Reload this Page >
P-47 Thunderbolt Brotherhood (All P-47s Welcome)
Old 07-26-2016, 07:20 AM
  #1576
KaP2011
My Feedback: (17)
KaP2011's Avatar
Question for you P 47 guru's. Does the P 47 "Snafu" have landing lights? If so, where are they located and did the same plane have landing lights during WW2?
Old 07-26-2016, 09:48 AM
  #1577
Duplicator41
Duplicator41's Avatar
The answer is yes to both and it's located in the left wing behind the landing gear. Rotates down when deployed.
Cheers,
Old 07-26-2016, 11:02 AM
  #1578
KaP2011
My Feedback: (17)
KaP2011's Avatar
Thanks Duplicator41, so there is just one. That's what I needed to know. I've been looking for a picture of the landing light with no luck, has anyone ran across a picture of it?
Old 07-26-2016, 11:15 AM
  #1579
KaP2011
My Feedback: (17)
KaP2011's Avatar
Never mind on the pictures, I did another search just now and found plenty of pictures.
Name:	P47 Landing light.jpg
Old 07-26-2016, 11:19 AM
  #1580
Calil
Could someone share a link about the "Snafu" history? I couldn't find it anywhere!
Old 07-26-2016, 11:46 AM
  #1581
HoundDog
My Feedback: (49)
HoundDog's Avatar
Cheers,
Hey there Mr.Duplicator41 What do U know about the 3 colored light under the right wing near the tip, on some P-47's like these on TarHeel Hal?
Old 07-26-2016, 11:19 PM
  #1582
flyer1977
https://www.youtube.com/watch?v=8rXviOJiK48
Old 07-26-2016, 11:31 PM
  #1583
Chad Veich
My Feedback: (60)
These are recognition lights. See the link for some discussion of their use.
http://www.warbirdinformationexchang...b6b44&start=15
Old 07-31-2016, 05:08 PM
  #1584
big fred
yellow # 2
ID:	2175323   Click image for larger version
ID:	2175324   Click image for larger version
Old 08-10-2016, 09:58 PM
  #1585
bigstew60
My Feedback: (35)
Here is my tf giant p-47, just had its maiden flight today.
Old 08-14-2016, 04:00 PM
  #1586
acdii
Just about ready to maiden mine. H9 150 Razorback. Few more hours to tidy up the wiring, adjust the throws and balance it. Ran up the engine today with the full cowl and dummy engine installed to make sure it runs cool and it does.
Old 08-14-2016, 11:31 PM
  #1587
Calil
Thats a beauty!!
Congrats!!
Old 08-15-2016, 10:06 AM
  #1588
Prekin
My Feedback: (19)
Prekin's Avatar
Is anybody here interested in 85" Razorback sliding canopy frame set? I´m thiking to prepare a fibreglass set as for 80" La-7.
Name:	La frame set.JPG
ID:	2177019   Click image for larger version
Old 08-15-2016, 01:50 PM
  #1589
Greg Wright
Greg Wright's Avatar
Here are a few pics from this past weekend when i did a remaiden on my CARF p-47 after it was repaired.
ID:	2177033   Click image for larger version
ID:	2177034   Click image for larger version
ID:	2177035   Click image for larger version
ID:	2177036   Click image for larger version
ID:	2177037   Click image for larger version
ID:	2177038   Click image for larger version
ID:	2177039   Click image for larger version
Old 08-15-2016, 01:58 PM
  #1590
David Eichstedt
My Feedback: (17)
Also a Hangar 9 Razorback, modified to be a bubbletop. Zenoah G45, Robart air retracts. Maiden soon.
Old 08-15-2016, 04:06 PM
  #1591
acdii
Originally Posted by Calil
Thats a beauty!!
Congrats!!
Thanks, eager to fly it, but not until I am 100% sure everything is working. The servos have me on edge, they chatter. What's interesting is after moving them for a while they stop chatter and work fine, but with a plane like this, I may swap them out with Futaba 3010's. They are MPI metal gear servos. Already had a flap servo quit on it. Out of the 8 servos only four are working smoothly.
Old 08-16-2016, 04:54 AM
  #1592
KaP2011
My Feedback: (17)
KaP2011's Avatar
I had that same problem recently with some Dymond metal gear servos, turned out to be that I had one of my receiver antennas too close to the servos. Once I re-positioned the antenna the problem went away.
Old 08-16-2016, 07:52 AM
  #1593
sjhanc
sjhanc's Avatar
RROMANO , On a "short nosed" plane like the P-47, every ounce of paint,detail, and equipment you add to the tail needs 8-10 ounces of weight added to the nose to get the CG right. My attempts to balance a new stock 60CC H9 P-51D were frustrating as I had previously built an identical plane that had not needed any nose weight. I naturally tried to copy the first plane's equipment installation and was stunned to find that it needed a full pound of lead in the SPINNER to correctly balance it. I had to remove the elevator servos from the horizontal stabs and install heavier servos at the CG, on either side of the fuel tank. Then I had to dig up some out-of-production Sullivan carbon-plastic elevator control rods (very light) and install them in the aft fuse. This helped the CG a lot but more was needed. The stock tail control surface hinge pins are steel and weigh about 3 ounces so I replace all 3 with .080" carbon rods from Tower hobbies. To finish it off I rebuilt the two 5 cell nicad receiver batteries (light weight batteries would not help here) so that they would fit right up against the firewall (this moved Over 20 ounces from the tank area forward about 8 inches. Some other radio equipment had to be moved to facilitate the elevator control rods. The end result is a 27 lb. 5 oz. plane that needs no extra nose weight and I did not have to adjust a single trim for level flight during the test flights.
If you are refinishing an older plane, especially with a glass finish, you need to take special care to not add weight where it will cause you grief when it is time to balance the plane. Almost everything you do in the tail will hurt you. I use lacquer sanding-sealer sprayed over bare wood and sanded smooth to prevent the fiberglass resin from soaking in and adding unnecessary weight. Then drape the lightest glass cloth you can find over the surface and apply only enough resin to adhere the cloth to the surface (if this fills the cloth weave you have too much resin). You can remove excess resin by rolling toilet tissue rolls over the uncured resin, tear off the saturated tissue and do it again. Then, after the resin cures, fill the glass cloth weave with light-weight painter's spackle compound spread thin with an old credit card. Sand the spackle smooth, then spread a thin layer of thinned resin over the whole surface and let it cure hard. The result won't need much sanding and if you are doing panel lines and rivets these can be done at this point by applying masking tape, spraying primer only on the tape lines, then feather sanding down to the tape. This method rivals plastic film for lightness and is dent resistance and if you can get a very light finish coat of paint on it, you won't need to add much nose weight.
I used this method on a TF GS P-51B several years ago and ended up with a 29 lb. model ready to fly and no extra ballast.
Old 08-16-2016, 04:30 PM
  #1594
acdii
They only chatter when they move, and only 4 out of the 8 do that. Still going to move the RX to the side and back a bit mainly due to vibrations from the DLE30. One flap chatters, ailerons chatter, and the left elevator chatters. They are rock steady at idle, and only chatter in the mid range. I notice that after I move them for a while they stop chattering and move OK. It is almost as if they need to be broken in. In any case, going to switch them out with Futaba 3010 servos instead. The recommended servos are 60 oz plastic gear standards.
Old 08-17-2016, 08:34 AM
  #1595
harley1340
building an esm p-47. Thinking about using an eflite 25-46 size nose wheel retract for the tail wheel retract mounted on a beam, all bulkhead retractable units are too big. Anyone with ideas? Thanks Art.
Old 08-17-2016, 12:22 PM
  #1596
MarioJuan
Hello. Would you please sign me up? The attached pictures are of my 1/6,4th scale P47D built from the Brian Taylor plan. I wish I had built it with panel lines, rivets and more detail including the colors! I am playing with the idea of building this same airplane but with the bubble canopy, electric propulsion and the Benidini sound system. I think that the warbirds designed by Brian Taylor are amongst the most eye catching models ever!
Best Regards from the Northwest of Spain.
ID:	2177293   Click image for larger version
ID:	2177294   Click image for larger version
ID:	2177295   Click image for larger version
ID:	2177296   Click image for larger version
ID:	2177297   Click image for larger version
Old 08-19-2016, 03:29 PM
  #1597
HoundDog
My Feedback: (49)
HoundDog's Avatar
Anyone Know anything about a P-47 Razor Back named Ridge Runner. Need Pics and BRU. No.
It flew with the 368th fighter group. This is the only thing I can find. Need a lot more INFO.
Old 08-19-2016, 04:56 PM
  #1598
David Eichstedt
My Feedback: (17)
Got my maiden done last Tuesday evening. Been flying it at Fon du Lac - 5 great flights today! G45 is being totally reliable and I'm a happy man.
Old 08-20-2016, 09:41 AM
  #1599
Prekin
My Feedback: (19)
Prekin's Avatar
Anybody here is able to recognize following paint schemes and know which units had this colours?
ID:	2177623   Click image for larger version
Old 08-20-2016, 01:51 PM
  #1600
David Eichstedt
My Feedback: (17)
56th fighter group
http://www.56thfightergroup.co.uk
