Blohm & Voss BV-138 Sea Dragon 1:8 scale
Reply
Old 03-20-2014, 07:59 PM
  #101
splinterz25
splinterz25's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm looking at the machine gunners position an arch needs to be made for the sheeting to follow.
The aft end of the fuse really falls off fast down to the turret.
Bruce
splinterz25 is offline
Old 03-21-2014, 01:53 PM
  #102
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay guys I started on the aft machine gunners station today.
I'm making this whole section so it can come out in one or two pieces and go back easily when the wing center section goes on for the final mounting.
I was going to make the top ribs in spruce but have changed my mind they will now be made out of 1/8" light ply.
I'm going to cut most of the way through the top of former #14 so when time comes to remove that part it will be easy w/ a few Dremal cuts.
Check the days progress,
Bruce
ID:	1980227   Click image for larger version
ID:	1980228   Click image for larger version
ID:	1980229   Click image for larger version
ID:	1980230   Click image for larger version
ID:	1980231   Click image for larger version
ID:	1980232   Click image for larger version
Old 03-21-2014, 11:07 PM
  #103
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Martin5465 View Post
Bruce, what "whole section" is going to come out? Are you saying the aft part of the nacelle will be removable? I might have missed something here.................
Martin the parts I'm making now will all be removable until I'm ready to glue in the center of the wing, I had to go out this evening but had the idea fresh in my mind so when I got home I stayed up and keep on working.
All of these parts lock in place w/ out glue just a few clamps
check it out,
ID:	1980353   Click image for larger version
ID:	1980354   Click image for larger version
ID:	1980355   Click image for larger version
ID:	1980356   Click image for larger version
ID:	1980357   Click image for larger version
ID:	1980358   Click image for larger version
Old 03-25-2014, 10:23 AM
  #104
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I've not been well since the weekend and I'm not sure what's wrong but I couldn't even focus on anything for length of time until today.
So I went down stairs and did some simple things, I need more of the fiberglass sheet I used for the hinges on the rudders; so I thought I would lay up some of that.
This is also a test to see how the resin is working because it's snowing again here in Maryland.
I've also made some more parts to connect the sides I was working before; these will
make the sides one piece and they'll be easier to install when I'm ready.
The other thing is the slow boat from China arrived w/ the micro servo; it only took 25 days and Hobby King ing up my bank account to get it, I've not had a chance to try it yet?
No photos this time not much to show,
Bruce
Old 03-25-2014, 11:16 AM
  #105
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks busy! Man you are a machine!
Casey
glazier808 is offline
Old 03-25-2014, 02:15 PM
  #106
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Casey I BET IT'S NOT SNOWING THERE LOL
I finished making my fiberglass sheeting for the rest of my hinges; and the resin works well but this is the fast dry kind.
I ran a test on the turnigy micro servo and it seems very strong no gidders or humming; it even comes w/ a metal horn/ arm.
Still going to run a few more test though.
Then I put a few new pieces on the center section so it can come off in one piece.
I also bent some 1/8" balsa to see how it will bend; to do this I soak it in almost boiling hot water for 10 min, my tap water in my house is this hot.
I bent it around a can w/ the correct shape and rubber banded in in place let it dry a few days; looks really good it's the whole top radius, all that is needed is to add some flat sides to take it all the way to the bottom.
This is good no need for planking w/ all of the glue mess and w/ 1/8" thick balsa and my frame work no need for stringers either.
If I can bend this I should be able to do the same w/ the booms only w/ a longer piece.
I'll make a tube / cylinder w/ a bottom & top to hold a full sheet fill it w/ very hot water; I'm not worried about raising the grain here it's 1/8" thick and can be sanded w/ little worries of going through.
Hope to do more tomorrow,
Bruce
ID:	1981409   Click image for larger version
ID:	1981410   Click image for larger version
ID:	1981411   Click image for larger version
ID:	1981412   Click image for larger version
ID:	1981413   Click image for larger version
ID:	1981414   Click image for larger version
ID:	1981415   Click image for larger version
ID:	1981417   Click image for larger version
ID:	1981418   Click image for larger version
ID:	1981419   Click image for larger version
ID:	1981420   Click image for larger version
ID:	1981421   Click image for larger version
ID:	1981422   Click image for larger version
ID:	1981423   Click image for larger version
ID:	1981425   Click image for larger version
ID:	1981426   Click image for larger version
ID:	1981427   Click image for larger version
Old 03-25-2014, 06:31 PM
  #107
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Feeling much better I should make some headway tomorrow.
Does any body have a link for a slimline / wing servo w/ good power that also has a good track record that's not $100 ea.
It has to be just at or thinner than 1/2" to fit
Bruce
Old 03-26-2014, 02:14 PM
  #108
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what I've just spent the day working on was the firewall angle; it's NOW 2 degrees, I had to make changes to my finger joints and remove the triangle glue blocks.
SO IT'S LIKE THIS... the wing is set at 3 degrees incidence off the center line of the FUSE ; the center engine is set at 2 degrees up thrust off the center line of the FUSE, this still may have to be changed once flown.
The booms engines ARE SET AT 0 DEGREES INLINE w/ the center line of the FUSE.
Getting this right took me much longer than I thought it would today; but I was able to get the other pieces parts drilled and glued in place on the temp. removable center section.
I'm going to eat something and head back down stairs; I want to look at cutting in the air intake into the bottom portion of the center firewall.
There should be a really nice natural air flow through the center section and out the gunners station.
I know water is going to get in this planes hull so I'm already looking a bilge pumps; and will run 2 - 6V nicad batteries on this plane, I don't want lithos.
Check it,
ID:	1981649   Click image for larger version
ID:	1981650   Click image for larger version
ID:	1981651   Click image for larger version
ID:	1981652   Click image for larger version
ID:	1981653   Click image for larger version
ID:	1981654   Click image for larger version
ID:	1981655   Click image for larger version
Old 03-27-2014, 10:35 AM
  #109
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So my brain has started working again and I have been thinking
about what kwik said awhile back about getting to the fuel tanks if there's a leak.
There will be a hatch to get to the hoses but there would be no way to change out the tank; so I came
up w/ a new plan, there will be a sub plate that the firewall will bolt to w/ T-nuts, the center engines set up is not that hard but the booms will be a bit of work; better now than later though.
I've also came up with the idea for the air intake under the center engine to try and keep water from getting in as much; on the scale plane there's a horizontal louver inside the intake if I can make this close when flaps are down this should help, once in the air flaps up it will open giving great air flow.
The center engine gets two intakes, the booms only one I'm still working on the booms out going air; looking at the scoops under the booms for that.
The removable center truss system is now all glued together and all the formers notched to fit.
There's still so much to do on this center section; there is a scale hatch on the top in front of the
machine gunners station that will be great for the electronics to keep them up high away from water.
Then there's the flaps these are going to be very tricky there's in board and out board flaps; the in board are easier than the out board because of the removable wing tips.
I'f I can, there's a small section of the out board flaps that is under the boom and remains when the wing tips are removed; this section either will have to move w/ the inboard servo or when I plug in the wing tip I have a tube & dowel line up as well.
This is one of those parts that would get broken very easy if this is not done well.
And I still have to finish boom two's aft end. [:P]
I love this stuff I never stop thinking []
ID:	1982020   Click image for larger version
ID:	1982021   Click image for larger version
ID:	1982025   Click image for larger version
ID:	1982026   Click image for larger version
ID:	1982027   Click image for larger version
ID:	1982028   Click image for larger version
ID:	1982030   Click image for larger version
Old 03-27-2014, 11:24 AM
  #110
Joespeeder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hisplinterz25,
Great work !! I've always loved this plane and was following a thread on a kit development over at RCG's a few years ago but that just kind of died with no real progress.
At the rate you're building you should be ready for Toledo !!!
Thanks for all the posts and detailed shots of your progress it's been great fun to watch and check in as you go.
Joe
Joespeeder is offline
Old 03-28-2014, 04:35 AM
  #111
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Joe welcome on board I'm glad there's another guy following along here on RCU there's not many; there really not interested in these kinds of builds here it seem these days it's just kit bashing putting an ARF together is considered building a kit?
To each there own; GLAD TO HAVE YOU ON BOARD
It will be at least a year before Toledo LOL
Bruce
Old 03-31-2014, 05:41 AM
  #112
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi everybody... I didn't do anything on the plane this weekend but think about the next steps.
I want to have a really good look at the Flaps look and position there's very little info on these.
While looking for info on these I found out the AILERONS, ELEVATOR & RUDDERS are tinplate & fabric; FLAPS are all tinplate.
The flaps have an internal hinge/ turn axle like rudders and the inner set deflect 30 degrees and the outer 60 degrees; the other control surfaces are all just under 30 degrees deflection.
The Aileron hinges and control arms are external but I can't find any close up shots to make duplicating them easy?
For the flaps I would like to have one servo for each side, run the inner and outer and still have the wing tip easily removed.
So today I'll start by removing the center section of the wing and put the fuse to the side; while I'm figuring this out I'll also work on boom #2 and bring it up to where the first one is.
Things will slow down now for a bit because there's very little to go on I'll be making it up as I go
trying to copy other German planes when I can't find any info on this one.
Control surfaces
Horizontal Stab and elevator
Total area &n bsp; &n bsp;16,56 m2 &nbs p; &nbs p; (src: Handbuch)
Depth & nbsp; & nbsp; 2,45 m ; ; (src: Handbuch)
Horizontal stabilizer:
Area &n bsp; &n bsp;10,67 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 7,20 m ; ; (src: Handbuch)
Depth & nbsp; & nbsp;1,54 m ; ; (src: Handbuch)
Attitude against horizontal &n bsp; +5? +2? &nb sp; &nb sp; (src: Handbuch)
-4?
Material &nbs p; &nbs p; Tin-plate & nbsp; & nbsp; (src: Handbuch)
Elevator:
Total area &n bsp; &n bsp;5,89 m2 &nbs p; &nbs p; (src: calculated)
Area behind turnaxle, including trimmrudder 4,34 m2 &nbs p; &nbs p; (src: Handbuch)
Counterbalance area &n bsp; 1,55 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 7,00 m ; ; (src: Handbuch)
Depth with counterbalance part &n bsp;0,915 m ; ; (src: Handbuch)
Depth without counterbalance part 0,675 m ; ; (src: Handbuch)
Position of turnaxle from backward edge 27,5 % ; ; (src: Handbuch)
Deflection upwards ; 29? &n bsp; &n bsp; &n bsp; (src: Handbuch)
Deflection downwards &nb sp; 27? (src: Handbuch)
Material &nbs p; &nbs p; Tin-plate and fabric (src: Handbuch)
Trimming rudder:
Area &n bsp; &n bsp;0,348 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 2,05 m ; ; (src: Handbuch)
Depth to turnaxle &nbs p; 0,15 m ; ; (src: Handbuch)
Material &nbs p; &nbs p; fabric &nbs p; &nbs p; (src: Handbuch)
Vertical Stabs and rudders
Total area &n bsp; &n bsp;12,60 m2 &nbs p; &nbs p; (src: Handbuch)
Vertical stabilizer:
Area &n bsp; &n bsp;2x 4,12 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth (height) &nbs p; 2,70 m ; ; (src: Handbuch)
Depth midheights (length) &nbs p; 1,53 m ; ; (src: Handbuch)
Vertical rudders:
Area behind turnaxle, including trimmrudder 2x 1,59 m2 &nbs p; &nbs p; (src: Handbuch)
Counterbalance area &n bsp; 2x 0,59 m2 &nbs p; &nbs p; (src: Handbuch)
Depth with counterbalance (length) 0,95 m ; ; (src: Handbuch)
Depth without counterbalance (length) 0,65 m ; ; (src: Handbuch)
edge, midheights &n bsp; 28 % ; ; (src: Handbuch)
Deflection inwards ; 29? &n bsp; &n bsp; &n bsp; (src: Handbuch)
Deflection outwards &nbs p; 29? & nbsp; & nbsp; & nbsp; (src: Handbuch)
Trimming rudders:
Area &n bsp; &n bsp;2x 0,143 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 1,425 m ; ; (src: Handbuch)
Depth (length) &nbs p; 0,100 m ; ; (src: Handbuch)
Ailerons
Total area: & nbsp; & nbsp;2x 3,07 m2 &nbs p; &nbs p; (src: calculated)
Area behind turnaxle &nbs p; 2x 2,30 m2 &nbs p; &nbs p; (src: Handbuch)
Counterbalance area &n bsp; 2x 0,77 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 5,06 m ; ; (src: Handbuch)
Depth with counterbalance (length) &nbs p; 0,64 m ; ; (src: Handbuch)
Depth without counterbalance (length) 0,48 m ; ; (src: Handbuch)
edge of wing, inner: 11,7 % ; ; (src: Handbuch)
edge of wing, outer: 18,5 % ; ; (src: Handbuch)
Deflection downwards &nb sp; 21? (src: Handbuch)
Deflection when used as flaps (14?)
upwards ; 39? &n bsp; &n bsp; &n bsp; (src: Handbuch)
downwards &nb sp; 11? (src: Handbuch)
Trimming rudder (only on the left side):
Area &n bsp; &n bsp;0,089 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth &nb sp; &nb sp; 1,05 m ; ; (src: Handbuch)
Depth (length) &nbs p; 0,085 m ; ; (src: Handbuch)
Flaps
Total area: & nbsp; & nbsp;9,58 m2 &nbs p; &nbs p; (src: Handbuch)
Inner:
Area &n bsp; &n bsp;2x 1,87 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth&nb sp; &nb sp; 2,550 m ; ; (src: Handbuch)
Depth & nbsp; & nbsp; 0,726 m ; ; (src: Handbuch)
Max deflection &n bsp; 30? ; ; ; (src: Handbuch)
Outer:
Area &n bsp; &n bsp;2x 2,92 m2 &nbs p; &nbs p; (src: Handbuch)
Spanwidth&nb sp; &nb sp; 4,43 m ; ; (src: Handbuch)
Depth (length), mid &nb sp; 0,66 m ; ; (src: Handbuch)
Max deflection &n bsp; 60? ; ; ; (src: Handbuch)
Ailerons:
Aileron-defl ection as flap &n bsp;14? ; ; (src: Handbuch)
Old 04-01-2014, 09:12 AM
  #113
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm still working on the Flaps today I think I've got these figured out
But I can't find any examples of the aileron hinges; they look like offset flap hinges mounted on top of the wing this doesn't make since to me.
Or they could be a cantilevered hinge mounted on top? I'm really not sure what they did here
It will be a while before I need to do this but while I was looking at the flap hinges thought I would look for these also.
Any thoughts about these hinges guys?
Bruce
Old 04-02-2014, 11:08 AM
  #114
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I've made a mock up hinge and gotten the first part of mounting the flap installed.
The real hinges will be either fiberglass w/ a brass bushing or 1/8" AG ply w/ brass bushing these are split flaps but there inset; Gene doesn't show this on his drawing, the way I've found this out was looking at the plastic model.
The aft edges is inset flush like the rest of the flap.
Here's where I'm at so far, it's slow going there's nothing on the drawings about any of this; So I'm making it up as I go.
ID:	1983483   Click image for larger version
ID:	1983484   Click image for larger version
ID:	1983485   Click image for larger version
ID:	1983486   Click image for larger version
ID:	1983487   Click image for larger version
ID:	1983488   Click image for larger version
ID:	1983489   Click image for larger version
ID:	1983491   Click image for larger version
ID:	1983492   Click image for larger version
Old 04-03-2014, 10:08 AM
  #115
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay some progress was made today on the actuator arms; Martin had asked about using a bushing or bearing I've sorta used both w/ this setup.
I made the arms / horns continue out like the ribs on the flap and glued one in between; there made out of that fiberglass sheet I made a few days ago, even though there's a bolt going through the fiberglass and there won't be much ware I still add in a small piece of brass tube for the bolt to go through then into and through the ball link which acts like a bearing.
These are just 2-56 pushrods & ball links and once I gt the servo in the correct place
I'll cut the rod and solder on a 2-56 brass coupler / clevis or ball link.
ID:	1983697   Click image for larger version
ID:	1983698   Click image for larger version
ID:	1983699   Click image for larger version
ID:	1983700   Click image for larger version
ID:	1983701   Click image for larger version
ID:	1983702   Click image for larger version
ID:	1983703   Click image for larger version
ID:	1983705   Click image for larger version
Old 04-14-2014, 09:46 AM
  #116
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know you guys were wondering where I went
I'm still working on my yard/ garden/ fencing projects hang in there I'll be back soon.
Bruce
Old 04-24-2014, 12:34 PM
  #117
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll be back on it in a few weeks the weather is perfect for me to get all my out side work completed before it gets really hot
I'm currently building fences,a sitting bench, and getting ready to start building a picnic table; I'll post some photos soon.
Bruce
Old 05-16-2014, 07:51 AM
  #118
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've now finished my spring yard work and should be back on the build very soon,
after some cleaning up of my shop
Bruce
Old 06-14-2014, 07:28 PM
  #119
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I moved the fuse into the building room yesterday and I'm going to work on getting the wing mid section up there next week.
Also I bought the parts to build my Vac-U Form box I hope to start building on that tomorrow or Monday.
Bruce
Old 06-20-2014, 09:23 PM
  #120
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In case your not following my PBY build here's the Vac-U-Box I'll be making the
canopy,turrets and scoops with; I give a step by step build of it on that thread.
I'll just show where I'm at so far here.
ID:	2007323   Click image for larger version
ID:	2007324   Click image for larger version
ID:	2007325   Click image for larger version
ID:	2007326   Click image for larger version
ID:	2007327   Click image for larger version
ID:	2007328   Click image for larger version
ID:	2007329   Click image for larger version
ID:	2007331   Click image for larger version
ID:	2007332   Click image for larger version
ID:	2007333   Click image for larger version
ID:	2007334   Click image for larger version
ID:	2007335   Click image for larger version
ID:	2007336   Click image for larger version
ID:	2007337   Click image for larger version
ID:	2007339   Click image for larger version
ID:	2007340   Click image for larger version
ID:	2007341   Click image for larger version
ID:	2007342   Click image for larger version
ID:	2007343   Click image for larger version
Old 06-23-2014, 07:17 AM
  #121
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well while waiting on the plastic and since were having a party/cook out this weekend; I took some time and cleaned the shop this weekend.
Then this morning I moved all the bits & pieces of the BV-138 build up stairs to the build room and the PBY build down stairs to get it ready for silk, dope & primer.
I over did it though this weekend and pulled something in my back so the rest of the day I'll work in my chair working on cutting out the fiberglass canopy's windows.
Check it out I haven't had this much room in the shop since I first made it into a shop LOL.
ID:	2007998   Click image for larger version
ID:	2007999   Click image for larger version
ID:	2008000   Click image for larger version
ID:	2008001   Click image for larger version
ID:	2008002   Click image for larger version
ID:	2008003   Click image for larger version
ID:	2008004   Click image for larger version
ID:	2008006   Click image for larger version
ID:	2008007   Click image for larger version
Old 07-02-2014, 06:03 PM
  #122
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys I'm working on the Vac-U-Box but the plugs ready for the next test
maybe tomorrow; I'm confident it's going to work.
Bruce
Old 07-03-2014, 08:23 PM
  #123
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HERE'S WHERE ..THE VAC-U-BOX IS.
After a few tries w/ different sizes and heat it worked.
But I think on the PBY plug I'll use a very light coat of NOVIS plastic polish to help the release.
I now can pull FOUR different sizes the smallest be a sheet 11.5 x 12 that one was to small for this plug being so tall and I'm using 0.030 plastic.
I used all of the suggestions I received from everyone the best one being to turn the plug against the rec. shape SO THE CORNERS DO NOT LINE UP.
Thanks Willsonman,
If or when you ever go to try to pull something have a LOT of extra plastic so you can play around w/ the temp and height of the sheet from the heat source to get it to sag w/ out touching the burner.
That's it for this test subject the next will be the PBY's plug I may be able to get to it on Sunday and that would be better to let the plug's epoxy paint harden even more.
SO ANYWAY CHECK IT OUT,
Bruce
ID:	2011456   Click image for larger version
ID:	2011457   Click image for larger version
ID:	2011458   Click image for larger version
ID:	2011459   Click image for larger version
ID:	2011460   Click image for larger version
ID:	2011461   Click image for larger version
ID:	2011462   Click image for larger version
ID:	2011464   Click image for larger version
ID:	2011465   Click image for larger version
Old 07-04-2014, 09:10 AM
  #124
splinterz25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HAPPY 4th of JULY everyone!
A big thanks to those who have served this country!!
Old 11-08-2019, 09:56 PM
  #125
joey_snaproll
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Blohm & Voss sea dragon build
Love the build thread , anymore up date , did you ever finish it?
thanks Joe
joey_snaproll is offline
