TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
#2776
My Feedback: (8)
RE: TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
ORIGINAL: Leroy Gardner
thunderbolt your right but my plane is being finished in the scheme of Cripes Amighty 3rd polished version and will have a very scale looking rivet detail. Rivets will be seen but suttle and not jump off at you. I have alot of pictures I've taken of a polished mustang besides the spec and 2&3 views of the plane used in the pannel lines and rivet detail. 5.000 is not even close to whats in the real plane but will present it well. Lots of work and it's looking good.Leroy
Roger that.
#2777
I was reading this thread a while ago and I thought there was a guy that mounted a DLE 55 with a soft mount and he ended up having his j'tec muffler come apart. Others chimed in and said you were not supposed to soft mount this engine as the vibration is isolated to the engine and causes issues. I completely agree that a soft mount sounds like the best way to go to save the plane, but I also don't want to damage the engine/muffler. I am not sure which way is best, but I do have plenty of time to decide. Have others used a soft mount with the jtec in-cowl p-51 muffler?
#2779
Spitfire if you follow the mounting instructions that came with the plane you'll be glad you did. Many of the guys don't have a clue about what soft mounts actually do. It's kinda like what would happen if your car engine, frig. compressor, furnace fan motorcycle and so on would sound like with out soft mounts and thats not to mention the distructive forces of vibration and high frequency modulation does to raido, servos, screws and glue joints,not to mention the engine mount itself. I'll show a well mounted engine and mount as an example, Leroy
I'll try later there is a server error and can't up load pictures.
#2780
I thought that it would be best to soft mount, and like your work. (crj driver) 6+ years without an issue! That's good enough for me! Leroy, nice work. That looks so well done.
#2781
I went to Home Depot and Lowes today to look at paint for the mustang later on down the road and had no luck. I was looking for Behr aluminum mettalic paint, but they said they haven't had it in 4 years or so. Same with Lowes. The only thing they have is Krylon spray paint. I found this Martha Stewart specialty paint that was called polished silver. It's $5.50 for 10 fluid ounces. I have no idea how much paint it will take, but I figured the quantity/cost to come up with a gallon and that would be about 13 jars of it. That would be around $70 for paint alone. What are other people using? I went to the hobby store and found testors sells spraypaint, but I was wanting to use an spraygun to get an even coat with no lines and also fuel proof.
#2782
My Feedback: (57)
Use Krylon Bright Silver. You can get it for 3 bucks a can at Wal Mart. This worked really well for my Jug. Just be sure to rub it down with 0000 steel wool. The result is a very convincing metal finish. It is not letting me post pictures right now. I'll try later.
#2784
ORIGINAL: spitfire66
#2785
ORIGINAL: CRJDriver
#2786
NC
I guess now all the rest of us have crappy paint jobs then. I will bet 75 percent of the Planes at Top gun this year were painted with House Latex outdoor paints. Why don't you take one of your birds down there next year and see how you fair with your 150.00 dollar paint job. I could care less what someone paints their plane with but for some reason you feel you are the only one who has the answer. You pushed your rivet detail all over the place with folks who have been doing much better for years, but at least I won't call any thing you got crappy I will leave that for you to do. Kevin.
#2788
http://www.alsacorp.com/
Try the killer chrome.. Several TG planes are painted with it.
Alu is really difficult to pull off in paint. The specialized automotive paints do the best job from what I've learned over the years. Or you can go with flite metal or similar. That works too.
#2789
Thanks everyone for the replies. I think I will try some of the krylon paints with/without clear coat, and then the "martha stewart" brand polished aluminum and see how they hold up. If the price gets over $100 I will spend $60 more and use the flite metal. I will do some testing this week. Thanks for the input.
The alsa corp stuff looks really nice, but too close in price to the flite metal for the whole kit. Thanks for the suggestion!
#2790
I found some a paint called chrome/aluminum that is used for propane tanks and fences. I'll buy some today and do some testing. My goal is a fuel proof paint that looks good (not top gun quality) and doesn't flake or rub off. Top Gun quality would be nice, but this is my first giant plane and I'm looking to gain quality experience while saving some money in the process. Some day money will be no object right?
http://www.acehardware.com/product/i...Id=61346231373
#2792
ORIGINAL: crashproof
Glad you have seen my pannel lines and rivets. I did that thread to show that anyone can learn to do it even you and I never said it's the only way to do it. You should try reading that thread and you too may learn something. Leroy
#2793
My Feedback: (133)
OR
leroy down boy, down!!!!!!!!! your drinking too much coffee i think!!!!!!!!! too much hostility!!!!!!! this thread is for the fun and not arguments!!!!!!
#2794
I used some grey primer and used some chrome aluminum paint today. I had the old p-51 that I started on and then though it wasn't good enough. Anyway I'm using that as my test subject for paint, and later to experiment with glassing. The picture is after 1 coat of paint. A minute ago I added coat #2. I think it looks awesome, but I had to brush it on as I don't have an airbrush. The problem with brushing is you can see the brush lines.
I am going to use a small spray gun that my dad recommended from harbor freight. He said he has used his a couple times and the one he has would work great. It says thinning is not recommended, but I figure I could do a very little bit if needed. There is a lot of metallic gunk in the bottom of the can that you have to really stir up well, and has raised my concern about clogging a gun. Maybe if I stir is up enough and use a coffe filter that would prevent issues? Well, if you can't tell I haven't done this kind of stuff before, but I am very eager to learn. If it wasn't for the brush lines I'd be really happy with the experiment so far!
Next I will be applying a clear coat to see if it gas proof and smear proof without changing the color and appearence. I'll keep you all posted. I am on my days off and would really like to get this figure out.
#2795
I value everyone's opinion. It helps me to hear everything and then draw my own conclusion. Please, no hostilities. I understand both of your arguments.
#2796
MN
HI Guys
What I have found over the years is that, the Krylon paints get very brittle over time and you get spiderweb cracks all over. Auto paints seem fairly brittle also. I use to use lacquar a lot, but found that brittle. The paint I have used for a few years now is the Stits paint. Their paint is used on fullsize and is sold for modellers thru F and M products in Texas. They have a fillercoat for the fabric they use called Polyspray. It is silver and has aluminum particles in it. It dries semi flat and is fuel proof. I have had it on my P-51 for four years now. Looks very much like dull aluminum. The other thing is that it doesn't finger print or come off in your hands. The paint is a one paint process and dries very fast. Similar to dope or lacquar. Just another option
#2797
ORIGINAL: fujiman
My responce was not hostile but was truthful. When context of a remark is blown that far out of perportion than it needs to be addressed to get it right. I don't come here to ruffel feathers, I come here to help or learn.
Sorry, it could have been said in a different way and still ment the same thing. Leroy
#2799
I've been looking for a good clearcoat that is resistent to gasoline. After rereading Tom Pierce's blog I found he used nelson's hobby clear for a gasoline proof clearcoat. I am going to use that. If you need information, like myself and are really a beginner go go tompierce.net It's great information.
