P-38 Lightning Brotherhood
#1251
My Feedback: (13)
Hay Guys,
I need a set (or three sets really) of 14x7x3 props with one counter rotating (for 20cc gas engines). Can anyone direct me to a source for these props.
I just was delivered a P-38 ARF from James Fraser of JB hobbies. The model arrived with the best packing I have ever seen (three outer boxes) for an ARF model and it had no damage. I have two DLE20RA cc gas engines (one engine counter rotating) going into the model. Two other gentlemen have built and flown the model with these engines and said it was a good match, and with a vertical presentation that has to be seen to be believed. It has a full set of gear doors, electric retracts and painted with WWII invasion stripes, over a olive green base color. This is my second VQ P-38J and it is very scale. They cleaned up the wing flap attachment that was such a hassle on the first addition kit issue too and this takes out the hassle of connecting the flaps (by the way...all four flaps are full fowler style). The quality control looks good and James at JB Hobbies was a sweet heart to deal with.
I built a 90" Nitro Plane P-38 with two K&B .61 Twisters for power and it came out to 18 #'s ready to fly. I had to install two Perry oscillating pumps to get the fuel to the engines and with the fuel tanks so low...and the engines so high...it was the only way to go for these engines. It has removable stab and the whole model breaks down so It will fit into my VW van. It takes a bit to put it together at the field, for it has six parts to assemble and dozens of servo connections. It also has a set of Spring Down retracts installed and onboard glow.
I pondered the larger model P-38 that you gentlemen are bailding but by the time it is ready to fly...you have close to $4k into the model this way...I have a P-38 in the air with gas engines under $2K. And I have a ton of spare parts from my first kit.
I also built a really cool P-38 stand to assemble the model and run the engines at the field. Its cool and works like a charm.
This wil be my fifth P-38 I have built and flown.
Soft Landings Always,
Bobby of Maui
Bobby of Maui
#1252
Hay Guys,
I built a 90" Nitro Plane P-38 with two K&B .61 Twisters for power and it came out to 18 #'s ready to fly. I had to install two Perry oscillating pumps to get the fuel to the engines and with the full tanks so low...and the engines so high...it was the only way to go for these engines. It has removable stab and the whole model breaks down so It will fit into my VW van. It takes a bit to put it together at the field, for it has six parts to assemble and dozens of servo connections. It also has a set of Spring Down retracts installed and onboard glow.
I pondered the larger model P-38 that you gentlemen are bailing but by the time it is ready to fly...you have close to $4k into the model this way...I have a P-38 in the air with gas engines under $2K. And I have a ton of spare parts from my first kit.
I also built a really cool P-38 stand to assemble the model and run the engines at the field. It cool and works like a charm.
Bobby of Maui
Bobby of Maui
So, yes, you're getting a bargain
#1253
My Feedback: (24)
[QUOTE=Bob Paris;12271930]Hay Guys,
Here's a couple links to Master Airscrew 14x7x3 CW and CCW http://www3.towerhobbies.com/cgi-bin...?&I=LXAPX4&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXAA40&P=7
#1255
My Feedback: (13)
Hay 70 ragtop,
Thank you for your help...I just ordered three sets of props. I am also ordering two metal spinners for my P-38. I had a plastic spinner explode on start up and if I didn't have glasses on...I may have been blinded.
Hay zrooster,
I planned on using a pair of PTE 36's I had on hand for the model...and just build as light as I could and go simi-scale. No cockpit, or other really scale stuff like you pro's build. I do love to build...but we have only one flying field on Maui...and it is really not worth it to build a model that complex with all the goodies and see it end up in a pile of balsa. Our winds are crazy here...and our runway 600 ft long with barriers (WWII resentments on the approach end). I felt by using the gear I have on hand...with a full kit...I could get it built for near $4K...maybe. Your right...it is not a cheap kit to build that is why I called James and ordered the VQ P-38.
Thanks guys for all your help...and when I start the build...I will do it here in this column.
Bobby of Maui
Hay zrooster,
Bobby of Maui
#1256
Hay 70 ragtop,
Hay zrooster,
Bobby of Maui
Hay zrooster,
Bobby of Maui
This is my grand project, and likely the only one I'll do on this scale (to this extent, that is).
Good luck on yours...you'll probably have yours flying before I get two sticks glued together!
#1257
My Feedback: (9)
Its a Rocket Car!!!
Hey, I thought you guys may like to see this.
Its a Rocket Car - I used this way back in the day for airshows with the TRCC Show Team.
This is a short shot on a short grass field, (not a runway) so things fail and that makes for a crazy ride!!!
https://www.youtube.com/watch?v=xCR3F-NU5r0
<iframe width="400" height="225" src="https://www.youtube.com/embed/xCR3F-NU5r0" frameborder="0" allowfullscreen></iframe>
#1258
My Feedback: (9)
P-38 Death Dealer & Pacific Aviation Museum
I am posting this in my groups & for the forum thread.
The P-38 Death Dealer was proudly displayed last week at this years Pacific Aviation Museum and Warbirds West Airshow along with the Thunderbirds at the "Wings, Wheels and Rotors" event in Longbeach Ca.
Pacific Aviation Musium Members from Pearl Harbor's Ford Island Museum were on hand to work with the youngsters on how the future of aviation is being molded by technology advancements "While" preserving the history & sacrifices our men and woman made and continue to make in active service.
Kenneth "Ken" DeHoff (Director of the Pacific Aviation Museum) worked tirelessly with the 30k plus crowd as they patrolled through the display area behind the flight lines shared with the Thunderbirds.
What an amazing event that was made possible by the tireless efforts of Michael Fetyko of Warbirds West scale flying team. His efforts working with upper echelon military brass ensured the history of aviation and the stories of the people who were there are remembered at these historic events.
Pictured is the P-38 on display with its working ground crew and battle damage from Iwo Jima.
Also Pictured is Ken form Pacific Aviation museum working with the flyers of tomorrow. If you are ever looking up history on Pearl Harbor don't forget to visit the Pacific Aviation museum on Ford Island. www.pacificaviationmuseum.org
Oh Yah! and the Thunderbirds parked at night next to our tent!! (bad photo sorry it was raining that night)
We are working on a new show for 2017
R.I.P. - R.A. Bob Hoover
#1259
What an amazing event that only made possible by the tireless efforts of Michael Fetyko of Warbirds West scale flying team. His efforts working with upper echelon military brass ensured the history of aviation and the stories of the people who were there are remembered at these historic events.
#1260
My Feedback: (7)
I worked hard last winter to build Fowler flaps for my ole heavy-landing CBA-38
DA helped me get the counter-rotating engines perfectly tuned and I finally found some 20-12 Xoar props that are perfect for the DA-50's
Sadly, I have not been able to take advantage of some of the fabulous fall weather lately because of an illness in the family
She's Ready to Go!
I promise to post video no matter how she "goes!"
She's Ready to Go!
#1261
Royal p38 kit
Hey folks i hope it is ok to mention have a royal-kit that needs a home
you can send me a pm if so. Its a builders kit the box has wear but its complete with 2 sets of plans and 2 builders guides
Thank you Joe
Thank you Joe
#1262
MA
Hello Kram. I to am finishing up my CBA p38. It has not flown yet even thoe ive had it for many years. I just finished putting DA 50s in place of the old A&M 3.2 engines. Also I added flaps but just did conventional flaps. Perhaps upgrade to fowler flaps some day. I was wondering what you did for mufflers on yours. This is my last piece to the puzzle. I may need Jtec to custom some for me. Also im hoping the 50s are enough power. Plane is a little under 50 lbs. Goal was to fly at the Nall this year but only if we can have several susesful test flight ahead of time.
Dave
Dave
#1263
Bill at Slimline just built me a set of Pitts style mufflers for my DA50 powered Yellow P-38. They are small and totally fit inside the cowl, but they are a bit noisy. He made drawings so they should be easy to duplicate. $400 for the pair.
#1266
My Feedback: (7)
Dave:
You can see from these re-plumbing shots I took last fall whoever installed the DA-50's in mine carved out some of the bottom firewall to give room for what I think is a standard DA Pitts-style muffler
It works well comes apart easily when needed
Plane flies very well at 50+ lbs on these engines: not a screamer but you don't want it to be
Jeff's flies very nicely on G-62's with similar 3 B props: about the same power
#1267
MA
Thank you Kram and pull-up. Looks like I will follow similar muffler installation. Kram, its nice to know it flys well with the 50s. Im not looking for a screamer either, just hoping it isn't a struggle to stay in the sky.
Dave
Dave
#1269
My Feedback: (13)
Dear David,
If you can wait a couple of days I will. I am on my way home tomorrow and will arrive back in Maui on March 2nd. It will fit any P-38 and worked on my 90" and 84" P-38's. You can retract your landing gear or start your engines on the stand and supports the engine nacelles and wing, up against the pilot pod.
Bob
Bob
#1270
My Feedback: (13)
Flyingpiggy,
I found the pictures you wanted-not all, but this will give you an idea of what I built. If you need more...when I am home, I will give you more with dimensions. The foam is missing from the stand that the model rested on, but the first picture is the full stand, the other pictures are missing the aft engine fuselage support.
Bobby of Maui
Bobby of Maui
#1271
My Feedback: (7)
David68:
Not at all a struggle to stay in the air.
Landing has been an issue, however. It falls like a manhole cover below what I estimate to be 35-40 mph: much faster than all my other 38's
I hope the addition of four Fowlers will tame it, but I can't vouch for that personally
Jeff's comes in smooth and soft with 4 Fowlers, but he's a lot better pilot than I am
You need at least 600 ft of grass runway with clear approaches to get 'er up and down safely
Mark
Mark
#1272
MA
Thanks Kram. I also need to ask about balancing. Somewhere I have an old vcr tape from CBA showing a few construction details and balancing. I cant place my fingers on the tape plus i no longer have a vcr. If i remember correctly, they assembled the plane but left the wing tips off. Then they slid a pipe into each wing tube socket with about 12 inches hanging out of the tubes. They then set the tubes on jack stands to balance. With the gear up it rotated slightly nose heavy. With the gear down it got even more nose heavy. Does this seem correct?
Dave
Dave
#1273
MA
Kram, I also have flaps but I got lazy and made 4 standard split flaps instead of fowlers. My theory was if the plane survives some flights, i could upgrade to fowlers. Maybe mine will land more like a composit manhole cover instead of a cast iron one. Lol.
