Reload this Page >
Top Flite Giant Zero 86" Span.
Old 06-28-2015, 04:20 PM
  #326
SWORDSN
My Feedback: (13)
Originally Posted by sparky4lawndart
Just asking.. I'm not asserting anything...
with that much spacer on the axle don't you run the risk of a hard landing bending the axle and locking up a wheel? I've had a similar setup in a P51 where the offset in the axle spelled doom for the motor (violent nose-over)...
You have a point sparky.I'm considering using a smaller wheel which would allow removing one spacer and add the gear doors.
Old 06-29-2015, 03:54 AM
  #327
dasintex
My Feedback: (10)
dasintex's Avatar
In your pictures, is that Sierra Gear with 5 1/2" Sierra Wheels?
Thanks.
Old 06-29-2015, 06:57 AM
  #328
SWORDSN
My Feedback: (13)
Thanks.
Yes,but they are just over 5 inches not 5 1/2
Old 06-29-2015, 08:23 AM
  #329
dasintex
My Feedback: (10)
dasintex's Avatar
I wonder if Sierra gear with 4 1/2" Robart wheels would work better and would allow for the Gear Doors to work, someone posted a picture earlier in this thread showing a full size Zero and the Wheels looked smaller and the 4 1/2" would be closer to scale size?
Old 06-29-2015, 11:07 AM
  #330
Bryan McLarty
Bryan McLarty's Avatar
That was me. I think it would be more like 4" wheels you'd be looking for to mate with the Sierra gear.
Old 06-29-2015, 04:29 PM
  #331
Bryan McLarty
What at about this idea?
This requires a rectangular lower strut bracket, a lower hinge pin with 4 e-clips and an axel with a drilled and tapped end. All of these items could be requested from Sierra and relatively easy to make for him. Doesn't require any mods to the existing gear.
The lower gear door would be mounted at the axel and at the lower strut bracket.
Old 07-12-2015, 01:26 PM
  #332
buddyhale
Has anyone had any issues with Robart electric retracts in their Zero? Both gear go up when retracted, but the issue I'm having is only one comes down. I've checked for binding and everything appears fine.
Old 07-12-2015, 02:52 PM
  #333
pittsdriver
My Feedback: (7)
pittsdriver's Avatar
Have you got the DIP switches set properly? I had mine set to the low voltage by mistake and had all kinds of problems. Now they work perfectly. Don
Old 07-12-2015, 03:01 PM
  #334
buddyhale
I think so. I'm running a 6v 2700mah Nimh powering only the gear. I have the DIP switch set to 'B'
Old 07-12-2015, 05:01 PM
  #335
pittsdriver
My Feedback: (7)
I'm running 7.4v direct to mine.
Old 07-12-2015, 05:38 PM
  #336
buddyhale
I have a Li-Ion I could try, although 6v packs have always worked in the past. I have about 30-40 flights on my Zero using 6v.
Higher voltage packs just increase the speed of the gear, correct?
Old 09-04-2015, 01:17 PM
  #337
SWORDSN
My Feedback: (13)
Got in a few flights yesterday and all went well.My previous problems listed were my fault mostly.I land a little hot and the Zero does better when you let it slow down.After rebuilding the fin and rudder I will add new decals
ID:	2118136   Click image for larger version
Old 01-18-2016, 02:15 PM
  #338
JAYNC
My Feedback: (7)
What balance point have you guys been using. Mine would require about 25oz to meet the fwd recommended point of 5.75" back from leading edge. Manual says start at 6.25" but of all the TF warbirds I've flown they all flew better nose heavy. Thanks
Old 01-19-2016, 05:21 AM
  #339
pittsdriver
My Feedback: (7)
This one flies better with a little forward CG. Don't worry it can handle the weight. I have over a pound forward ballast and it is still a floater. Don
Old 01-19-2016, 06:17 AM
  #340
dasintex
My Feedback: (10)
dasintex's Avatar
Is anyone using one of those On Board Starters from Mile High RC on a DLE55 or DLE55RA on this Plane?
Old 01-20-2016, 06:42 AM
  #341
SWORDSN
My Feedback: (13)
Mine flies very well balanced at 6.25 mark.I did not add any additional weight,using DLE55 w/pitts style muffler.I agree a little nose heavy is better than tail heavy.
Old 03-09-2016, 10:43 AM
  #342
ALFIEV
So, for anyone who still monitors this thread and might be interested (can't blame you if you're not) I finally managed to get my hands on one of these ARF's after many months of trying. Ended up getting it from a German outfit, arrived in New Zealand quite quickly, but sat at New Zealand customs for 2 weeks because somehow UPS couldn't work out how to ring my mobile (number was on the packing slip, and correct!!) so I couldn't pay import taxes. Finally sorted that out and delivered this morning.
Model looks great, only ***** is that the cowling was crushed on one side. No damage on the outside of the box so must assume this is a result of dodgy packaging at the factory. It is repairable, but will never be "brand new".
I intend to fit a Saito FG 60R3 with Robart gear, Best pilots pilot, Hitec servos, and will run the whole thing on LiFePo4 batteries. Looking forward to the assembly!!
Old 03-09-2016, 10:46 AM
  #343
ALFIEV
Actually, now I think of it, the cowling might never have looked brand new anyways. I am thinking I will install louvres in the cowling to increase airflow through the engine. I understand that the radial needs a better airflow than the cowling (as stock) permits.
Old 03-09-2016, 11:15 AM
  #344
Lifer
Lifer's Avatar
Try and contact Top Flite Customer Service. You might be surprised how helpful they are. Their contact info is on the front of the assembly manual.
Old 03-09-2016, 11:20 AM
  #345
hpergm
hpergm's Avatar
Hi Alf,
I am monitoring the thread - quite slow isn't it? Shame really, this is one of the best value for money Model 22 Zeros in 1:5.
I also have the same set-up as yours (FG60, Best pilots, Robarts, etc) but the project was put on the back burner because the ESM T-28 (with its friendly trike undercarriage) stole my hart. (And guess what? The FG60 fits that as well.)
Looking fwd to completing the Zero, though. I want to scale the skin out as much as possible (rivets, panel overlaps, painted insignia and the hell out of weathering). I am looking for a scheme which has Jap characters on the fin but also the odd squadron band to keep it from looking too plain vanilla. The 721st Guardians would be an interesting scheme - have you seen the "Eternal Zero"?
BR,
Hector.
P.S. People, keep the reports coming the thread is tittering on the edge of oblivion!
Old 03-09-2016, 02:31 PM
  #346
ALFIEV
Hey Hector,
Great to hear from you. Glad you are still contemplating the Zero project. Have you taken any steps to augment the airflow through the cowling on the T-28 or your FW190? I'm thinking louvres but wouldn't fit them if I don't need them.
Thanks for the advice Lifer. Will look into it.
KR
Alf
Old 03-10-2016, 01:18 AM
  #347
hpergm
hpergm's Avatar
My plan is to cut out the moulded cowl flaps and glue them at a more open position. This, in conbination with the fake radial baffle at the front of the engine, should be more than ample.
The airflow situation in the Zero is much better than my TF FW190 which does not have cowl flaps (and indeed needs louvres). There, the baffling works wonders, engine is relatively cool and the top cylinder only 10-15degrees hotter (without a louvre behind it - louvres only behind nos 2 and 3, where it does not show on the bottom part of the cowl).
Hope this helps.
Old 03-10-2016, 12:43 PM
  #348
ALFIEV
Thanks again Hector. I will wait until I start fitting the engine and cowl up, and then see what needs to be done.
Alf
Old 03-13-2016, 10:35 AM
  #349
SWORDSN
My Feedback: (13)
Mine flies great,about 50flights on it.
Old 03-13-2016, 11:08 AM
  #350
ALFIEV
Got to spend some quality time in the shed over the weekend My last assembly (careful not to upset anyone by using the word "build") was an ESM 74" Corsair. Well, the Topflite is so much more fun to assemble so far. The hardware seems to be of good quality, everything seems to fit well. I did spend 30 minutes with the covering iron and heat gun taking a few wrinkles out of the wing coverings (haven't unwrapped the fuselage yet. Just brought a couple of the aileron and flap push-rods in to work so I can solder them at lunchtime.
Enjoyable assembly so far!!
