ESM ZERO BUILD
#203
My Feedback: (25)
I honestly TRIED to use the supplied wheel well tubs, but they crumbled in my hands,LOL! I will go back later and fabricate wood liners this Spring. There really isn't any need for them anyway, but I'll use that project just for something to do.
#205
OL 55,
What is the diameter on your spinner? I called YA and they said theirs is 3.5 inches. I have a three inch and a 3.5 inch. One looks a little big, the other looks a little small.
I've broken my canopy now about four times. First three cracks not so bad but the last one requires a replacement. Did someone say there are replacement canopies being made? (I am next in line @ TBM but that might be a few months from now.)
Thanks...
Thanks...
#206
My Feedback: (25)
The Focke-Wulf style spinner, bought off fleabay is 74mm or 2.9+ inches in diameter. It's 3" for all intensive purposes. I believe sometimes the "shape" of a spinner can make them look either too small or too large. This one suits me fine.
LMAO! I had watched the video about cutting my ESM Zero canopy with a Dremel and cutoff wheel before I actually did it, and was real happy with the job I did when doing so, only to have one of the family cats piss me off (and I had the canopy in my hand!) so I wacked the cat (softly!) with the canopy and cracked it full length! That was last Summer and it, and other ESM parts I've had on backorder with TBM are still non existent. Other than ESM retracts (and I can repair them myself) I would say we're out of luck for replacement parts on these models. The 88" Zero is my only ESM model to date, and I think I'll keep it that way,LOL. Best of luck with Jeff and Bill on your ESM Corsair parts needs....
#208
My Feedback: (25)
http://www.ziroliplans.com/zirolipla...%20Canopy.html
Would this work? It's only $30 and 40 mils versus the ESM 20 mil thickness.
#209
OL55 &
Last time I talked to TBM they told me that I was second in line for a canopy and only one came with the recent shipment. The Byron/Iron Bay Zero canopy is about 19 and 1/2 inches long. The span on the Byron Zero is 88 inches and I think the length is 79 inches. The span on my ESM Zero is 87 and 3/8" but the length with the spinner is about 67 inches. The Ziroli Zero spans about 91 inches. If anyone out there has a Ziroli Zero maybe they could measure it for us. I wouldn't bet on it working.
I have an ESM Stuka that has done really well. Quite pleased with it actually....
OL 55 ...so did you try to glue up the canopy you have?
I think the eggs I eat for breakfast have a thicker shell than the canopy on my Zero.
After I get the engine in I will try and post some images...
#211
My Feedback: (33)
NY
I have a similar size Zero built by CMP and I had to add 3lbs of lead on the motor box ( electrical box full of lead ) with a Fuji 43. The weight is around 20lbs and has good speed, but if I had to do it again and I may I will use a Zenoah 62 others have in the CMP forum and it has lots of power and reduces the additional weight needed. You will love flying a Zero they fly great and look even better!
#212
My Feedback: (25)
OL55 &
#213
Thanks Tevans55,
So we know for sure it won't work. The Ziroli is twenty inches and the ESM frame calls for 17 and 3/4 inches, stem to stern... Well... leave no stone unturned. Will call YA on their canopy today.
BTW, Airborne has zero spinners if that hasn't been mentioned. They have 3 inch and 3.5 inch. No 3.25 inch. Plastic with aluminum base and center bolt. Low cost. Problem: center section at point is weak and will break out easily. But they have a nice scale looking profile and are inexpensive. I just add a little CA to the base to cement the spinner to the backplate and locktite the bolt. You can also get any color you want simply by painting with a scale color acrylic and then "frosting" with Luster cote flat clear.
I haven't run a new gas engine in a plane before. The DLE re55 manual says without vibration dampeners you damage the engine during break in.
Anyone have suggestions about an effective break in procedure for this engine? Oil ratio and octane rating?
John
John
#215
My Feedback: (25)
I gave up experimenting with multi blade props some time ago, and just stick to 2 bladed props. I find the 3 and 4 bladed props less efficient and fly the plane anemically. I just don't let anyone see the cowl/prop without it spinning,LOL!
#220
New Taipei City, Taiwan West Sheng Airport
https://www.youtube.com/watch?v=smaMpy6J_Ig
#222
Right then, maidened my Zero with the 50CC 4 Stroke Kolm as well. What a brilliant combination. The 20x12 three blade really gives the plane an awesome punch. almost unlimited vertical and good speed.
It is an awesome floater. Took me four attempts to land the plane without overshooting the runway. It just glides on and on and on and on...
Rev
Rev
#224
I built my retractable Tailwheel out of a cheap Hobbyking electric retract and some parts from an old mechanical 90° P-40 .40 size Retract. It swivels freely and works fine. goes up electric.
Rev
