ESM ZERO BUILD
#226
Hey Reverend,
That's a really great shot of your zero. The three bladed prop adds a lot to the appearance. The scale antenna and tank drop are very nice also...
Well done!
I built a semi scale retractable steerable tail wheel from some parts from an old crashed fly baby and copied the robart mechanical tail wheel parts in aluminum. Took about twenty dollars to buy the aluminum and about twenty hours to cut and fit the pieces. You can see a pic on my models at RC universe. The left side shows a part of the fly baby tail wheel spring.
Well done!
#227
I bought the one from glazier808 back on page 7 of this thread. Looks really good. I am trying to decide if I want to add an air cylinder to operate it or use a servo. I am already fighting a tail heavy issue, so I want to keep this as light as possible.
How did you bond a former in the fuse to attach the tail wheel to?
#228
I spent some time making a plywood piece that would fit the inside of the fuse. Epoxy was used to bond the piece to the fuse. Isn't the fuse epoxy fiberglass? It took more time to fit the retract to the former because the pivot point for the extended gear was precisely below the pivot point for the rudder. The linkages clear by just a few thousands of an inch. I have complete confidence in the unit.
I think the fuse is short on this model compared to the w.s. So there's an advantage. Additionally, the cable system took extra time, but it is much lighter than having rods going back to the tail surfaces. There are few warbirds out there that will balance as easily as this one...
#231
I have a used Robart set for this plane if anyone is interested, PM me. Its the 630 RSE(90 deg) Electric and the 671 Left and Right Robo Struts.
The springs for this set have been cut to work with with this plane, 19-24LB plane, Absorbs shocks good. This set will come with all the the connectors and the OEM wheels and axle for the ESM Zero.
Here's a video of their drop checks https://www.youtube.com/watch?v=qRQN...DFP4PFNqhI0dug
#233
My Feedback: (25)
My Zero flew very good, and fast with the G62 on it, but I lost the plane at an event this season as I wore through the up elevator wire even though I built the plane with DuBro 4 40 pull,pull wire rather than the lighter wire the kit supplied. The elevator bellcrank chaffed the wire to the point that the loop broke through leaving me no elevator. I was able to fly it on aileron, rudder, and throttle for a brief time, but eventually lost the plane in the trees. I had fun with this bird, but probably won't be buying another ESM product in the future, if for no other reason than the shipping. Best of everything good to y'all who have subscribed to the ESM lineup.
#235
My Feedback: (25)
You bet! I'm not an advocate of peaking the mixture with the use of a tachometer (although I use one for reference) but rather peak the RPMs on the ground then back up the high speed needle slightly as the engine leans itself when in the air at altitude, and with less load on the engine at speed. I used a Xoar 22x10 WWll style two blade. A 23x8 is also a good prop for this engine. And a Bennett muffler (not a pitts).
#237
Not much action going on here. Got back started plugging along with mine. Got the engine mounted and the tail controls figured out. Still have the tail wheel retract to install.
Looks like the engine is going to fit nicely! Sure hope it is enough power, using the DLE 35RA.
Then I will have to install the cockpit. Really looking forward to flying this bird!
#243
Lomcevak,
Tail wheel is nice...where did you get the starter? I guess it has to have a battery and how much does it weigh? I like the idea of not having to flip the prop. Would you tell us more about it? Hope I haven't overlooked a previous post.
#244
Reading OL55's remark, I think a simple spot of epoxy on the steel wire where it goes through the metal on the elevator control shaft would prevent this from happening again. That should stop all metal to metal chaffing. Its something that needs to be resolved.
#245
My Feedback: (25)
Something definitely needs to be re engineered here as another club member experienced the very same thing with his ESM Dauntless, but it happened on the ground (I wasn't that lucky,LOL). Another thing we've found of recent was the much improved performance in a multi pitched Zinger prop for the G62s (and my DA50) in a 20x8-14 pitch Zinger prop. Marked RPMs and in air speed. Not that our Warbirds are all about speed, but we fly a lot of formation flying, and to have it on tap is useful. I myself have moved to Yellow Aircraft for my Zero, and 47 airframes.
#246
OL55,
I didn't mention that I was sorry to hear about the loss of your plane. Even losing a low cost plane is not enjoyable and the larger ones require much more time and effort just to get them airborne. You seem the resilient type, nonetheless, I wish you well, that you may have a speedy recovery and that your greatest success and satisfaction is yet to come...
#247
My Feedback: (25)
OL55,
#248
http://www.milehighrc.com/EME_E_Start_30_35.html
I tried it out last night and it seems to work well. I am trying to get the plane finished so I can fly it in two weeks. Maybe then I can let you know more.
It does use another battery, but I am needing nose weight anyway. That is partly the reason I chose to put a starter on it anyway. They make starters for other engines as well.
#249
Hi,
i have just purchased esm zero and i want to put a pair of sierra retracts made for that plane.
Does anyone has any experience with sierra retracts;
i am worried that it would be difficult to put the strut covers because the strut scissors protrude at that side, which of course is the scale design.
