TF 1/5 Scale P-51 ARF Assembly (1ST MISHAP!!!)
#4076
I had a pretty good flying day but bent a strut. Totally my fault. I kept wanting to plant the tail early on touchdown and I sent it airborne again and plopped it down. Little bit of a crosswind so I think that’s what made me rush it. Does anyone know if this strut is a 145 series or just an older 622 strut with the threaded tubes? The new 622 don’t have them.I bought these second hand off an old top flite kit.I called robart and left a voicemail so I’ll see if the top ole is are interchangeable. I really like the threaded tubes perpendicular to the scissors for door mounting.
#4078
My Feedback: (9)
IL
Has anyone have ever used a different brand covering that matches the Monokote Aluminum color on the P51? I want to purchase Hobbykings Solid Silver or Bright Silver, but wasn't sure if their color matches the Monokote. Thanks.
#4080
If anyone has a new in box tf P-51 ARF they are looking to get rid of pm me please! I’m doing a spychalla B-conversion so must be new. My buddy and I are looking to do a dual build. I love this model!
#4081
AL
Hello all. Has anyone used the aileron differential called for in the manual? I've searched this thread and saw no mention of it. If you have, what kind of handling differences did you see?
Thanks!
Thanks!
#4083
I want to make a scale 4 blade prop for my Pica 1/5th scale plane I'm working on any suggestions! mine is electric so the shaft is not an issue and I have an extra 5" alum spinner.
#4085
My Feedback: (10)
CA
Check out www.aircraftinternational.com. They carry Biela scale props in 4 blade versions in many different blade styles and sizes.
#4087
I received my replacement wing from horizon today. It arrived in perfect condition and the covering is absolutely flawless. No ironing required, although it will be a shame when I tear it off and glass it for paint. I’ll do the mods to the gear mounts again. I doubt the shear webs have been upgraded (I say added) as they really aren’t structural in this wing. It was thin balsa on the last wing like a build gig. Ply will be added
#4089
Does anyone happen to have the instructions or pdf for doing the scale wing dihedral mod? I have the sierra gear with the 85 degree blocks. I can’t seem to find my instructions.
