Reload this Page >
Warbird Cockpit, Mig-3 scratch built!
Old 07-06-2013, 01:19 PM
Avaiojet
Default RE: Warbird Cockpit, Mig-3 scratch built!
Continued:
ID:	1898120   Click image for larger version
ID:	1898121   Click image for larger version
ID:	1898122   Click image for larger version
ID:	1898123   Click image for larger version
ID:	1898124   Click image for larger version
ID:	1898125   Click image for larger version
ID:	1898126   Click image for larger version
ID:	1898128   Click image for larger version
ID:	1898129   Click image for larger version
ID:	1898130   Click image for larger version
Old 07-06-2013, 01:21 PM
Prekin
My Feedback: (19)
Prekin's Avatar
Really nice exhaust. Check your email.
Old 07-06-2013, 01:28 PM
Avaiojet
Continued:
ID:	1898132   Click image for larger version
ID:	1898133   Click image for larger version
ID:	1898134   Click image for larger version
ID:	1898135   Click image for larger version
ID:	1898136   Click image for larger version
ID:	1898137   Click image for larger version
ID:	1898138   Click image for larger version
ID:	1898140   Click image for larger version
ID:	1898141   Click image for larger version
ID:	1898142   Click image for larger version
Old 07-06-2013, 01:36 PM
Avaiojet
Continued:
ID:	1898144   Click image for larger version
ID:	1898145   Click image for larger version
ID:	1898146   Click image for larger version
ID:	1898147   Click image for larger version
ID:	1898148   Click image for larger version
ID:	1898149   Click image for larger version
ID:	1898150   Click image for larger version
ID:	1898152   Click image for larger version
ID:	1898153   Click image for larger version
ID:	1898154   Click image for larger version
Old 07-06-2013, 01:38 PM
Avaiojet
Continued:
ID:	1898156   Click image for larger version
ID:	1898157   Click image for larger version
ID:	1898158   Click image for larger version
ID:	1898159   Click image for larger version
ID:	1898160   Click image for larger version
ID:	1898161   Click image for larger version
ID:	1898162   Click image for larger version
ID:	1898164   Click image for larger version
Old 07-06-2013, 02:13 PM
  #31
Avaiojet
ORIGINAL: Prekin
Charles, you did a good progress with the fuselage.
I´ve just seen your work in CAD. Are you able to make a rivets for your Mig-3?
Yes, but I won't. It beats up my cutter!
I have a source to get them in Europe and another guy in the USA. Found them in a Thread on RCU.
Hey! Where else!!
I will, however, make some surface detail that won't beat up my cutter. Same kind of layering like I did for the cockpit side, floor and rear pieces. Just thick vinyl.
For the rudder, elevator, flap "aileron" area, and some fuselage areas. I may just make the vinyl in "reverse" and use a build-up primer, then remove the masks. this I've done a few times before.
Charles
Old 07-06-2013, 03:41 PM
  #32
vertical grimmace
vertical grimmace's Avatar
Sorry, but I guess the reason I mentioned the fin/rudder, is that it appears to be completely the wrong shape. Maybe it does not matter, but it looks more like a Nobler than a Mig 3 in the tail!
Look here: http://mig3.sovietwarplanes.com/mig3/gallery2.html
Old 07-06-2013, 05:08 PM
  #33
Avaiojet
ORIGINAL: vertical grimmace
vertical grimmace,
Thanks for the link, that's absolutely a great site. I have it in my favorites and have used it many times over the months.
Yes, you are correct, looks kinda like a Nobler, but certainly it doesn't look like a Mig-3's tail and rudder.
The reason is, as I explained in the Thread, was, the Mig-3 idea came about long after the lines of the model were drawn, designed and built.
Sure, I could change the rudder AND the stab/elevator, but what about those square wing tips, they are incorrect also. So is the wing aspect ratio and the taper. Not to mention the placement in the center of the fuselage.
This is a fun model that evolved into a Mig-3.
I do have CAD drawings in the works, for a true outline Mig-3, but undecided as to the size.
You have a good eye and must know your aircraft.
Charles
Old 07-07-2013, 08:04 AM
  #34
aymodeler
aymodeler's Avatar
ORIGINAL: Avaiojet
Charles,
Igot to say that I love the idea of a "fun" model! I understand that building scale is one kind of fun (and I aspire to the skills to build true scale myself someday), but it is also good to see that there is still room for a more relaxed approach too. Regardless of the true accuracy, your attention to detail and craftsmenship are truely impressive.
Al
Old 07-08-2013, 04:02 AM
  #35
Avaiojet
ORIGINAL: aymodeler
ORIGINAL: Avaiojet
Charles,
I got to say that I love the idea of a ''fun'' model! I understand that building scale is one kind of fun (and I aspire to the skills to build true scale myself someday), but it is also good to see that there is still room for a more relaxed approach too. Regardless of the true accuracy, your attention to detail and craftsmenship are truely impressive.Al
Al,
It is about having fun! Glad you realize that.
Hey! I know Hartford really well. I'm actually from NE.
Thanks for the reply.
Charles
Old 07-14-2013, 05:18 AM
  #36
Avaiojet
Some added photos of the scale Mig-3 cockpit to date.
Still a ways to go.
Charles
Can't get a photo on, I'll try later!
Old 07-15-2013, 10:49 PM
  #37
Avaiojet
Update with assembly.
ID:	1900964   Click image for larger version
ID:	1900965   Click image for larger version
ID:	1900966   Click image for larger version
ID:	1900967   Click image for larger version
Old 07-15-2013, 10:53 PM
  #38
Prekin
My Feedback: (19)
Prekin's Avatar
Hello Charles. It looks like a making a scale cockpits is could be your job!
This one is very nice.
Finally I´ve done my La-5 FN, now she is waiting for a maiden flight. After them I will buy some scale pilot.
ID:	1900969   Click image for larger version
ID:	1900970   Click image for larger version
ID:	1900971   Click image for larger version
Old 07-15-2013, 11:01 PM
  #39
Avaiojet
Prekin,
Hey! Hey!
Time difference!
OK, talk about your spinner?
Charles
Old 07-15-2013, 11:08 PM
  #40
Prekin
My Feedback: (19)
Prekin's Avatar
About my spinner? I draw a 3D model in Audesk Inventor. It was the first step.
After them, my friend made a steely model of the spinner for the fibreglass form.
And the last step was a making the fibreglass spinner.
Some other question?
ID:	1900975   Click image for larger version
Old 07-15-2013, 11:22 PM
  #41
Avaiojet
Prekin,
What about the base? Turned on a lathe?
Why not just use the aluminum one?
I thought you spun it?
Outstanding!!
Charles
Old 07-15-2013, 11:30 PM
  #42
Prekin
My Feedback: (19)
Prekin's Avatar
I used an aluminium base, which I had at home. It was a part of package of some other fibreglass spinner. http://www.topmodelcz.cz/index.php?&...nu_eshop_id=25
Old 04-19-2015, 11:53 PM
  #43
Avaiojet
Double Post.
ID:	2090386   Click image for larger version
ID:	2090387   Click image for larger version
ID:	2090388   Click image for larger version
ID:	2090389   Click image for larger version
ID:	2090390   Click image for larger version
ID:	2090391   Click image for larger version
ID:	2090392   Click image for larger version
Old 04-19-2015, 11:54 PM
  #44
Avaiojet
I've been busy and haven't had a chance to Post. Now I'll Post my progress with the Mig-3.
I changed the rudder but cannot change the wing. As I said, the model didn't start out as a Mig-3.
Old 04-20-2015, 12:20 AM
  #45
Avaiojet
Changed the rudder, covered the wings, fitted the OS LA .46 CL and the custom made tank. Close to detailing and paint.
ID:	2090396   Click image for larger version
ID:	2090397   Click image for larger version
ID:	2090398   Click image for larger version
ID:	2090399   Click image for larger version
ID:	2090400   Click image for larger version
ID:	2090401   Click image for larger version
ID:	2090402   Click image for larger version
ID:	2090404   Click image for larger version
ID:	2090405   Click image for larger version
ID:	2090406   Click image for larger version
Old 07-24-2015, 03:27 PM
  #46
Avaiojet
Here's some up to date photos.
ID:	2111020   Click image for larger version
ID:	2111021   Click image for larger version
ID:	2111022   Click image for larger version
ID:	2111023   Click image for larger version
