Top Flite Giant Zero 86" Span.
Reply
Old 06-08-2014, 06:43 AM
  #51
chris923
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by TonyBuilder View Post
Anyone going to use the EME onboard starter for this kit?
TB
Tony,
A flyer in our club had the EME starter on a DLE55 in a Corsair. While in flight the shaft on the starter broke, taking out he prop and cowl. Great dead stick landing! It will fly again.
chris923 is offline
Old 06-10-2014, 07:46 PM
  #52
sparky4lawndart
sparky4lawndart's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've had 2 EME55's with starters, and fitted starters to a DLE55 and a DLE55RA. I've had them running for over a year and never had a problem like that... I did kill the 550 motor trying to hand flip the engine when the Lipo died. $20 for a replacement from MileHighRC... I even had one on my GS TF FW190 at a Scale Masters event in AZ and took 3rd place in ProAm Sportsman. The judges were confounded when I cut the engine on the run way and asked the tower for clearance to start her up and take off...
sparky4lawndart is offline
Old 06-11-2014, 05:03 AM
  #53
dasintex
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Frank;
You have the Zero now as well?, do you think the EME Starter will fit in the Cowl? I'm currently putting together FW190 with the Starter and have the Zero on the way to put together after the FW190; I won't get the EME Starter for the Zero if it doesn't fit in the Cowl like it does on the FW190.
Thanks.
dasintex is offline
Old 06-11-2014, 06:02 AM
  #54
sparky4lawndart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The DLE and the starter arrive today... I'll have pics to show by end of day!!! woot!
Old 06-11-2014, 04:32 PM
  #55
dmyers0403
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have three starter setups and luv em. Others were waiting to see how they performed
This is the second season and no problem. Use a 800-3S and it will last all weekend.
Two friend just installed new EME starters for DLE111 and did great in early test a couple of weeks ago.
When they saw advertisement they immediatly ordered two and were told they would have to wait for first production Ha, Add was ahead of production, imagine that
They both are building 120" Skyraiders.
Main gears are to close to allow fake engine cylinders etc unless an extension is used, least in my experience.
dmyers0403 is offline
Old 06-11-2014, 05:11 PM
  #56
sparky4lawndart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heres a pic of the DLE55RA that arrived today so I installed it and put a spare starter assembly on it... it definitely fits the cowl!
Old 06-11-2014, 08:24 PM
  #57
77chickenhawk
77chickenhawk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was wondering if you could post the website for the electric starter system please thank you
77chickenhawk is offline
Old 06-12-2014, 04:08 AM
  #58
jsjshjshu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's already being lauded and criticized in another Warbird Thread.
jsjshjshu is offline
Old 06-12-2014, 04:31 AM
  #59
dasintex
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Mile High RC sells them http://www.milehighrc.com/EME_E_Start.html
dasintex is offline
Old 06-12-2014, 06:36 AM
  #60
77chickenhawk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you very much I added it to my favorites. Unfortunately it will not work on my zero because I didn't build it having it in hand prior to assembly. But the next Warbird will definitely will have it
Old 06-12-2014, 06:02 PM
  #61
sparky4lawndart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Electric starter install.. so easy, even I can do it!
Steps:
  • order starter from MileHighRC
  • wait patiently for the mailman
  • tackle mailman on your lawn and find your package from MileHighRC
  • unbox everything...
  • remove prop shaft from motor (1/2 deep socket)
  • use gear puller to slide prop hub off motor
  • remove woodruff key
  • install new woodruff key
  • slide spacer onto shaft (cafeful with the key)
  • put the starter assembly onto motor
  • install Sprague gear
  • install prop hub
  • tighten new prop shaft with 13mm deep socket
  • mount on plane!!!!
ID:	2004533   Click image for larger version
ID:	2004534   Click image for larger version
ID:	2004535   Click image for larger version
Old 06-12-2014, 08:52 PM
  #62
dmyers0403
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dont forget the two stand off brace-spacers :-))
Old 06-13-2014, 01:22 AM
  #63
bladebender
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where do you get that gear puller
bladebender is offline
Old 06-13-2014, 02:35 AM
  #64
TonyBuilder
TonyBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Auto parts store!
TB
TonyBuilder is offline
Old 06-15-2014, 01:49 PM
  #65
sparky4lawndart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Went and flew the zero today... wow... very good ground handling... faster than my TF GS FW190 with the same motor and prop. my only complaint is that the electric gear take way too long to cycle... I'm used to regulated air systems on my FW190.
she goes fast w/ the DLE55RA w/ a Xoar 22X10 2 blade! she goes slow with no bad tendencies. she'll stall to the left wing (tested way up) and easy to recover if you have the altitude. she floats in like a P-47 and tracks straight as an arrow.
The big hit was really, really, big loops on the dead line. I had 5 planes fly the length of the runway and I came back in behind them - Guns, Guns, Guns! haha
The electric starter was great but I chipped a tooth on the Sprague gear (one way gear) when the motor kicked back on choke... The epoxy failed on the cowl so I'm going to try that again with silicone next.
You guys are going to love to fly this plane!
Old 06-15-2014, 02:56 PM
  #66
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What did you have to attach to the cowl with epoxy?
Lifer is offline
Old 06-15-2014, 02:58 PM
  #67
TonyBuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wood block!!!
TB
Old 06-15-2014, 03:18 PM
  #68
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've built about 8 of the TF warbird arf's and none of them have anything glued to the cowl except the plastic motor and the P-47 has the oil cooler plastic piece. None have a piece of wood glued to the cowl. Is the Zero cowl different?
Lifer is offline
Old 06-15-2014, 05:31 PM
  #69
sparky4lawndart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lifer? my FW 190 and the Zero have a cowl ring (made of wood) that you epoxy to the cowl and that bolts to the firewall (on the zero, there's a cowl mount ring that gets epoxied to the firewall first.
someone suggested I use silicone.. hope it'll work better
Old 06-15-2014, 08:17 PM
  #70
2walla
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use shoe goop. Much better than silicone.
2walla is offline
Old 06-16-2014, 12:48 AM
  #71
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sparky,
My error. Thanks for the correction. Can use mix milled fiberglass with the epoxy to help the adhesion?
Lifer is offline
Old 06-16-2014, 06:50 PM
  #72
st_dysan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How is the starter actuated? They offer a controller, what does it do?
st_dysan is offline
Old 06-16-2014, 08:48 PM
  #73
sparky4lawndart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
It has a battery input ( I use a 3s 2200MAh lipo) a lead to the brushed 550 motor (starter) and a lead to your rcvr. You put the channel on a momentary switch and it signals the starter unit to send a 1.5 second pulse to the starter motor. when I first got it I was being cheap (1 1/2 years ago) and tried to rig a servo to a power switch but that failed miserably when the switch locked (burned) in the connected state and I couldn't disengage it... $30 is worth the switch made for this setup!
Old 06-16-2014, 09:27 PM
  #74
sparky4lawndart
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by Lifer View Post
Sparky,
Hey Lifer.. good idea... I'm using WestSystems 410 with T88 structural epoxy.. made my peanut butter thick filet batch and went to town!!! hope turns out okay!
Old 06-17-2014, 04:10 AM
  #75
xgnsxgnhu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just put that over here I will start that one next, want one.Looks nice
xgnsxgnhu is offline
Reply
Display Modes
