Top Flite Giant Zero 86" Span.
Reply
Old 02-13-2017, 12:26 PM
  #426
edwmar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey there, I have the topflite zero as well and am highly interested in going electric! Would you be willing to share pics of your planes internal setup to support batteries etc? I've been trying to come up with a means to do so but with its short nose it doesn't seem to easily lend itself to creating a fuselage battery hatch. Thanks a ton!
-edwin marshall (kmarshall.jr@gmail.com)
edwmar is offline
Old 02-13-2017, 12:46 PM
  #427
Bryan McLarty
Bryan McLarty's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone used a Saito FG-60 3cyl. gas radial on this plane in this thread? What were the balance issues needed? What about removing the pre-installed noseweights?
Bryan McLarty is offline
Old 02-13-2017, 02:07 PM
  #428
aquaskiman
My Feedback: (46)
aquaskiman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Cg needs to be about 3/4 inch back from there recommended setting
aquaskiman is offline
Old 05-08-2017, 08:18 AM
  #429
fox02100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I am building this zero from Topflite with DLE 55 RA
You can see this build here ( sorry by french but there is many pictures ) :
Montage Zero Top Flite DLE 55 RA
I removed the leads in the noze... not easy because I had to open the fuse to be able to access to the nilstop nut
fox02100 is offline
Old 05-09-2017, 12:21 PM
  #430
SWORDSN
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why did you remove the weights?
SWORDSN is offline
Old 05-09-2017, 01:02 PM
  #431
fox02100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I removed weights to optimize total weight
My idea is to put the 3 Life pack as much as possible on the front by making new engine support
If I success, I will save 1,4kg
These weights are really at a bad place... too close to the gravity center !
fox02100 is offline
Old 05-10-2017, 01:25 PM
  #432
SWORDSN
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will probably still have to add some weight to the front.I'm using a DLE55 with the factory weights and i placed one life bat. behind the CG .What you are doing ,as you say,will allow for a lighter craft.Let us know how she flies.Mine flies very well.
SWORDSN is offline
Old 06-04-2017, 06:02 AM
  #433
sfl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anybody here that did a electric conversion of this plane?
I am interested!
Would be great to see some pic's, especially the battery hatch would be a challenge...
Regards SFL
sfl is offline
Old 09-07-2017, 03:31 PM
  #434
Todd D
My Feedback: (50)
Todd D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone flying this plane with a G62? Wondering if that engine would be OK if the builder were to remove the factory installed weights? Thoughts?
thanks
Todd D is offline
Old 09-08-2017, 11:20 AM
  #435
SWORDSN
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not sure how it would compare.How much do the weights, that you removed,weigh?
SWORDSN is offline
Old 09-08-2017, 04:53 PM
  #436
Todd D
My Feedback: (50)
Todd D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry should have been more clear. I don't have the plane currently. Since I have a G62 on the shelf just kind of looking for a plane for it. I saw one fly and it looked nice.
Anyone currentlt flying one with a G62?
Todd D is offline
Old 09-09-2017, 02:31 AM
  #437
fox02100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I removed factory weight
Total 1.4kg
I use DLE 55 and put in the cowl 2 Life A123 2500mAh
fox02100 is offline
Old 09-09-2017, 03:21 AM
  #438
bladebender
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lifer how much for ringmaster 40.
bladebender is offline
Old 09-09-2017, 05:36 AM
  #439
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bladebender,
I sold a control-line Ringmaster kit about a year ago. I don't have anymore.
Lifer is offline
Old 09-12-2017, 04:31 AM
  #440
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine Heat & Batteries
Total 1.4kg
Any anticipated issues with engine Heat and the Batteries?
dasintex is offline
Old 09-13-2017, 09:08 AM
  #441
fox02100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it is a good question !
I hope I will not face any trouble
Factory request to put Lipo in the cowl ( on the top of engine mount )
I put Life A123, I think stronger than Lipo
fox02100 is offline
Old 12-16-2017, 12:00 PM
  #442
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by ALFIEV View Post
So.... finally maidened the TF Zero running the Saito radial 60cc engine. This model flies very very nicely. Easy take-off, good climb out, great aileron rolls, relatively good loop although I pulled it a bit tight at the bottom coming out of the loop. Only problem was that I deployed half-flap at too high a speed and got into all sorts of bother. First it ballooned, then it went into a spiralling dive, when I pulled out of that I was inverted flying away from me with a tail wind. Managed to retract flap and roll it right-side up and brought it back. Too scared to deploy flaps again so I went for a flapless landing. Was o.k, but when I taxied back I noticed one of the main landing gears was not fully extended.
Have pulled the retract apart and found that a pin on the upper trunnion has bent which jams the gear. I have used Robart electric retracts on this model, and they weren't a cheap option!! I would not expect a bent part in the retract out of that landing, and using gear of that quality and expense!! Has anyone else found similar issues with the Robart electric retracts??
I will try to straighten the pin, but once it has bent I wonder if it will continue to bend.
Anyway, an action packed maiden!! One I would not like to repeat. Appears I will have to slow this baby right down before thinking about deploying flap. Bloody scary, I thought I had lost this model straight up!!!
What I do feel is that this model will be a great flier once I feel confident in the set-up. The Saito powered it great and sounded superb. Just have to work on the landing gear, something I didn't think I'd be doing given the expense I went to.
P.S Sorry, no video. I had someone taking video, but the quality is no where near good enough to post. Will try again next time.
The Robart Gears are over priced and unfortunately they are constantly bending or breaking. I've had terrible experience with the gear for the TF 190. I was wondering if you could use the Sierra gear mechanism with the Robart strut to solve the gear door mounting issue?
LtMash1A is offline
Old 12-16-2017, 01:07 PM
  #443
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does the assembly manual call for down elevator mixed with the flaps? If so, it sure helps with Top Flite big P-47, P-40, and Corsair.
Lifer is offline
Old 12-16-2017, 04:57 PM
  #444
Saillfish
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Robart gear
Yes the pin you are talking about bends very easy on robart gear. 2 options are. Buy the new gear part. It' expensive. The other most do is grind the weld off the gear on one side. The bent pin will fall out and then JB weld in the shank of a drill bit. Don't remember the size. But it fits perfectly. This is how many people fix that. The bit is hardened steel unlike the mild steel that bent.
Saillfish is offline
Old 02-08-2018, 08:26 PM
  #445
mustfly
My Feedback: (21)
mustfly's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got my zero a month ago this is the first time I'm going build Something like this I am used to billing 3-D airplanes any tips on please let me know
mustfly is offline
Old 02-23-2018, 11:30 PM
  #446
fox02100
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
donít worry, very easy to build
if you have motivation, remove factory weight, and put batteries in the noise
you can save 1kg
the only operation I didnít like, is the soldering of pushrod
fox02100 is offline
Old 02-25-2018, 05:11 AM
  #447
Tommy_Gun
Tommy_Gun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So if you are only used to building 3d planes, does that men that's all you're used to flying?
If that is the case, remember to fly this plane on it's wing and not on the engine and prop.
In other words especially on final approach to land, avoid high angle of attack / low airspeed type flying.
Have fun!
Tommy_Gun is offline
Contact Us Archive Advertising Cookie Policy
