1865881   Click image for larger version
ID:	1865882   Click image for larger version
Old 03-24-2013, 06:05 AM
neville thomas
more pics of tail section sierra gear
ID:	1865885   Click image for larger version
ID:	1865886   Click image for larger version
ID:	1865887   Click image for larger version
Old 03-24-2013, 06:10 AM
neville thomas
door hinge and piston
ID:	1865889   Click image for larger version
ID:	1865890   Click image for larger version
ID:	1865891   Click image for larger version
ID:	1865892   Click image for larger version
Old 03-24-2013, 06:29 AM
neville thomas
this is what 10amp look like two bricks
