tips on rudder trim tabs
RE: tips on rudder trim tabs
ORIGINAL: WhiteRook
does anyone have any pics of operating rudder trimtabs on warbirds ? i have afew ideas
thanks RCU
thanks RCU
My Feedback: (23)
ORIGINAL: WhiteRook
thats what i was thinking of using it for ,counteracting pull to the left, on takeoff
There is this new invention called the rudder chAnnel that works wonders for that problem! Lol
Rudder trim or boost tabs arent going to help this issue as both still require an action by the pilot for them to function. Unfortunately for some, there is no other way to counteract a yaw tendency automatically except by either your own thumbs or by using a gyro.
My Feedback: (10)
What I think you are looking for is an ability to input a set amount of rudder "trim" for take-off and climb, yet remove that from the cruise setting once cleaned up and in cruise configuration?
Depending on your radio you might have "flight modes" which allows you to switch between different setups with one switch, like going from a 3D configuration to a sport flight one, or from take-off, flight and landing modes. See if your radio has such.
Then you could set your take off settings on one mode with some rudder trim as needed, but have that trim taken out in flight mode.
Whit
WY
I do giant scale warbirds and put trim tabs on all the moving surfices eccept the flaps what that dose is like making a rudder for a rudder it takes alot of strain off the servos.
Many full scale trim tabs are sheet metal (aluminum) that are bent on the ground because a pilot suggests they need to be bent. There is a difference between a boost tab, and a trim tab.
Now, I could see how a small trim tab could help keep your plane straight, and not strain a servo, but You will have to be pretty big for this to be the case. But by and large, I would see this as unnecessary.
My Feedback: (23)
Just a trim tab is either ground adjustable or pilot adjustable in flight. Its used to trim the airplane for hands off flight at a given speed, if its inflight adjustable, its deflection stays linear as the flight control it is attached to moves.
Just a boost tab (aka servo tab) is not adjustable period. It has a fixed length pushrod that is attached to a stationary point on the wing or stab, and then the "tab" on the flight control it is attached to is hinged. As the flight control is delfected, the tab moves in the opposite direction of the flight control surface. This opposite deflection helps "boost" the control by relieving the amount of force needed to move the flight control, this is especially useful at high speeds with mechanically actuated flight controls
There is also an Anti-servo tab that does the opposite of the boost tab.
Now a combines boost /trim tab just adds an adjustable actuator in place of the fixed point on the wing/ stab. This allows you to use the boost tab to adjust trim when the control surface ia at neutral and then when the surface is moved, it helps reduce the force needed to move the control surface.
Actually there is a difference between Just a trim tab, and Just a boost tab. But many times they are combined into the same unit.
